Glass
Revision as of 08:43, 29 November 2009; view current revision
Category: Body
Also see: Power Windows
Ventilation
1972 USA Owners manual (see page 7 for ventilation -- opening of the windows: door window, ventilator glass, and Quarter Window):
Driving Safety and Comfort
Windshield/Windscreen
  • Sedan/Truck/Van windshields differ from Coupe windshield
Trix fitted a bakkie windscreen to his 1200 coupe:
Replacement
For a discussion of how to replace the windshield glass, see 1200 ute windsceen install
SEDAN
  • 72613-H1902, 72613-H1901 GLASS-WINDSHIELD PL (clear) T=6.6 2-dr SEDAN USA
  • 72613-H1903, 72613-H1900 GLASS-WINDSHIELD PLT (tinted) T=6.6 OP 2-dr SEDAN USA
  • 72613-H1003 GLASS-windshield from '70 Aug S-Std JDM replaces 72613-H1002
  • 72613-H1103 GLASS-windshield from '70 Aug S-DX, S-GL, 4GX JDM replaces 72613-H1102
  • 76210-H1001 WEATHERSTRIP-windshield from '70 Aug Sedan, Van replaces 76210-H1000
COUPE
  • 72613-H1910,72613-H1913 GLASS-WINDSHIELD (tinted) T=6.6 Coupe USA
  • 72613-H1802 GLASS-windshield Coupe from '70 Aug JDM replaces 72613-H1801
  • 76210-H1801 WEATHERSTRIP-windshield from '70 Aug Coupe replaces 76210-H1800
TRUCK
  • 72613-H1102 GLASS-WINDSHIELD all 7510-8611
  • 72613-G1900 GLASS-WINDSHIELD all 8611-
  • 72610-G1000 WEATHERSTRIP-WINDSHIELD all 7510-
VAN
  • 72613-H1003 GLASS-windshield, front from '70 Aug V-Std replaces 72613-H1002 VS, VP
  • 72613-H1103 GLASS-windshield, front from '70 Aug V-Dx, V-P replaces 72613-H1102
  • 76210-H1001 WEATHERSTRIP-windshield Sedan, Van
Moulding Trim Sedan & Van
S-DX, S-GL, 4-GX, Van-Dx
Early style: single upper piece
  • 72810-H1100 SET-MOULDING, windshield
    • 72812-H1100 MOULDING-windshield, upper
    • 72814-H1100 MOULDING-windshield, side (R.H.)
    • 72815-H1100 MOULDING-windshield, side (L.H.)
    • 72813-H1100 MOULDING-windshield, lower
From '70 June: tree-piece upper
The SET replaces the earlier SET, but not vice-versa
  • 72810-H1101 SET-MOULDING, windshield S-DX, S-GL, 4-GX, V-DX, V-P
    • 72811-H1101 MOULDING-windshield, upper (R.H.)
    • 72812-H1101 MOULDING-windshield, upper (L.H.)
    • 72814-13600 CLIP-moulding
    • 72814-H1101 MOULDING-windshield, side (R.H.)
    • 72815-H1101 MOULDING-windshield, side (L.H.)
Moulding Trim Coupe
  • 72810-H1800 SET-MOULDING, windshield
    • 72812-H1800 MOULDING-windshield, upper
    • 72814-H1800 MOULDING-windshield, side (R.H.)
    • 72815-H1800 MOULDING-windshield, side (L.H.)
    • 72813-H1800 MOULDING-windshield, lower
  • 72810-H1801 SET-MOULDING, windshield S-DX, S-GL, 4-GX
    • 72811-H1801 MOULDING-windshield, upper (R.H.)
    • 72812-H1801 MOULDING-windshield, upper (L.H.)
    • 72814-H1801 MOULDING-windshield, side (R.H.)
    • 72815-H1801 MOULDING-windshield, side (L.H.)
Moulding Trim Truck
74-up Truck uses 8-piece molding set. Has L-shaped pieces in the corners.
  • 72810-G1000 MOULDING SET-WINDSHIELD all 7510-
Door Glass
  • 2-dr Coupe Door glass differs from 2-dr Sedan glass
  • 2-dr and 4-dr glass differs
  • 4-dr van and 4-dr sedan are the same
Wing Window
2-door sedan and Pickup
  • 80282-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, RH $13.69
  • 80283-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, LH $13.69
4-door Sedan
  • 82242-H1000 RH
  • 82243-H1000 LH
Window Regulator
  • 2-dr Sedan/2-dr Coupe
    Top: Coupe
    Bottom: 2-dr Sedan
  • 1980 Sunny Truck
Rear Glass
Rubber Seals
  • 72610-H1001,72610-H1000 WEATHERSTRIP-WINDSHIELD 2-dr SEDAN $95.37 USD
  • 72610-H1800,72610-H1801 WEATHERSTRIP-WINDSHIELD Coupe
  • 72810-H1100 SET-MOULDING WITH SHIELD (4-piece set) Sedan -0570
  • 72810-H1101 SET-MOULDING WITH SHIELD (6-piece set) Sedan 0670-
    both sedan sets interchange
Sources
  • Nissan dealer
  • Sydney: American Auto Parts
  • Sydney: Spectrum Rubber
  • Melbourne: Scott's Old Auto Rubber
  • NZ: Para Rubber
  • Thomas and Trimlok
  • California: Too Intense Restoration
  • USA:
    • Pilkington Classics 1-800-848-1351
    • PPG Vintage 1-877-855-8100
Discussion
