Datsun 1200 axle shafts come in two sizes: H145 for all cars and early utes, and H165 units for 1974-1997 models.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Suppliers - USA
- Nissan
- RockAuto differential parts
- http://www.partsamerica.com
Axle
- 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
- 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
- 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
- Also B210 H165B with L16 engine
Rear Axle Seal
- Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
Rear Axle Bearing
H145
- Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
- Required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
- Nissan 43215-18000 BEARING-REAR AXLE
- SKF GRW115R Schuck's
- KOYO 83294C4
- NSK B32-3CC5
- NTN 6206BLUX/32C4 $28 USD
Interchange:
- 1967-1970 Datsun B10 (180 is B10 part number)
- 1970-1973 Datsun B110
Specs:
- O.D.: 62.000 (mm)
- Bore: 30.000 (mm)
- ?? 32 mm
- Width: 16.000 (mm)
H150/H165
- 43215-H5000 BEARING-REAR AXLE, OUTER B120 7510-, B210 H150
