30100-H1003 ASSY-DISC CLUTCH 30100-H1002 ASSY-DISC CLUTCH (HITACHI HT5 30100-H1001 ASSY-DISC CLUTCH (AKEBONO A-5 30210-H5000 ASSY-COVER CLUTCH 30210-H1901 ASSY-COVER CLUTCH 30210-H1902 ASSY-COVER CLUTCH 30210-H1003 ASSY-COVER CLUTCH 30210-H1903 ASSY-COVER CLUTCH 30210-H7000 ASSY-COVER CLUTCH 30210-H5000 ASSY-COVER CLUTCH 30210-H7000 ASSY-COVER CLUTCH 30223-E4100 SCREW-CAP CLUTCH COVER TO FLY WHEEL 08915-23810 WASHER-SPRING 30531-H1600 LEVER-WITHDRAWAL CLUTCH 30537-21010 PIN-BALL WITHDRAWAL LEVER 30537-H1000 PIN-BALL WITHDRAWAL LEVER 08915-14010 WASHER-SPRING 30501-H1000 SLEEAVE-BEARING CLUTCH RELEASE 30502-21000 BEARING-CLUTCH RELEASE 30533-H1001 SPRING-RETURN CLUTCH RELEASE 30542-H1600 COVER-DUST WITHDRAWAL LEVER 30543-H1600 BOOT-RUBBER 46540-H1600 ASSY-PEDAL CLUTCH 46525-18000 BUSH-PEDAL FULCRUM 46531-18001 COVER-PEDAL PAD 46531-M3000 COVER-PEDAL PAD 46560-18000 PIN-FULCRUM PEDAL 46483-10800 WASHER-PLAIN 08915-14010 WASHER-LOCK M10 08911-14010 NUT-HEX M10X1.25 46123-E6600 PIN-CLEVIS 46123-A0600 PIN-CLEVIS 46123-78500 PIN-CLEVIS 01532-00031 PIN-SNAP 34485-14805 PIN-SPRING 46585-H1000 SPRING-RETURN PEDAL 46510-18001 STOPPER-PEDAL 08911-30810 NUT-HEX JAM M8X1.25 30610-24900 ASSY-CYLINDER CLUTCH MASTER (5/8" NABCO/ 30610-24910 ASSY-CYLINDER CLUTCH MASTER (5/8" NABCO/ 46090-10600 RESERVOIR-BRAKE OIL(NABCO) 46090-10610 RESERVOIR-BRAKE OIL(TOKICO) 46016-12200 ASSY-BAND OIL RESERVOIR (NABCO) 46016-14600 ASSY-BAND OIL RESERVOIR (NABCO) 46016-10610 ASSY-BAND OIL RESERVOIR (TOKICO) 46020-10611 SET-CAP OIL RESERVOIR (TOKICO) 46020-28600 SET-CAP OIL RESERVOIR(NABCO) 46020-E0300 SET-CAP OIL RESERVOIR(NABCO) 46061-30000 SPRING-PISTON(NABCO/TOKICO) 46077-08710 ASSY-PISTON CLUTCH MASTER (TOKICO) 46076-08700 ASSY-PISTON CLUTCH MASTER (NABCO) 46064-30002 CUP-PISTON "P" (NABCO) 46064-10610 CUP-PISTON(TOKICO) 46065-15800 CUP-PISTON"S"(NABCO) 46065-10610 CUP-PISTON"S"(TOKICO) 46073-30800 ASSY-VALVE INLET(NABCO) 46073-10610 ASSY-VALVE INLET(TOKICO) 46056-27260 SPRING-VALVE INLET (NABCO/TOKIC 46076-30800 RETAINER-SPRING (NABCO/TOKIC 46032-27260 PIN-RELEASE INLET VALVE (NABCO) 46032-10610 PIN-RELEASE INLET VALVE (TOKICO) 46043-27260 PACKING(NABCO) 46079-27260 RING-"O"(NABCO) 46079-10610 RING"O"(TOKICO) 30631-24900 ASSY-ROD BUSH(NABCO) 30631-24910 ASSY-ROD BUSH(TOKICO) 46070-27260 RING-SNAP(NABCO/TOKICO) 46100-27260 COVER-DUST(NABCO/TOKICO) 30610-10627 KIT-REPAIR"A"(TOKICO) 30610-10625 KIT-REPAIR"A"(NABCO) 30610-08726 KIT-REPAIR"B"(NABCO) 30610-10628 KIT-REPAIR"B"(TOKICO) 08110-84510 BOLT-HEX M8 08915-23810 WASHER-LOCK M8 30613-27260 SHIM T=0.5MM 30611-27260 SHIM T=1.6MM 30612-27260 SHIM T=0.8MM 30620-H1600 ASSY-CYLINDER CLUTCH OPERATING 30620-H1601 ASSY-CYLINDER CLUTCH OPERATING 30625-27260 PISTON 30624-21000 CUP-PISTON 30628-H1600 ROD-PUSH 30627-25500 COVER-DUST 41128-18000 SCREW-BLEEDER 41129-A2410 CAP-BLEEDER 41129-40F00 CAP-BLEEDER 30547-78001 NUT-PUSH 08121-02565 BOLT 08911-30810 NUT-LOCK 46201-89914 ASSY-HOSE CLUTCH 46211-01A14 ASSY-HOSE CLUTCH 46237-18000 GASKET-CLUTCH HOSE TO CYLINDER T=0 46237-A4600 GASKET-CLUTCH HOSE TO CYLINDER T=1 46211-01A14 ASSY-HOSE CLUTCH 46205-61000 PLATE-LOCK CLUTCH HOSE 46206-18000 SPRING-LOCK CLUTCH HOSE 46410-H1600 ASSY-TUBE CLUTCH 32010-H3963 ASSY-TRANSMISSION (F4W56A) 32010-H3953 ASSY-TRANSMISSION (F4W56L) 32010-H3951 ASSY-TRANSMISSION (F4W56L) 32010-H3950 ASSY-TRANSMISSION(F4W56E) 32010-H3551 ASSY-TRANSMISSION (F4W56) FINAL GEAR R 32010-H1652 ASSY-TRANSMISSION(F4W56) FINAL GEAR R 32100-H1630 CASE-TRANSMISSION 32101-H3900 CASE-TRANSMISSION 32100-H3930 ASSY-CASE,TRANSMISSION 32100-H1600 CASE-TRANSMISSION 32102-18000 PLUG-WELCH TRANSMISSION CASE 00933-11400 PLUG-WELCH TRANSMISSION CASE 00933-11400 PLUG-WELCH TRANSMISSION CASE 00931-10810 PLUG-FILLER 32110-H1000 ASSY-COVER FRONT T/M CASE 32113-13200 SEAL-OIL FRONT COVER 32113-H3100 SEAL-OIL FRONT COVER 32112-18000 RING-'O' FRONT COVER 32208-18002 SHIM-ADJUST FRONT COVER T=0.1MM 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3MM 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2MM 32208-18000 SHIM-ADJUSTING FRONT COVER T=0.5MM 08120-82510 BOLT 08915-13810 WASHER-LOCK 32130-H3900 ASSY-EXTENSION REAR 32130-H6230 ASSY-EXTENSION REAR WITHOUT OIL SEAL 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 32130-H1030 ASSY-EXTENSION REAR WITHOUT OIL SEAL 32130-H1010 ASSY-EXTENSION REAR 32130-H0110 ASSY-EXTENSION REAR 32130-H3901 ASSY-EXTENSION REAR 32132-18000 BUSH-REAR EXTENSION 32136-G1001 SEAL-OIL REAR EXTENSION 32136-18001 SEAL-OIL REAR EXTENSION 32136-H3100 SEAL-OIL REAR EXTENSION 38322-N0100 ASSY-BREATHER 38322-A0900 ASSY-BREATHER 32140-24900 BUSH-RETURN SPRING 00931-10810 PLUG-FILLER 08120-85510 BOLT 08915-23810 WASHER-LOCK 08915-43810 WASHER-PLAIN 32137-H1010 ASSY-PLATE ADAPTER 32133-18000 PIN-DOWEL REAR EXTENSION 32141-24900 BUSH-STRIKING ROD 32005-21100 COMP-SWITCH REVERSE LAMP 32005-21101 COMP-SWITCH REVERSE LAMP 32005-H5000 COMP-SWITCH REVERSE LAMP 32005-H5000 COMP-SWITCHI,4 TH 32005-21100 COMP.-SWITCH,4 TH 32005-21101 COMP-SWITCH,4 TH 32006-H6000 COMP-SWITCH,NEUTRAL 32006-H3900 COMP.-SWITCH,NEUTRAL 08120-85510 BOLT FIXING TRANSMISSION 08915-23810 WASHER-LOCK FIXING TRANSMISSION 24210-89957 CLIP 32702-15400 ASSY-PINION SPEEDOMETER 17T 32707-18000 ASSY-SLEEVE SPEEDOMETER 32709-18000 RING-'O' SPEEDOMETER PINION 32710-18000 RING-'O' SPEEDOMETER PINION 32708-18000 WASHER-SPEEDOMETER PINION 32712-18000 PIN-RETAINING SPEEDOMETER 08915-13610 WASHER-LOCK 08110-61410 BOLT 30422-18000 COVER-DUST CLUCH HOUSING 08110-61010 BOLT 08915-13610 WASHER-LOCK 32280-24901 ASSY-GEAR REVERSE IDLER 17T 32283-24901 BUSH-GEAR REVERSE IDLER 32281-24900 SHAFT-REVERSE IDLER 32285-18000 RING-SNAP REVERSE IDLER 32210-24900 GEAR-COUNTER 29T,25T,19T,13T 32223-24900 BEARING-BALL COUNTER SHAFT 32220-24901 GEAR-REVERSE COUNTER 13T 00922-11700 RING-SNAP 32219-18000 BEARING-BALL COUNTER SHAFT 32224-18003 SHIM-ADJUSTING COUNTER BEARING T=1. 32224-18006 SHIM-ADJUSTING COUNTER BEARING T=1. 32224-18004 SHIM-ADJUSTING COUNTER BEARING T=1. 32224-18002 SHIM-ADJUSTING COUNTER BEARING T=0. 32224-18001 SHIM-ADJUSTING COUNTER BEARING T=0. 32224-18005 SHIM-ADJUSTING COUNTER BEARING T=1. 00922-24000 RING-SNAP 32200-H1000 ASSY-GEAR MAIN DRIVE 19T,30T 32203-18000 BEARING-BALL MAIN SHAFT 32205-18000 WASHER-MAIN BEARING 32204-18000 RING-SNAP MAIN DRIVE GEAR SHAFT 32241-H1010 SHAFT-MAIN 32246-18000 WASHER-THRUST MAIN SHAFT 32253-H1000 BUSH-MAIN SHAFT REVERSE GEAR 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 32264-H1000 BEARING-NEEDLE MAIN SHAFT 32264-18000 BEARING-NEEDLE MAIN SHAFT 32236-18000 SPACER-NEEDLE BEARING 32230-24900 ASSY-GEAR 1ST SPEED MAIN SHAFT 32T 32604-H1000 RING-BAULK 32609-18000 INSERT-SHIFTING 32603-18000 SPRING-SYNCHRONIZER 32601-18000 HUB-SYNCHRONIZER 32606-18000 SLEAVE-COUPLING 32264-24900 BEARING-NEEDLE MAIN SHAFT 32250-24900 ASSY-GEAR 2ND SPEED MAIN SHAFT 27T 32260-24900 ASSY-GEAR 3RD SPEED MAIN SHAFT 23T 32604-H1000 RING-BAULK 32604-H1010 RING-BAULK 32609-18000 INSERT-SHIFTING 32603-18000 SPRING-SYNCHRONIZER 32601-18000 HUB-SYNCHRONIZER 32606-18000 SLEEVE-COUPLING 32265-18000 WASHER-THRUST SYNCHRO HUB 32265-H7200 WASHER-THRUST SYNCHRO HUB 32720-14600 BALL-STEEL 32272-18000 BEARING-PILOT MAIN SHAFT 32273-24900 BEARING-MAIN SHAFT 32205-18000 WASHER-MAIN BEARING 32204-18000 RING-SNAP MAIN SHAFT 32245-24901 GEAR-REVESE MAIN SHAFT 31T 32801-24901 ROD-FORK 1ST & 2ND 32805-18000 FORK-SHIFT 32293-73200 PIN-RETAINING 32809-24900 ROD-FORK 3RD & 4TH 32809-H3900 ROD-FORK 3RD & 4TH 32813-24901 BRACKET-FORK ROD 32293-73200 PIN-RETAINING 32803-18000 RING-STOPPER 32816-24901 ROD-FORK REVERSE 32819-24901 FORK-SHIFTING REVERSE 32829-26760 BALL-CHECKING 32832-18000 PLUNGER-INTER LOCK 32830-18000 SPRING-CHECKING BALL 32834-18000 PLUG-CHECKING BALL 32892-24901 ROD-STRIKING 32892-H3900 ROD-STRIKING 32896-24901 LEVER-STRIKING 32897-24901 SCREW-SET STRIKING LEVER 32804-24900 WIRE-LOCK 32850-24901 ASSY-GUIDE STRIKING ROD 32858-14600 RING-O 32857-14600 CAP-RING O 32846-24900 RING-"E" TYPE 32847-24901 PIN-STOPPER CONTROL ARM 32848-24900 RING-"O"CONTROL ARM 32851-24900 PLUNGER-RETURN SPRING 32851-N9000 PLUNGER-RETURN SPRING 32852-24901 SPRING-RETURN 32853-24900 PLUG-RETURN SPRING 32856-24901 SPRING-REVERSE CHECK 00933-32810 PLUG-EXPANSION 32841-H1011 ASSY-LEVER CONTROL 32854-24900 RING-"E"9S 32849-24900 PIN-CONTROL ARM 32849-H1010 PIN-CONTROL ARM 32855-24900 BUSH-CONTROL LEVER 32855-H1010 BUSH-CONTROL LEVER 32861-24900 BUSH-CONTROL LEVER HEAD 32861-N4200 BUSH-CONTROL LEVER HEAD 32862-24900 BOOT-RUBBER CONTROL LEVER 32862-G1200 BOOT-RUBBER CONTROL LEVER 32865-27700 KNOB-CONTROL LEVER 32865-H1000 KNOB-CONTROL LEVER 32865-V2400 KNOB-CONTROL LEVER 74963-20900 BOOT-CONTROL LEVER 32801-24901 ROD-FORK 1ST & 2ND 32805-18000 FORK-SHIFT 32293-73200 PIN-RETAINING 32809-24900 ROD-FORK 3RD & 4TH 32809-H3900 ROD-FORK 3RD & 4TH 32813-24901 BRACKET-FORK ROD 32293-73200 PIN-RETAINING 32803-18000 RING-STOPPER 32816-24901 ROD-FORK REVERSE 32819-24901 FORK-SHIFTING REVERSE 32829-26760 BALL-CHECKING 32832-18000 PLUNGER-INTER LOCK 32830-18000 SPRING-CHECKING BALL 32834-18000 PLUG-CHECKING BALL 32892-24901 ROD-STRIKING 32892-H3900 ROD-STRIKING 32896-24901 LEVER-STRIKING 32897-24901 SCREW-SET STRIKING LEVER 32804-24900 WIRE-LOCK 32850-24901 ASSY-GUIDE STRIKING ROD 32858-14600 RING-O 32857-14600 CAP-RING O 32846-24900 RING-"E" TYPE 32847-24901 PIN-STOPPER CONTROL ARM 32848-24900 RING-"O"CONTROL ARM 32851-24900 PLUNGER-RETURN SPRING 32851-N9000 PLUNGER-RETURN SPRING 32852-24901 SPRING-RETURN 32853-24900 PLUG-RETURN SPRING 32856-24901 SPRING-REVERSE CHECK 00933-32810 PLUG-EXPANSION 32841-H1011 ASSY-LEVER CONTROL 32854-24900 RING-"E"9S 32849-24900 PIN-CONTROL ARM 32849-H1010 PIN-CONTROL ARM 32855-24900 BUSH-CONTROL LEVER 32855-H1010 BUSH-CONTROL LEVER 32861-24900 BUSH-CONTROL LEVER HEAD 32862-24900 BOOT-RUBBER CONTROL LEVER 32865-H1000 KNOB-CONTROL LEVER 32865-27700 KNOB-CONTROL LEVER 74963-20900 BOOT-CONTROL LEVER 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT 37111-20300 ASSY-YOKE SLEEVE 37111-18001 ASSY-YOKE SLEEVE 37117-18000 YOKE-FLANGE 37125-18025 ASSY-JOURNAL WITH BEARING 37125-H1025 KIT-JOURNAL WITH BEARING 37130-18000 ASSY-RACE BEARING WITH OIL SEAL 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL 37147-18000 RING-SNAP BEARING RACE T=1.48 37148-18000 RING-SNAP BEARING RACE T=1.50 37149-18000 RING-SNAP BEARING RACE T=1.52 37146-18000 RING-SNAP BEARING RACE T=1.46 08120-82210 BOLT-HEX M8X1.25 01111-00061 BOLT-FIX PROPELLER SHAFT 01111-00151 BOLT-FIX PROPELLER SHAFT 08911-20810 NUT-HEX M8X1.25 08915-13810 WASHER-LOCK M8 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) 38310-G0400 COMP-CARRIER GEAR 38315-G0400 BOLT FIXING DIFF BEARING CAP 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP 38100-H1000 SET-GEAR & PINION HYPOID 39:10 38102-G0300 BOLT-DRIVE GEAR 38103-G0400 STRAP-LOCK BOLT 38421-G0500 CASE DIFFERENTIAL 38423-18000 GEAR-SIDE DIFF BEVEL 38424-18000 WASHER-THRUST SIDE GEAR 38424-18001 WASHER-THRUST SIDE GEAR 38424-18002 WASHER-THRUST SIDE GEAR 38425-18000 MATE-PINION DIFF BEVEL 38426-18000 WASHER-THRUST PINION MATE 38427-18000 SHAFT-PINION MATE 38428-G0400 PIN-LOCK DIFF PINION 38440-H1000 ASSY-BEARING DIFF SIDE 38440-18000 ASSY-BEARING DIFF SIDE 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 38120-18000 ASSY-BEARING DRIVE PINION REAR 38140-18000 ASSY-BEARING DRIVE PINION FRONT 38165-H1000 SPACER-DRIVE PINION BEARING 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 38189-18000 SEAL-OIL DRIVE PINION 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER 38210-18000 ASSY-FLANGE COMPANION 38215-01300 WASHER-PLASN 38216-18000 NUT-DRIVE PINION 38320-18010 GASKET-GEAR CARRIER 08915-13810 WASHER-LOCK 08911-20810 NUT 34902-H1900 ASSY-HAND LEVER & BRACKET 34903-H1900 ASSY-BRACKET HAND LEVER 34907-25820 BUSH-HAND LEVER BRACKET 34909-H1100 PACKING-HAND LEVER BRACKET 34915-H1100 ASSY-SUPPORT HAND LEVER 34946-H0300 SPRING-RETURN SELECT 34912-H1100 LEVER-HAND 34919-25820 KNOB-HAND LEVER 34919-H1000 KNOB-HAND LEVER 34923-25820 SCREW-HAND LEVER 34947-25820 PIN-SELECT 18136-61503 RING-SNAP"E" 34913-H1900 ASSY-SHAFT HAND LEVER 34434-89900 SCREW-LOCK 00851-21610 WIRE-LOCK 08360-82014 SCREW-MACHINE M8X1.25 34932-H2520 COMP-SHAFT ROD 34552-89900 INSULATOR-ROD 34419-04100 WASHER-SPRING 34485-14805 PIN-SPRING 34951-H2520 ASSY-CROSS SHAFT 34952-H1100 COMP-BRACKET CROSS SHAFT 34462-18000 BUSH-SPHERICAL CROSS SHAFT 34965-25820 COVER-OUTER RH CROSS SHAFT 34966-25820 COVER-INNER RH CROSS SHAFT 34463-14806 SPRING-RETURN CROSS SHAFT 34467-84700 BOOT-OUTER CROSS SHAFT 74941-89900 COVER-OUTER LH CROSS SHAFT 34936-H1100 COMP-SHAFT ROD LOWER 34938-25820 PIN-SHAFT ROD 34948-25820 RING-SNAP 'E' TYPE 34410-21000 TRUNION-GEAR SHAFT ROD 34552-89900 INSULATOR-ROD 01311-00021 WASHER-PLAIN 34419-04100 WASHER-SPRING 34485-14805 PIN-SPRING 08911-14010 NUT-HEX M10X1.25 32100-H6210 CASE-TRANSMISSION 00933-11400 PLUG-WELCH TRANSMISSION CASE 00931-10810 PLUG-FILLER 32110-H1000 ASSY-COVER FRONT TRANSMISSION 32113-H3100 SEAL-OIL FRONT COVER 32112-18000 RING-'O' FRONT COVER 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2 32208-18002 SHIM-ADJUSTING FRONT COVER T=0.1 08120-82510 BOLT-FIX FRONT COVER 08915-13810 WASHER-SPRING 32130-H6200 ASSY-EXTENSION REAR 32132-18000 BUSH-REAR EXTENSION 32136-G1001 SEAL-OIL REAR EXTENSION 38322-A0900 ASSY-BREATHER 38322-N0100 ASSY-BREATHER 32140-24900 BUSH-RETURN SPRING 00931-10810 PLUG-FILLER 08120-85510 BOLT 08915-23810 WASHER-LOCK 08915-43810 WASHER-PLAIN 32137-G1100 ASSY-PLATE ADAPTER 32133-18000 PIN-DOWEL REAR EXTENSION 32141-24900 BUSH-STRIKING ROD 32005-21101 COMP-SWITCH REVERSE LAMP 32005-K1214 COMP-SWITCH REVERSE LAMP 32005-H5000 COMP-SWITCH REVERSE LAMP 32006-H6000 COMP-SWITCH 4TH LAMP 08120-85510 BOLT-FIXING TRANSMISSION 08915-23810 WASHER-LOCK FIXING TRANSMISSION 24210-89957 CLIP 32702-15400 ASSY-PINION SPEEDOMETER 17T 32703-15400 ASSY-PINION SPEEDOMETER 17T 32707-18000 ASSY-SLEEVE SPEEDOMETER 32709-18000 RING-'O' SPEEDOMETER PINION 32710-18000 RING-"O" SPEEDOMETER SLEEVE 32708-18000 WASHER-SPEEDOMETER PINION 32712-18000 PIN-RETAINING SPEEDOMETER 08915-13610 WASHER-LOCK 08110-61410 BOLT-FIX SPEEDOMETER 30422-H5010 COVER-DUST CLUTCH HOUSING 08111-01614 BOLT-HEX DUST COVER 32719-18000 BUSH-SLEEVE SPEEDOMETER 32280-G1100 ASSY-GEAR REVERSE IDLER 17T 32283-G1100 BUSH-GEAR REVERSE IDLER 32281-G1100 SHAFT-REVERSE IDLER 32285-18000 RING-SNAP REVERSE IDLER 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T 32223-24900 BEARING-BALL COUNTER SHAFT 32220-G1100 GEAR-REVERSE COUNTER 13T 00922-11700 RING-SNAP 32219-G1000 BEARING-NEEDLE COUNTER SHAFT 32224-G1004 WASHER-THRUST COUNTER BEARING T=2 32224-H7205 WASHER-THRUST COUNTER BEARING T=2. 32224-H7204 WASHER-THRUST COUNTER BEARING T=2 32224-H7203 WASHER-THRUST COUNTER BEARING T=2. 32224-G1003 WASHER-THRUST COUNTER BEARING T=2. 32224-G1002 WASHER-THRUST COUNTER BEARING T=2. 32224-H7201 WASHER-THRUST COUNTER BEARING T=2. 32224-G1005 WASHER-THRUST COUNTER BEARING T=2. 32224-G1001 WASHER-THRUST COUNTER BEARING T=2. 32224-H7200 WASHER-THRUST COUNTER BEARING T=2. 32224-G1000 WASHER-THRUST COUNTER BEARING T=2. 32224-H7202 WASHER-THRUST COUNTER BEARING T=2. 32200-G1000 ASSY-GEAR MAIN DRIVE 19T,30T 32203-18000 BEARING-BALL MAIN SHAFT 32205-18000 WASHER-THRUST MAIN DRIVE GEAR 32204-18000 RING-SNAP MAIN DRIVE GEAR 32241-G1101 SHAFT-MAIN 32246-G1000 WASHER-THRUST MAIN SHAFT 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 32264-18000 BEARING-NEEDLE MAIN SHAFT 32230-G1100 ASSY-GEAR 1ST SPEED 32604-H1000 RING-BAULK 32604-H1010 RING-BAULK 32609-18000 INSERT-SHIFTING 32603-18000 SPRING-SYNCHRONIZER 32601-18000 HUB-SYNCHRONIZER 32606-18000 SLEEVE-COUPLING 32264-24900 BEARING-NEEDLE MAIN SHAFT 32250-G1100 ASSY-GEAR 2ND SPEED 32260-G1100 ASSY-GEAR 3RD SPEED 32604-H1000 RING-BAULK 32604-H1010 RING-BAULK 32609-18000 INSERT-SHIFTING 32603-18000 SPRING-SYNCHRONIZER 32601-18000 HUB-SYNCHRONIZER 32606-18000 SLEEVE-COUPLING 32265-18000 WASHER-THRUST SYNCHRONIZER HUB 32265-H7200 WASHER-THRUST SYNCHRONIZER HUB 32720-14600 BALL-STEEL 32272-18000 BEARING-PILOT MAIN SHAFT 32273-G1000 BEARING-BALL MAIN SHAFT 32205-18000 WASHER-MAIN BEARING 32204-18000 RING-SNAP MAIN SHAFT 32245-G1100 GEAR-REVERSE MAIN SHAFT 32801-G1100 ROD-FORK 1ST & 2ND 32805-18000 FORK-SHIFT 32293-73200 PIN-RETAINING 32809-H6200 ROD-FORK 3RD & 4TH 32813-24901 BRACKET-ROD 32293-73200 PIN-RETAINING 32803-18000 RING-STOPPER 32816-G1100 ROD-FORK REVERSE 32819-G1100 FORK-SHIFT REVERSE 32829-26760 BALL-CHECKING 32832-18000 PLUNGER-INTER LOCK 32830-18000 SPRING-CHECKING BALL 32834-18000 PLUG-CHECKING BALL 32892-H6200 ROD-STRIKING 32896-24901 LEVER-STRIKING 32897-24901 SCREW-SET STRIKING LEVER 32804-24900 WIRE-LOCK 32850-24901 ASSY-GUIDE STRIKING ROD 32858-14600 RING-'O' STRIKING ROD 32857-14600 CAP-RING 'O' 32846-24900 RING-'E' TYPE 32847-24901 PIN-STOPPER CONTROL ARM 32848-24900 RING-'O' CONTROL ARM 32851-N9000 PLUNGER-RETURN SPRING 32851-24900 PLUNGER-RETURN SPRING 32852-24901 SPRING-RETURN 32853-24900 PLUG-RETURN SPRING 32856-24901 SPRING-REVERSE CHECK 00933-32810 PLUG-EXPANSION 32841-H1011 ASSY-LEVER CONTROL 32854-24900 RING-'E' 9S 32849-H1010 PIN-CONTROL ARM 32855-H1010 BUSH-CONTROL LEVER 32861-24900 BUSH-CONTROL LEVER HEAD 32862-24900 BOOT-LEVER CONTROL LEVER 32865-H1000 KNOB-CONTROL LEVER 74963-20900 BOOT-CONTROL LEVER 31020-X0100 ASSY-TRANSMISSION,AUTOMATIC 31100-X0100 ASSY-CONVERTER,TORQUE 31301-X0100 HOUSING-CONVERTER 31300-X0100 HOUSING-CONVERTER 31300-X0104 HOUSING-CONVERTER 31300-X0101 HOUSING-CONVERTER 31305-H0101 SCREEN-AIR INLET 31307-H0100 GUARD-STONE 08310-51012 SCREW 31309-X0100 BOLT 31310-X0100 ASSY-CASE,TRANSMISSION 31310-X0151 ASSY-CASE,TRANSMISSION 00931-10210 PLUG-SQUARE HEAD 31472-X0100 RACE-INNER,ONEWAY CLUTCH 31484-X0100 WASHER-PLAIN 31488-F0600 BOLT 31625-X0100 PIN-ANCHOR END 31381-X0100 BREATHER-AIR 31921-X0150 ASSY-SHAFT,MANUAL 31921-X0100 ASSY-SHAFT,MANUAL 31914-X0100 SEAL-O RING (14S) 31922-X0100 WASHER-MANUAL SHAFT 31924-X0101 ASSY-PLATE,MANUAL 01211-00011 NUT 31961-20300 LEVER-PARKING 31970-X0100 ASSY-ROD,PARKING 31963-X0100 RING-SNAP (6S) 31330-X0100 ASSY-EXTENSION,REAR 31336-X0100 SEAL-OIL 31335-X0100 GASKET-REAR EXTENSION 08130-83010 BOLT 08915-43810 WASHER-PLAIN 31390-X0101 ASSY-PAN,OIL 31397-X0100 GASKET-OIL PAN 31397-X0101 GASKET-OIL PAN 31065-A4000 CLAMP-VACUUM TUBE 08160-61210 BOLT 1 08130-83010 BOLT 08120-85510 BOLT 08915-23810 WASHER-LOCK 30422-18000 COVER-DUST,CLUTCH HOUSING 08360-61010 SCREW 08915-13610 WASHER-LOCK 31009-20300 BOLT-SELF LOCK,CONVERTER 31061-H1111 TUBE-VACUUM 31064-20300 TUBE-ELBOW 31067-E0100 TUBE-JOINT 31063-H1110 CONNECTOR-VACUUM 31080-H1110 ASSY-PIPE,OIL CHARGING 08360-61214 SCREW-WITH WASHER 31084-20300 SEAL-O RING (20S) 31086-P2601 ASSY-GAUGE,OIL LEVEL 31885-H1110 ASSY-TUBE,REAR LUBRICATION 21638-P2600 JOINT-TUBE 21625-P2600 BOLT-CONNECTOR,OIL COOLER TUBE 21626-P2600 WASHER-SEAL 05412-1400P GASKET B 32703-P2621 ASSY-PINION,SPEEDOMETER 32703-P2622 ASSY-PINION,SPEEDOMETER (22T) 32707-66300 ASSY-SLEEVE,SPEEDOMETER 32709-14600 SEAL-OIL 32710-14600 RING-O 32873-14600 PIN-RETAINING 32718-14600 PLATE-LOCK 08360-61214 SCREW-WITH WASHER 31397-X0125 KIT-GASKET & SEAL AUTO TRANS 31411-X0100 SHAFT-INPUT 31440-X0100 ASSY-CARRIER,REAR PLANET 31436-X0100 RACE-BEARING,NEEDLE THRUST 31435-X0100 BEARING-NEEDLE THRUST (5070) 31477-X0100 RING-SNAP (116B) 31460-X0100 ASSY-GEAR,SUN 31465-X0100 SHELL-CONNECTING 31466-X0100 RACE-BEARING,CONNECTING SHELL 31467-X0100 RING-SNAP (47S) 31420-X0100 ASSY-CARRIER,FRONT PLANET 31428-X0100 BEARING-NEEDLE THRUST (3047) 31436-X0100 RACE-BEARING,PLANET CARRIER 31431-X0100 GEAR-INTERNAL 31553-X0100 HUB-REAR CLUTCH 31433-X0100 RING-SNAP (99B) 31435-X0100 BEARING-NEEDLE THRUST (5070) 31438-X0100 BEARING-NEEDLE THRUST (3553) 31431-X0100 GEAR-INTERNAL 31452-X0100 FLANGE-INTERNAL DRIVE 31433-X0100 RING-SNAP (99B) 31428-X0100 BEARING-NEEDLE THRUST (3047) 31435-X0100 BEARING-NEEDLE THRUST (5070) 00922-12800 RING-SNAP (28) 31471-X0100 DRUM-CONNECTING 31475-X0100 RACE-OUTER,ONE WAY CLUTCH 31476-X0100 RING-SNAP (92B) 31473-X0100 ASSY-CLUTCH,ONE WAY 31479-X0100 RING-SNAP (71B) 31376-X0100 RING-SNAP (134) 31667-X0104 PLATE-RETAINING, T=16.6 31667-X0105 PLATE-RETAINING, T=16.8 31667-X0103 PLATE-RETAINING, T=16.4 31667-X0102 PLATE-RETAINING, T=16.2 31667-X0101 PLATE-RETAINING, T=16.0 31667-X0100 PLATE-RETAINING, T=15.8 31662-X0100 ASSY-PLATE,ORIVE (130) 31666-X0100 PLATE-DRIVEN (130) 31668-X0100 PLATE-DISHED (130) 31652-X0101 RING-SNAP (56S) 31651-X0100 SPRING-PISTON RETURN 31651-X0101 SPRING-PISTON RETURN 31648-X0100 RING-THRUST SPRING 31647-X0100 SEAL-O RING (56D) 31646-X0100 SEAL-LATHE CUT RING (132D) 31645-X0100 PISTON-LOW & REVERSE BRAKE 31438-X0100 BEARING-NEEDLE THRUST (3553) 31489-X0100 RACE-BEARING,DISTRIBUTOR 31480-X0100 ASSY-SHAFT,OUTPUT 31486-X0100 ASSY-DISTRIBUTOR,OIL 31487-X0100 RING-SEAL (62) 31860-X0410 ASSY-GOVERNOR 31862-X0100 VALVE-PRIMARY GOVERNOR 31863-X0100 SPRING-PRIMARY GOVERNOR 31872-X0410 VALVE-SECONDARY GOVERNOR (35) 31873-X0100 SPRING-SECONDARY GOVERNOR 31864-X0100 PLATE-RETAINER 08160-61610 BOLT 31340-X0100 ASSY-PUMP,OIL 31340-X0101 ASSY-PUM.OIL 31341-X0100 ASSY-HOUSING,OIL PUMP 31344-X0100 SEAL-HOUSING 31346-X0102 GEAR-INNER,OIL PUMP 31346-X0100 GEAR-INNER,OIL PUMP 31346-X0101 GEAR-INNER,OIL PUMP 31347-X0100 GEAR-OUTER,OIL PUMP 31347-X0101 GEAR-OUTER,OIL PUMP 31347-X0102 GEAR-OUTER,OIL PUMP 31350-X0100 ASSY-COVER,OIL PUMP 31350-X0101 ASSY-COVER,OIL PUMP 31361-X0100 RING-SEAL (44) 31362-X0100 RING-SEAL (43) 08120-61810 BOLT 31363-X0100 SEAL-LATHE CUT RING (200D) 31366-X0100 GASKET-OIL PUMP 31556-X0102 RACE-BEARING,PUMP COVER, T=1.6 31556-X0105 RACE-BEARING,PUMP COVER, T=2.2 31556-X0103 RACE-BEARING,PUMP COVER, T=1.8 31556-X0100 RACE-BEARING,PUMP COVER, T=1.2 31556-X0104 RACE-BEARING,PUMP COVER, T=2.0 31556-X0101 RACE-BEARING,PUMP COVER, T=1.4 31528-X0100 WASHER-THRUST, T=1.9 31528-X0101 WASHER-THRUST, T=2.1 31528-X0102 WASHER-THRUST, T=2.3 31528-X0103 WASHER-THRUST, T=2.5 31528-X0104 WASHER-THRUST, T=2.7 31528-X0105 WASHER-THRUST, T=1.7 31528-X0106 WASHER-THRUST, T=1.5 31540-X0100 ASSY-CLUTCH,REAR 31542-X0100 DRUM-REAR CLUTCH 31517-X0100 SEAL-O RING (54D) 31514-X0102 ASSY-PISTON,CLUTCH 31514-X0101 ASSY-PISTON,CLUTCH 31516-X0100 SEAL-LATHE CUT RING (116D) 31521-X0100 SPRING-PISTON RETURN 1 31552-X0100 RETAINER SPRING 31552-X0102 RETAINER-SPRING 31523-X0100 RING-SNAP (54S) 31529-X0100 PLATE-DISHED (115) 31536-X0100 PLATE-DRIVEN (115) 31532-X0100 ASSY-PLATE,DRIVE (115) 31567-X0100 PLATE-RETAINING (115) 31538-X0100 RING-SNAP (118) 31439-X0100 RACE-BEARING,REAR CLUTCH DRUM 31555-X0100 BEARING-NEEDLE THRUST (2035) 31510-X0100 ASSY-CLUTCH,FRONT 31511-X0100 ASSY-DRUM,FRONT CLUTCH 31517-X0100 SEAL-O RING (54D) 31514-X0101 ASSY-PISTON,CLUTCH 31514-X0102 ASSY-PISTON,CLUTCH 31516-X0100 SEAL-LATHE CUT RING (116D) 31521-X0100 SPRING-PISTON RETURN 1 31552-X0100 RETAINER-SPRING 31552-X0102 RETAINER-SPRING 31523-X0100 RING-SNAP (54S) 31529-X0100 PLATE-DISHED 31536-X0100 PLATE-DRIVEN (115) 31532-X0100 ASSY-PLATE,DRIVE (115) 31537-X0102 PLATE-RETAINING, T=11.0 31537-X0105 PLATE-RETAINING, T=11.6 31537-X0103 PLATE-RETAINING, T=11.2 31537-X0101 PLATE-RETAINING, T=10.8 31537-X0100 PLATE-RETAINING, T=10.6 31537-X0104 PLATE-RETAINING, T=11.4 31538-X0100 RING-SNAP (118B) 31630-X0100 ASSY-BAND,BRAKE 31624-X0100 STRUT-BAND 31621-X0100 SPRING-PISTON RETURN (10KG) 31615-X0100 PISTON-BAND SERVO (64-44) 31611-X0100 RETAINER-SERVO (64-44) 31616-X0100 SEAL-LATHE CUT RING (64D) 31617-X0100 SEAL-LATHE CUT RING (44D) 31628-X0100 SEAL-O RING (82S) 31612-X0100 SEAL-LATHE CUT RING (80D) 31618-X0101 STEM-BAND SERVO PISTON 31618-X0100 STEM-BAND SERVO PISTON 31619-X0100 WASHER-STEM 08915-44200 WASHER-PLAIN 08540-70810 NUT 08160-61610 BOLT 31532-X0125 KIT-CLUTCH REPAIR AUTO TRANS 31705-X0410 ASSY-VALVE,CONTROL 31710-X0410 BODY-UPPER,CONTROL VALVE 32829-26760 BALL-STEEL (7.938) 31733-X0100 SPRING-DETENT,MANUAL 31734-X0100 PIN-SEAT,DETENT SPRING 31731-X0100 VALVE-MANUAL 31741-X0100 VALVE-PRESSURE REGULATOR 31742-X0100 SPRING-PRESSURE REGULATOR 31743-X0100 SEAT-SPRING,PRESSURE LEGULA 31746-X0100 PLUG-PRESSURE REGULATOR 31747-X0101 SLEEVE-PLUG,PRESSURE REGULA 31825-X0100 VALVE-2ND LOCK 31826-X0100 SPRING-2ND LOCK 31724-X0100 PLATE-SIDE,D 08360-51012 SCREW 31781-X0100 VALVE-2,3 TIMING 31782-X0100 SPRING-2,3 TIMING 31801-X0100 VALVE-THROTTLE VACUUM 31808-X0100 VALVE-THROTTLE BACK UP 31809-X0100 SPRING-THROTTLE BACK UP 31817-X0100 SPRING-SOLENOID DOWN SHIFT 31816-X0100 VALVE-SOLENOID DOWN SHIFT 31722-X0100 PLATE-SIDE,B 08360-51012 SCREW 31762-X0100 SPRING-1,2 SHIFT 31761-X0100 VALVE-1,2 SHIFT 31771-X0410 PLUG-2,3 SHIFT 31772-X0100 SPRING-2,3 SHIFT 31766-X0100 VALVE-2,3 SHIFT 31752-X0100 SPRING-PRESSURE MODIFIER 31751-X0100 VALVE-PRESSURE MODIFIER 31721-X0101 PLATE-SIDE,A 08360-51012 SCREW 31715-X0100 PLATE-SEPARATOR 31713-X0100 BODY-LOWER,CONTROL VALVE 31822-X0100 SPRING-ORIFICE CHECK 31823-X0100 VALVE-ORIFICE CHECK 32720-36900 BALL-STEEL (6.35) 31802-X0100 SPRING-THROTTLE RELIEF 08360-62512 SCREW 31728-X0100 ASSY-STRAINER,OIL 08360-54012 SCREW 1 31716-X0100 BOLT 08911-10610 NUT 08160-62500 BOLT 08160-63510 BOLT 08160-64010 BOLT 31918-H0101 ASSY-SWITCH,INHIBITOR 31918-H0100 ASSY-SWITCH,INHIBITOR 31918-X0100 ASSY-SWITCH,INHIBITOR (NILES) 31918-X0101 ASSY-SWITCH,INHIBITOR (NATIONAL) 31919-X0101 GASKET-INHIBITOR SWITCH 31916-X0100 SEAL-O RING (16S) 08160-61610 BOLT 08160-62010 BOLT 31931-H0101 ASSY-DIAPHRAGM,VACUUM 31932-X0101 ROD-DIAPHRAGM, L=31 31932-X0104 ROD-DIAPHRAGM, L=29.5 31932-X0103 ROD-DIAPHRAGM, L=29 31932-X0102 ROD-DIAPHRAGM, L=30.5 31932-X0100 ROD-DIAPHRAGM, L=30 31933-X0100 SEAL-O RING (26S) 31941-X0102 ASSY-SOLENOID,DOWN SHIFT 31941-X0101 ASSY-SOLENOID,DOWN SHIFT 31981-E8000 SUPPORT-PARKING ACTUATOR 31983-E8000 PLATE-RETAINING,PARKING 31985-E8000 SPRING-BALL,PARKING 31984-E8000 RETAINER-SPRING,PARKING 31357-20300 BALL-STEEL (8.731) 01125-00021 BOLT 31986-20300 SHAFT-PARKING PAWL 31991-E8000 PAWL-PARKING 31988-E8000 SPRING-RETURN PAWL 31987-E8000 SPACER-PARKING PAWL 40018-18000 COLLAR-SPINDLE FRONT 08114-06510 NUT-LOCK FRONT WHEEL BEARING 40264-18000 WASHER-LOCK FRONT WHEEL BEARING 40052-H1000 ARM-KNUCKLE RH 40052-H5000 ARM-KNUCKLE RM 40053-H1000 ARM-KNUCKLE LH 40053-H5000 ARM-KNUCKLE LH 40056-H1000 BOLT-KNUCKLE ARM 38MM 40055-H1000 BOLT-KNUCKLE ARM 44MM 40055-H1000 BOLT-KNUCKLE ARM 44MM 08911-64010 NUT-HEX M10X1.25 08915-14010 WASHER-SPRING M10 40038-H1000 BOLT-STEERING STOPPER 08911-34010 NUT-HEX M10 40160-H1000 ASSY-BALL JOINT LOWER 40189-73000 PLUG-FILLER 40192-H1000 COVER-DUST LOWER 40146-18000 CLAMP-DUST COVER 08911-84210 NUT-HEX SLOTTED M12X1.25 08921-32010 PIN-COTTER 40178-H1000 BOLT-FIXING BALL JOINT A 40179-H1000 BOLT-FIXING BALL JOINT B 08911-60810 NUT-HEX M8X1.25 08915-13810 WASHER-SPRING LOCK 40202-18051 ASSY-HUB ROAD WHELL FRONT 40202-H1005 ASSY-HUB ROAD WHELL FRONT FOR DISC BRA 40222-22001 BOLT-HUB ROAD WHEEL 40210-H1000 ASSY-BEARING FRONT WHEEL INNER 40210-18000 ASSY-BEARING FRONT WHEEL INNER 40215-18000 ASSY-BEARING FRONT WHEEL OUTER 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER 40232-18000 SEAL-GREASE FRONT HUB 40234-18000 CAP-HUB FRONT 40206-18003 DRUM-BRAKE 40206-H1006 ROTOR-BRAKE DISC FRONT 40209-H1005 BOLT FIX ROTOR FRONT 40300-H1001 ASSY-ROAD WHEEL 4JX12 40310-H1140 SET-TIRE & TUBE 155SR 12 RADIAL 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL EMVSS 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS 40312-H1922 TIRE 6.00-12-4PR FMVSS 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WHITE EMVSS 40315-H1100 COVER-ROAD WHEEL 40315-H1800 COVER-ROAD WHEEL 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) 40225-27700 NUT-ROAD WHELL 1 40325-H1000 WEIGHT 50G WHEEL BALANCE 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED
