14035 is Nissan Part Numbers type for GASKET-MANIFOLD TO CYLINDER HEAD. Identification includes intake port size, and whether it is a "dry" or "wet" type (if there are any water passages in the gasket).
Round Port
Oval Ports
All oval port manifolds use the new-type bolt pattern.
Small Oval Port
1974 A13 engine * 28x30 intake port size * Dry type (no water ports on manifold face of head) 14035-H6200
Medium Oval Port
EFI Heads (A14E, A15E) * 28x32 mm intake ports with notch for injector * Wet type (has intake manifold water ports) 14035-H9201
Regular Oval Port
For A15 and most A14 engines. * 28x34 mm intake ports
* Dry type (no intake manifold water ports) 14035-H7200 -7906 11044-H7201 14035-H7210 [alternate supplier] 14035-H7400 7906-
11044-H7860
* Wet type (has intake manifold water ports) 14035-H8901
Large Oval Port
For A12GX Engine and A12T engines * Port size 30x36 mm * Wet type (has intake manifold water ports) 14035-H2300
