14035 is Nissan Part Numbers type for GASKET-MANIFOLD TO CYLINDER HEAD. Identification includes intake port size, and whether it is a "dry" or "wet" type (if there are any water passages in the gasket).
Round Port
Dry Type
180
180 was parts originally designed for Datsun 1000.
* Dry type * Original style bolt pattern 14035-18000
H10
H10 was parts originally designed for Datsun 1200.
* Dry * Original style bolt pattern 11044-H1000 GASKET-cylinder head [no O-ring] 11044-H1000 GASKET-cylinder head (from '72-5) [can use on earlier head] * 11045-H1000 RING-"O" (from '72-5)
M30
* Dry Intake * New type bolt pattern 11041-M3000
H74
* New type bolt pattern * Dry type 14035-H7400 A14 Van 7906-, A12 B120 -8109 14035-H7410 8110- A12 B120
Wet Type
G61
Late model A12 (from Oct 1989) * New Type Bolt Pattern * Wet Intake 14035-H8501 -9111 14035-H8511 9111-
Oval Ports
All oval port manifolds use the new-type bolt pattern.
H23
For A12GX Engine and A12T engines * Port size 30x36 mm (Large Oval Port) * Wet type (has intake manifold water ports) 14035-H2300![]()
H62
1974 A13 engine * 28x30 intake port size * Partial-siamese intake ports * Dry type (no water ports on manifold face of head) 14035-H6200
H72
For A15 and most A14 engines from introduction 1974 to 1979 * 28x34 mm intake ports (Regular Oval Port) * Dry type (no intake manifold water ports) 14035-H7200 -7906 11044-H7201 14035-H7210 [alternate supplier]![]()
H78
11044-H7860
H89
* Wet type (has intake manifold water ports) 14035-H8901
H92
EFI Heads (A14E, A15E) * 28x32 mm intake ports (medium oval) with notch for injector * Wet type (has intake manifold water ports) 14035-H9201
