14035 is Nissan Part Numbers type for GASKET-MANIFOLD TO CYLINDER HEAD. Identification includes intake port size, and whether it is a "dry" or "wet" type (if there are any water passages in the gasket).
Round Port
180
180 was parts originally designed for Datsun 1000, so thus A10 engines. This manifold gasket was also used by A12 engines for B110 and E10, and B210.
* Dry type * Original style bolt pattern 14035-18000 -7909 14035-18010 [alternate manufacturer] superceeded by 14035-K7700 $12.58 USD![]()
H74
Used by newer A12S (1976?) and A14 Van engines. * New type bolt pattern * Dry type 14035-H7400 7908-8109 superceeded by 14035-H7401 $13.82 14035-H7410 8110-![]()
H85
Late model A12, A14 KFU, A15 KFU (see FU Engine) * Round port * New Type Bolt Pattern * Wet Intake 14035-H8501 B120 -9111, B310 USA 0879-0780 KFU A14/A15 $12.58 USD 14035-H8511 B120 9111-also available aftermarket PN MS15316
Oval Ports
All oval port manifolds use the new-type bolt pattern.
H23
For A12GX Engine and A12T engines * Original bolt pattern * Port size 30x36 mm (Large Oval Port) * Wet type (has intake manifold water ports) 14035-H2300 14035-H2301Nismo competition gasket:
Even-larger ports competition gasket:
Also made in non-original bolt pattern:
H62
1974 A13 engine * 28x30 intake port size * Partial-siamese intake ports * Dry type (no water ports on manifold face of head) 14035-H6200 $4.87 USD Or you can use 14035-H7200 instead
H72
For A15 and most A14 engines from introduction 1974 to 1979 * 28x34 mm intake ports (Regular Oval Port) * Dry type (no intake manifold water ports) 14035-H7200 -7906 $12.35 USD 14035-H7210 [alternate supplier]![]()
M24
A14T from late B210 * regular size oval ports * difference from 14035-H7200 unknown 14035-M2401
H89
* Wet type (has intake manifold water ports) 14035-H8901 superseded by 14035-05H01 $25.20 USD![]()
H92
EFI Heads (A14E, A15E) * 28x32 mm intake ports (medium oval) with notch for injector * Wet type (has intake manifold water ports) 14035-H9201
EXマニフォールド INマニフォールド ガスケット
