For an overview of electric vehicle conversions for Datsun 1200, see Electric. Follows is one way to do it
Motor
8" DC motor Adapter plate to stock transmission (Optional: Use 60-series four speed for more durability) Aluminum spacer for Datsun crank adapter to bolt the stock flywheel
Mounting
Aluminum mount with Ford engine mounts * Purchase Ready-made for 8" motor
Battery Pack
128 Volt pack 40 Thundersky lithium ion 60ah batteries. $3000 * 128V pack (40 individual batteries) * Weight: 300 lbs Battery pack straps *Tin-plate copper battery interconnects Inter-cell regulators
Mounting
Aluminum pack brackets/carrier frame * can fit above engine subframe rails, fairly simple * or in ute bed with simple bolted down rectangle box * or under ute bed with careful fabrication of carrier * Must prevent upward movement * Must prevent sideways movement
Control
Use the stock Datsun 1200 accelerator pedal Use the stock 1200 throttle cable Connect it to the controller 'pot box'
Optional
Room Heater
Electric Heater Core: 108-156 VDC, 1500 watts $104.50 * Direct replacement for your vehicle's original heater core * Not cheap, but very warm for cold, damp climates High voltage relay
Gauges
Driver's Gauges: Voltmeter, etc. *:![]()
