The Hitachi D4R80 electronic distributor is used by the early E-series engines (e.g. B11 Sentra USA). Can these be modified to work in A-series engines? Probably as other E-series distributors have been used. The later Hitachi D4R823 is used by later E-series engines (N12 Australia) and can be modified for A-series engine. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior Ignition Unit![]()
Older Exterior Matchbox (Hitachi D4K)![]()
22162-15M01 CAP ASSY-DISTRIBUTOR N10 E15S USA, N12 E16S USA, B11 E15S+E16S 22157-H9560 ROTOR-HEAD 22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-21M00, 22136-D4700 PLATE ASSY-BREAKER 22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00 SHAFT ASSY [weight & spring shaft] 22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
