Alloy Gear Carrier
From Datsun 1200 Club
<-- back to H145
B10 Datsun 1000 came with a light alloy version of the H145 differential.
Only 9kg
174_6836aedd80d4c.jpgPost 498967
The alloy carrier is weaker (less able to handle the torque) but is lighter at only 9kg, thus keeping unsprung weight down — a perfect part for the lightweight Datsun Sunny 1000.
B10 4.111 (37:9) sedan & coupe
B10 4.375 (35:8) van
B20 4.625 (37:8) truck
  • All use the same #Gear Carrier
  • The bearing cap fit over studs and are secured with nuts, compared to the B110 cast iron H145 which uses bolts
  • Instead of the inexpensive crush sleeve that the cast iron H145 uses, the alloy unit uses reusable shims for side bearing preload
Distinguishing feature: studs fasten the bearing caps (cast iron carriers use bolts)
174_6836af35b1f4d.jpgPost 498967
'37 X 9' stamping indicates 4.111 gear ratio (37/9), as used by B10 sedan and Coupe
174_68328e429eef0.jpgPost 498964
Carrier Assembly
The Carrier Assembly, also called the diff center or 3rd-member 'pumpkin', comprises the #Gear Carrier with differential gear case and gearset installed.
174_68328e0d0b72d.jpgPost 498964 174_68328f3502e2c.jpgPost 498964 174_68328e2dc4204.jpgPost 498964 174_68328e3482e9e.jpgPost 498964 174_68328e3971682.jpgPost 498964
Gear Carrier
B10 Datsun 1000 H145 alloy carrier
38310-18000 COMP.-CARRIER, gear ALL
fixing differential bearing cap (4 used)
* 38315-18000 STUD
* 38317-18000 WASHER
* 38318-18000 NUT
174_5a571822c5c90.jpgPost 487200 174_5a5718154210c.jpgPost 487200 174_5a571936ec216.jpgPost 487200 174_5a5719785083e.jpgPost 487200 174_5a57199f40cdd.jpgPost 487200 174_5a5719d3b71bb.jpgPost 487200
The gasket face is 86mm Outside Diameter
174_5a571a03aab7f.jpgPost 487200
GEAR CARRIER & GEAR
174_683288a979ecf.jpgPost 498963
   38300-18000 ASS'Y-CARRIER, with gear (37 T : 9 T) Sedan & Coupe
   38300-18100 ASS'Y-CARRIER, with gear  (35 T , 8 T) Van <  38300-H0700
   38300-H0700 ASS'Y-CARRIER, with geer (35 T : & T) Van
   38300-15400 ASS'Y-CARRIER, with gear (37 T : 8 T) Truck < 38300-G0500
   38300-G0500 ASS'Y-CARRIER, with gear (37 T : 8 T) Truck
1    38310-18000 COMP.- CARRIER, gear 4
2      38315-18000 STUD 4
3      38317-18000 WASHER 4
4      30318-18000 NUT 4
5    38100-18000 SET-GEAR. hypoid with pinion (37 T : 9 T) Sedan & Coupe
     38100-18100 SET-GEAR, hypoid with pinion (35 T : 8 T) Van
     38100-H0700 SET-GEAR, hypoid with pinion (35 T : 8 T) Van
     38100-15400 SET-GEAR, hypoid with pinion (37 T : 8 T) Truck
     38100-G0400 SET-GEAR, hypoid with pinion (37 T : 8 T) Truck (from '69-Nov.) <x> 38100-15400
6    38102-18000 BOLT-drive gear 8
     38102-18100 BOLT-drive gear 8 <> 38102-18000
7    38103-18000 STRAP-lock bolt 8
     38103-18001 STRAP-lock bolt 4 <> 38103-18000
     38103-18100 STRAP-lock bolt 4 <> 38103-18001
8    38421-18001 CASE-differential gear
9    38423-10000 GEAR-side, differential bevel 2
10   as required
     38424-18000 WASHER-thrust, side gear
     38424-18001 WASHER-thrust, side gear
     38424-18002 WASHER-thrust, side gear
11   38425-18000 MATE-pinion, differential bevel 2
12   33426-18000 WASHER-thrust, pinion mate 2
13   38427-18000 SHAFT-pinion mate
14   38428-18000 PIN-lock, pinion shaft
15   38440-14361 ASS'Y-BEARING, differential side 2
16   as required
     38453-18000 SHIM-adjusting, drive gear (0.05 T)
     38454-18000 SHIM-adjusting, drive gear (0.075 T)
     38455-18000 SHIM-adjusting, drive gear (0.125 T)
     38456-18000 SHIM-adjusting, drive gear (0.25 T)
     38457-18000 SHIM-odjusting, drive gear (0.5 T)
17   38120-18000 ASS'Y-BEARING, drive pinion, rear
18   38140-18000 ASS'Y-BEARING, drive pinion, front
19   as required
     38125-18000 WASHER-adjusting, drive pinion bearing
     38126-18000 WASHER-adjusting, drive pinion bearing
     38127-18000 WASHER-adjusting, drive pinion bearing
     38128-18000 WASHER-adjusting, drive pinion bearing
     38129-18000 WASHER-adjusting, drive pinion bearing
     38130-18000 WASHER-adjusting, drive pinion bearing
     38131-18000 WASHER-adjusting, drive pinion bearing
     38132-18000 WASHER-adjusting, drive pinion bearing
     38133-18000 WASHER-adjusting, drive pinion bearing
     38134-18000 WASHER-adjusting, drive pinion bearing
     38135-18000 WASHER-adjusting, drive pinion bearing
     38136-18000 WASHER-adjusting, drive pinion bearing
     38137-18000 WASHER-adjusting, drive pinion bearing
     38138-18000 WASHER-adjusting, drive pinion bearing
     38139-18000 WASHER-adjusting, drive pinion bearing
20   as required
     38165-18000 SPACER-drive pinion bearing
     38166-18000 SPACER-drive pinion bearing
     38167-18000 SPACER-drive pinion bearing
21   38153-18000 SHIM-adjusting, drive pinion (0.05 T)
     38134-18000 SHIM-adjusting, drive pinion (0.075 T)
     38155-18000 SHIM-adjusting, drive pinion (0.125 T)
     38156-18000 SHIM-adjusting, drive pinion (0.25 T)
     38157-18000 SHIM-adjusting, drive pinion (0.5 T)
     38189-18000 SEAL-oil, drive pinion
22   38189-18000 SEAL-oil, drive pinion
23   38210-18000 ASS'Y-FLANGE, companion & dust shield
     38210-18001 ASS'Y-FLANGE, companion & dust shield <> 38210-18000
24   38215-01300 WASHER-plain
25   38216-18000 NUT-drive pinion
26   38320-18000 GASKET-gear carrier
     38320-18010 GASKET-gear carrier <> 38320-18000
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Alloy_Gear_Carrier"
This page has been accessed 335 times. This page was last modified 07:07, 28 May 2025. Content is available under Datsun 1200 Club.
