Automatic Transmission Gear Part Numbers
From Datsun 1200 Club
Categories: Automatic Transmission | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
 1 31411-X0100 SHAFT-INPUT 3N71B
 2 31440-X0100 ASSY-CARRIER,REAR PLANET 3N71B
 3 31436-X0100 RACE-BEARING,NEEDLE THRUST 3N71B
 4 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B
 5 31477-X0100 RING-SNAP (116B) 3N71B
 6 31460-X0100 ASSY-GEAR,SUN 3N71B
 7 31465-X0100 SHELL-CONNECTING 3N71B
 8 31466-X0100 RACE-BEARING,CONNECTING SHELL 3N71B
 9 31467-X0100 RING-SNAP (47S) (2) 3N71B
10 31420-X0100 ASSY-CARRIER,FRONT PLANET 3N71B
11 31428-X0100 BEARING-NEEDLE THRUST (3047) 3N71B
12 31436-X0100 RACE-BEARING,PLANET CARRIER 3N71B
13 31431-X0100 GEAR-INTERNAL 3N71B
14 31553-X0100 HUB-REAR CLUTCH 3N71B
15 31433-X0100 RING-SNAP (99B) 3N71B
16 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B
17 31438-X0100 BEARING-NEEDLE THRUST (3553) 3N71B
18 31431-X0100 GEAR-INTERNAL 3N71B
19 31452-X0100 FLANGE-INTERNAL DRIVE 3N71B
20 31433-X0100 RING-SNAP (99B) 3N71B
21 31428-X0100 BEARING-NEEDLE THRUST (3047) 3N71B
22 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B
23 00922-12800 RING-SNAP (28) 3N71B
24 31471-X0100 DRUM-CONNECTING 3N71B
25 31475-X0100 RACE-OUTER,ONE WAY CLUTCH 3N71B
26 31476-X0100 RING-SNAP (92B) 3N71B
27 31473-X0100 ASSY-CLUTCH,ONE WAY 3N71B
28 31479-X0100 RING-SNAP (71B) (2) 3N71B
29 31376-X0100 RING-SNAP (134) 3N71B
30 31667-X0104 PLATE-RETAINING, T=16.6 3N71B
30 31667-X0105 PLATE-RETAINING, T=16.8 3N71B
30 31667-X0103 PLATE-RETAINING, T=16.4 3N71B
30 31667-X0102 PLATE-RETAINING, T=16.2 3N71B
30 31667-X0101 PLATE-RETAINING, T=16.0 3N71B
30 31667-X0100 PLATE-RETAINING, T=15.8 3N71B
31 31662-X0100 ASSY-PLATE,ORIVE (130) (3) 3N71B
32 31666-X0100 PLATE-DRIVEN (130) 3N71B
33 31668-X0100 PLATE-DISHED (130) 3N71B
34 31652-X0101 RING-SNAP (56S) 3N71B
35 31651-X0100 SPRING-PISTON RETURN 3N71B
35 31651-X0101 SPRING-PISTON RETURN 3N71B 2 31651-X0100
36 31648-X0100 RING-THRUST SPRING 3N71B
37 31647-X0100 SEAL-O RING (56D) 3N71B
38 31646-X0100 SEAL-LATHE CUT RING (132D) 3N71B
39 31645-X0100 PISTON-LOW & REVERSE BRAKE 3N71B
40 31438-X0100 BEARING-NEEDLE THRUST (3553) 3N71B
41 31489-X0100 RACE-BEARING,DISTRIBUTOR 3N71B
42 31480-X0100 ASSY-SHAFT,OUTPUT 3N71B
43 31486-X0100 ASSY-DISTRIBUTOR,OIL 3N71B
44 31487-X0100 RING-SEAL (62) (3) 3N71B
45 31860-X0410 ASSY-GOVERNOR 3N71B
46 31862-X0100 VALVE-PRIMARY GOVERNOR 3N71B
47 31863-X0100 SPRING-PRIMARY GOVERNOR 3N71B
48 31872-X0410 VALVE-SECONDARY GOVERNOR (35) 3N71B
49 31873-X0100 SPRING-SECONDARY GOVERNOR 3N71B
50 31864-X0100 PLATE-RETAINER (3) 3N71B
51 08160-61610 BOLT (4) 3N71B
1973 LB110 USA Parts Catalog, page 55B-1
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Automatic_Transmission_Gear_Part_Numbers"
This page has been accessed 6,907 times. This page was last modified 06:04, 27 February 2017. Content is available under Datsun 1200 Club.
