Automatic Transmission Hardware Part Numbers
From Datsun 1200 Club
Categories: Automatic Transmission | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
 1 31340-X0100 ASSY-PUMP,OIL 3N71B
   31340-X0101 ASSY-PUM.OIL 3N71B 2 31340-X0100
 2 31341-X0100 ASSY-HOUSING,OIL PUMP 3N71B
 3 31344-X0100 SEAL-HOUSING 3N71B
 4 31346-X0102 GEAR-INNER,OIL PUMP 3N71B
   31346-X0100 GEAR-INNER,OIL PUMP 3N71B
   31346-X0101 GEAR-INNER,OIL PUMP 3N71B
 5 31347-X0100 GEAR-OUTER,OIL PUMP 3N71B
   31347-X0101 GEAR-OUTER,OIL PUMP 3N71B
   31347-X0102 GEAR-OUTER,OIL PUMP 3N71B
 6 31350-X0100 ASSY-COVER,OIL PUMP 3N71B
   31350-X0101 ASSY-COVER,OIL PUMP 3N71B 2 31350-X0100
 7 31361-X0100 RING-SEAL (44) (2) 3N71B
 8 31362-X0100 RING-SEAL (43) (2) 3N71B
 9 08120-61810 BOLT (5) 3N71B
10 31363-X0100 SEAL-LATHE CUT RING (200D) 3N71B
11 31366-X0100 GASKET-OIL PUMP 3N71B
12 31556-X0102 RACE-BEARING,PUMP COVER, T=1.6 3N71B
12 31556-X0105 RACE-BEARING,PUMP COVER, T=2.2 3N71B
12 31556-X0103 RACE-BEARING,PUMP COVER, T=1.8 3N71B
12 31556-X0100 RACE-BEARING,PUMP COVER, T=1.2 3N71B
12 31556-X0104 RACE-BEARING,PUMP COVER, T=2.0 3N71B
12 31556-X0101 RACE-BEARING,PUMP COVER, T=1.4 3N71B
13 31528-X0100 WASHER-THRUST, T=1.9 3N71B
13 31528-X0101 WASHER-THRUST, T=2.1 3N71B
13 31528-X0102 WASHER-THRUST, T=2.3 3N71B
13 31528-X0103 WASHER-THRUST, T=2.5 3N71B
13 31528-X0104 WASHER-THRUST, T=2.7 3N71B
13 31528-X0105 WASHER-THRUST, T=1.7 3N71B
13 31528-X0106 WASHER-THRUST, T=1.5 3N71B
14 31540-X0100 ASSY-CLUTCH,REAR 3N71B
15 31542-X0100 DRUM-REAR CLUTCH 3N71B
16 31517-X0100 SEAL-O RING (54D) 3N71B
17 31514-X0102 ASSY-PISTON,CLUTCH 3N71B 1272- 2 31514-X0101
17 31514-X0101 ASSY-PISTON,CLUTCH 3N71B
18 31516-X0100 SEAL-LATHE CUT RING (116D) 3N71B
19 31521-X0100 SPRING-PISTON RETURN 1 (10) 3N71B
20 31552-X0100 RETAINER SPRING 3N71B
20 31552-X0102 RETAINER-SPRING 3N71B 1272- 2 31552-X0100
21 31523-X0100 RING-SNAP (54S) 3N71B
22 31529-X0100 PLATE-DISHED (115) 3N71B
23 31536-X0100 PLATE-DRIVEN (115) (3) 3N71B
24 31532-X0100 ASSY-PLATE,DRIVE (115) (3) 3N71B
25 31567-X0100 PLATE-RETAINING (115) 3N71B
26 31538-X0100 RING-SNAP (118) 3N71B
27 31439-X0100 RACE-BEARING,REAR CLUTCH DRUM 3N71B
28 31555-X0100 BEARING-NEEDLE THRUST (2035) 3N71B
29 31510-X0100 ASSY-CLUTCH,FRONT 3N71B
30 31511-X0100 ASSY-DRUM,FRONT CLUTCH 3N71B
31 31517-X0100 SEAL-O RING (54D) 3N71B
32 31514-X0101 ASSY-PISTON,CLUTCH 3N71B
32 31514-X0102 ASSY-PISTON,CLUTCH 3N71B 1272- 2 31514-X0101
33 31516-X0100 SEAL-LATHE CUT RING (116D) 3N71B
34 31521-X0100 SPRING-PISTON RETURN 1 (10) 3N71B
35 31552-X0100 RETAINER-SPRING 3N71B
35 31552-X0102 RETAINER-SPRING 3N71B 1272- 2 31552-X0100
36 31523-X0100 RING-SNAP (54S) 3N71B
37 31529-X0100 PLATE-DISHED 3N71B
38 31536-X0100 PLATE-DRIVEN (115) (3) 3N71B
39 31532-X0100 ASSY-PLATE,DRIVE (115) (3) 3N71B
40 31537-X0102 PLATE-RETAINING, T=11.0 3N71B
40 31537-X0105 PLATE-RETAINING, T=11.6 3N71B
40 31537-X0103 PLATE-RETAINING, T=11.2 3N71B
40 31537-X0101 PLATE-RETAINING, T=10.8 3N71B
40 31537-X0100 PLATE-RETAINING, T=10.6 3N71B
40 31537-X0104 PLATE-RETAINING, T=11.4 3N71B
41 31538-X0100 RING-SNAP (118B) 3N71B
42 31630-X0100 ASSY-BAND,BRAKE 3N71B
43 31624-X0100 STRUT-BAND 3N71B
44 31621-X0100 SPRING-PISTON RETURN (10KG) 3N71B
45 31615-X0100 PISTON-BAND SERVO (64-44) 3N71B
46 31611-X0100 RETAINER-SERVO (64-44) 3N71B
47 31616-X0100 SEAL-LATHE CUT RING (64D) 3N71B
48 31617-X0100 SEAL-LATHE CUT RING (44D) 3N71B
49 31628-X0100 SEAL-O RING (82S) 3N71B
50 31612-X0100 SEAL-LATHE CUT RING (80D) 3N71B
51 31618-X0101 STEM-BAND SERVO PISTON 3N71B 2 31618-X0100
51 31618-X0100 STEM-BAND SERVO PISTON 3N71B
52 31619-X0100 WASHER-STEM 3N71B 2 08915-44200
52 08915-44200 WASHER-PLAIN 3N71B
53 08540-70810 NUT 3N71B
54 08160-61610 BOLT (3) 3N71B
1973 LB110 USA Parts Catalog, page 55C-1
55 31532-X0125 KIT-CLUTCH REPAIR AUTO TRANS 3N71B
1973 LB110 USA Parts Catalog, page 55C-2
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Automatic_Transmission_Hardware_Part_Numbers"
This page has been accessed 7,290 times. This page was last modified 05:01, 4 September 2017. Content is available under Datsun 1200 Club.
