Coupe Fuel Tank Part Numbers
From Datsun 1200 Club
Categories: Fuel System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Coupe Fuel Tank
Standard
  17201-H1802 ASSY-TANK FUEL 38L COUPE 17201-H1801
1 17201-H1801 ASSY-TANK FUEL 38L COUPE
2 17342-18000 RING-O COUPE
3 17343-H1001 PLATE-LOCK COUPE
3 17343-14801 PLATE-LOCK COUPE 2 17343-H1001
4 25060-H1800 GAUGE-FUEL TANK COUPE
5 17312-P0102 PACKING-DRAIN COUPE 2 17312-P0101
5 17312-14800 PACKING-DRAIN COUPE
5 17312-H1000 PACKING-DRAIN COUPE 2 17312-14800
5 17312-P0101 PACKING-DRAIN COUPE 2 17312-H1000
6 17310-P0100 PLUG-DRAIN COUPE 2 17310-H1000
6 08931-44210 PLUG-DRAIN, M12 hex head parallel thread
6 17310-H1000 PLUG-DRAIN COUPE 2 08931-44210
7 17251-H1900 CAP-FILLER COUPE
7 17251-H1000 CAP-FILLER COUPE 2 17251-H1900
8 17264-18000 PACKING COUPE
9 17220-H1801 TUBE-FILLER COUPE
10 17222-H1000 NECK-FILLER COUPE
11 17221-H1000 PACKING FILLER NECK COUPE
12 08310-40812 SCREW-MACHIN (3) COUPE
13 17229-H1801 HOSE-FILLER
14 17228-H1400 GROMMET
15 08723-15800 CLAMP-HOSE (2)
16 A7325-H1000 TUBE(10X14DX5M)
17 08723-11400 CLAMP-HOSE (2) COUPE
17 16439-22100 CLAMP-HOSE (2) COUPE 2 08723-11400
18 17335-H1800 TUBE COUPE
19 17324-H1400 GROMMET COUPE
20 17334-H1801 CLIP COUPE 2 17310-H1000
21 08510-51012 SCREW COUPE
22 77700-89915 PLUG-RUBBER 30 COUPE
23 08110-82062 BOLT-WITH LOCK WASHER (5) COUPE
24 08915-53810 WASHER-PLAIN (5) COUPE
25 74890-H1800 PROTECTOR-FILLER HOSE COUPE
26 08110-62010 BOLT FIXING PROTECTOR (3) COUPE
27 08915-23610 WASHER FIXING PROTECTOR (3) COUPE
28 08915-43610 WASHER FIXING PROTECTOR (3) COUPE
1973 LB110 USA Parts Catalog
Evapo
1 17201-H1802 ASSY-TANK FUEL 38L COUPE EVAPO
2 17342-18000 RING-"O" COUPE
6 08931-44210 PLUG-DRAIN COUPE
7 17251-H1902 CAP-FILLER COUPE EVAPO 0173- 2 17251-H1901
7 17251-H1000 CAP-FILLER COUPE EVAPO 0470- 6 17251-H1900
7 17251-H1901 CAP-FILLER COUPE EVAPO 0672- 2 17251-H1000
9 17220-H1802 HOSE-FILLER UPPER COUPE EVAPO
9 17220-H1803 HOSE-FILLER UPPER COUPE EVAPO 0470- 0 17220-H1802
13 17229-H1802 HOSE-FILLER COUPE EVAPO
14 17228-H1400 GROMMET COUPE
15 08723-15800 CLAMP-HOSE (2) COUPE
16 17230-H1802 HOSE-FILLER INNER COUPE EVAPO 2 17230-H1801
16 17230-H1801 HOSE-FILLER 2ND(NOT ADOPTED) COUPE EVAPO
17 08723-13600 CLAMP-HOSE COUPE EVAPO
18 A7325-H1000 TUBE-VINYLE(10X14DX5M) COUPE
18 A7515-H1900 TUBE-RUBBER(10X16DX5M) COUPE EVAPO
18 08742-20040 TUBE-RUBBER COUPE EVAPO 2 A7515-H1900
19 16439-22100 CLAMP-HOSE (2) COUPE 2 08723-11400
19 08723-11400 CLAMP-HOSE (2) COUPE
20 17324-H1800 GROMMET COUPE EVAPO
21 08110-82062 BOLT WITH LOCK WASHER (5) COUPE
22 08915-53810 WASHER-PLAIN (5) COUPE
23 17350-H1801 ASSY-TANK RESERVOIR COUPE EVAPO
23 17350-H1802 ASSY-TANK RESERVOIR COUPE EVAPO 0470- 0 17350-H1801
24 63140-78500 NUT-JAM (3) COUPE EVAPO
25 08410-61610 SCREW (3) COUPE EVAPO
26 08915-13610 WASHER-LOCK (3) COUPE EVAPO
27 17335-H1801 TUBE-BREATHER RH COUPE EVAPO
27 17335-H1802 CONNECTOR (2) COUPE EVAPO 0470- 0 17335-H1801
28 17336-H1801 TUBE-BREATHER LH COUPE EVAPO
29 17515-H1817 HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L COUPE EVAPO 2 17230-H1801
29 A7515-H1800 HOSE-FUEL(6X13.5X5M) COUPE EVAPO
29 08742-20020 HOSE-FUEL(6X13.5X2200MM) COUPE EVAPO
29 A7515-H1800 HOSE-FUEL(6X13.5X10M) COUPE EVAPO 0470-
29 08742-20020 HOSE-FUEL(6X13.5X2200MM) COUPE EVAPO 2 17230-H1801
29 08742-20020 HOSE-FUEL (6X13.5X2.2M) COUPE EVAPO 2 A7515-20020
30 16439-22100 CLAMP-HOSE 1 (16) COUPE EVAPO 2 68723-11400
30 08723-11400 CLAMP-HOSE 1 (16) COUPE EVAPO
31 17351-H1800 CONNECTOR-3 WAY COUPE EVAPO 0470-
31 17351-H1801 CONNECTOR-3WAY COUPE EVAPO 2 17351-H1801
32 17361-H1800 TUBE-EVAPORATION COUPE EVAPO MANUAL
32 17361-H1801 TUBE-EVAPORATION COUPE EVAPO MANUAL 0 17361-H1800
33 24251-H1801 GROMMET COUPE EVAPO
34 00951-10600 GROMMET (2) COUPE EVAPO
35 00951-11000 GROMMET (4) COUPE EVAPO
36 00951-11200 GROMMET (2) COUPE EVAPO 0470-
37 46115-C0400 GROMMET (2) COUPE EVAPO 0470-
38 17337-H1800 PROTECTOR-FUEL HOSE COUPE EVAPO 0470-
39 24210-89964 CLIP COUPE EVAPO 0470-
40 74890-H1800 PROTECTOR-FILLER HOSE COUPE EVAPO
41 08110-62010 BOLT FIXING PROTECTOR (3) COUPE EVAPO
42 08915-23610 WASHER FIXING PROTECTOR (3) COUPE EVAPO
43 08915-43610 WASHER FIXING PROTECTOR (3) COUPE EVAPO
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Coupe_Fuel_Tank_Part_Numbers"
This page has been accessed 7,075 times. This page was last modified 06:39, 10 May 2023. Content is available under Datsun 1200 Club.
