Door Hinge
From Datsun 1200 Club
Category: Body
Front door hinges are all the same: Sedan/Coupe/Ute/Wagon.
Upper hinge: sheet metal
Lower hinge: cast metal
24317.jpgAlbum 24317 16784.jpgAlbum 16784
FRONT DOOR
Upper & Lower hinge differs
* Upper Left & Right hinge differ
* Lower is same on both sides
* 2-dr, 4-dr, truck/van/sedan/coupe all the same
Hinge Replacement
The hinges bolt to the cowl dash side panel, and the bolts are accessed from inside the passenger cabin. The bolts for the lower hinge can be accessed by removing the kick panel plug.
28828.jpgAlbum 28828
16783.jpgAlbum 16783 17027.jpgAlbum 17027 17028.jpgAlbum 17028
Hinge Repair
Door dropping down on its hinges?
24450.jpgAlbum 24450
NAPA Door Hinge Pin & Bushing Kit Balkamp 6755157
Pin Length: 2.85"
Pin Diameter: .313"
Bushing I.D.: 0.315"
Bushing O.D.: 0.397"
24451.jpgAlbum 24451
Motormite/Door Hinge Parts 38397
Tip: You will need to cut the pin to length
If you need the bushings, and the pin is still OK:
H0400-73002 BUSH-DOOR HINGE UPPER $2.53 USD
H0400-73002 BUSH-DOOR HINGE REAR DOOR UPPER & LOWER
H0402-H1001 BUSH-DOOR HINGE LOWER $1.29 USD
Also see: Datsun Door hinge repair from NWDE
ドア ヒンジ
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Door_Hinge"
This page has been accessed 15,997 times. This page was last modified 21:21, 20 May 2023. Content is available under Datsun 1200 Club.
