F5C56 Shifter Parts
From Datsun 1200 Club
Category: Transmission
<-- back to 56-Series Transmission Parts
See also: Shifter
STRIKING ROD fits into extension housing
27718.jpgAlbum 27718
Gearshift lever fits into GUIDE
27719.jpgAlbum 27719
See further breakdown below
Striking Rod
GUIDE with plug. After inserting the ROD, put the plug in
27722.pngAlbum 27722
17 32892-H7200 PLUG-checking ball 3
18 32896-H7200 LEVER-striking
19 32917-H7200 PIN-lock
20 08915-13610 WASHER-lock
21 08915-53610 WASHER-plain
22 08911-20610 NUT-hex
23 32850-H7200 GUIDE ASS'Y-striking rod
24 * 32845-24900  PIN-ret, striking rod 2
25 32857-14600 CAP-ring O
26 32858-14600 RING O, striking rod
30 00933-32800 PLUG-expansion
27720.jpgAlbum 27720
Shift Return Spring & Plunger
PLUNGER and RETURN SPRING fits into the extension housing
27723.pngAlbum 27723 27721.jpgAlbum 27721
31 32851-24900 PLUNGER-return spring
32 32852-24901 SPRING-return
33 32856-24901 SPRING-reverse check
34 32853-E9300 PLUG-return
Shift Rails
27725.pngAlbum 27725
Shift Lever
27726.pngAlbum 27726
Shift Arm Bracket
STRIKING LEVER has two pins & two nuts:
1. Fastens BRACKET to STRIKING LEVER
2. Fastens STRIKING LEVER to striking rod
174_5d86b16354e7a.jpgPost 492668
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=F5C56_Shifter_Parts"
This page has been accessed 3,416 times. This page was last modified 20:10, 14 May 2023. Content is available under Datsun 1200 Club.
