Front Door Fitting Part Numbers
From Datsun 1200 Club
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
* Window Regulator for Window Winder/Regulator Handle
* Door Lock (door latch and door handle)
Truck
Sedan
1 80500-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON SEDAN 2 DOOR
2 80501-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON SEDAN 2 DOOR
3 80502-H1201 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR
3 80502-H3600 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR
4 80503-H1201 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR
4 80503-H3600 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR
5 80504-H1001 ASSY-REMOTE CONTROL DOOR LOCK RH SEDAN 2 DOOR
6 80505-H1001 ASSY-REMOTE CONTROL DOOR LOCK LH SEDAN 2 DOOR
7 80508-H1000 SPRING-DOOR LOCK RH SEDAN 2 DOOR
8 80509-H1000 SPRING-DOOR LOCK LH SEDAN 2 DOOR
9 08320-61012 SCREW-MACHINE M6 TO FIX DOORLOCK (6) SEDAN 2 DOOR
10 08916-43610 WASHER-LOCK TOOTH (6) SEDAN 2 DOOR
11 08310-61214 SCREW-MACHINE WITH WASHER (4) SEDAN 2 DOOR
12 08915-43610 WASHER-PLAIN TO FIX REMOTE CONTROL (4) SEDAN 2 DOOR
13 80570-E6000 ASSY-STRIKER DOOR LOCK RH SEDAN 2 DOOR
14 80571-E6000 ASSY-STRIKER DOOR LOCK LH SEDAN 2 DOOR
15 80575-24800 SHIM-STRIKER DOOR LOCK (2) SEDAN 2 DOOR
16 80577-21000 BOLT-SPECIAL TO FIX STRIKER (6) SEDAN 2 DOOR
17 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH SEDAN 2 DOOR
18 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH SEDAN 2 DOOR
19 08330-50820 SCREW-MACHINE M5 TO FIX ESCUTCHEON (2) SEDAN 2 DOOR
20 80595-21003 KNOB-DOOR LOCK (2) SEDAN 2 DOOR
   80595-N1600 KNOB-DOOR LOCK (2) SEDAN,2 DOOR $10.42 USD
21 80970-A4600 GROMMET-LOCK KNOB (2) SEDAN 2 DOOR
   80970-21000 GROMMET-LOCK KNOB (2) SEDAN 2 DOOR
22 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH SEDAN 2 DOOR
22 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH SEDAN 2 DOOR 0371-
23 80606-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT LH SEDAN 2 DOOR
23 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH SEDAN 2 DOOR 0371-
24 80608-H1000 ASSY-ROD OUT SIDE HANDLE (2) SEDAN 2 DOOR
25 08915-13510 WASHER-SPRING LOCK (4) SEDAN 2 DOOR
26 08915-43510 WASHER-PLAIN M5 (4) SEDAN 2 DOOR
27 08911-10510 NUT-HEX M5 (4) SEDAN 2 DOOR
28 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR (2) SEDAN 2 DOOR
29 80675-H1000 WASHER-HANDLE (2) SEDAN 2 DOOR
30 08330-51220 SCREW-MACHINE (2) SEDAN 2 DOOR
31 80700-H1000 ASSY-REGULATOR DOOR WINDOW FRONT (2) SEDAN 2 DOOR
31 80700-H1001 ASSY-REGULATOR,DOOR WINDOW, FRONT (2) SEDAN 2 DOOR
32 80700-H1200 ASSY-REGULATOR DOOR WINDOW (2) SEDAN 2 DOOR 1070-
32 80700-H1201 ASSY-REGULATOR DOOR WINDOW (2) SEDAN 2 DOOR 0771-
33 08310-61012 SCREW-MACHINE (6) SEDAN 2 DOOR
34 08915-13610 WASHER-SPRING LOCK M6 (6) SEDAN 2 DOOR
35 84371-H1000 HOLDER-NYLON (2) SEDAN 2 DOOR
35 24220-H6200 HOLDER-NYLON (2) SEDAN 2 DOOR 0371-
Coupe
1 80500-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON COUPE
2 80501-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON COUPE
3 80502-H1201 ASSY-DOOR LOCK FRONT RH COUPE
3 80502-H3600 ASSY-DOOR LOCK FRONT RH COUPE 2 80502-H1201
4 80503-H1201 ASSY-DOOR LOCK FRONT LH COUPE
4 80503-H3600 ASSY-DOOR LOCK FRONT LH COUPE 0671- 2 80503-H1201
5 80504-H1001 ASSY-REMOTE CONTROL DOOR LOCK RH COUPE
6 80505-H1001 ASSY-REMOTE CONTROL DOOR LOCK LH COUPE
7 80508-H1000 SPRING-DOOR LOCK RH COUPE
8 80509-H1000 SPRING-DOOR LOCK LH COUPE
9 08320-61012 SCREW-MACHINE M6 TO FIX DOORLOCK (6) COUPE
10 08916-43610 WASHER LOCK TOOTH TO FIX DOOR LOCK (6) COUPE
11 08310-61214 SCREW-MACHINE WITH WASHER (4) COUPE
12 08915-43610 WASHER-PLAIN TO FIX REMOTE CONTROL (4) COUPE
13 80570-E6000 ASSY-STRIKER DOOR LOCK RH COUPE
14 80571-E6000 ASSY-STRIKER DOOR LOCK LH COUPE
15 80575-24800 SHIM-STRIKER DOOR LOCK (2) COUPE
16 80577-21000 BOLT-SPECIAL TO FIX STRIKER (6) COUPE
17 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH COUPE
18 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH COUPE
19 08330-50820 SCREW-MACHINE M5 TO FIX ESCUTCHEON (2) COUPE
20 80595-21003 KNOB-DOOR LOCK (2) COUPE
   80595-N1600 KNOB-DOOR LOCK (2) COUPE 2 80595-21003
21 80970-21000 GROMMET-LOCK KNOB (2) COUPE
22 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH COUPE
22 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH COUPE 0371- 2 80605-H1900
23 80606-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT LH COUPE
23 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH COUPE 0371- 2 80605-H1900
24 80608-H1000 ASSY-ROD OUT SIDE HANDLE (2) COUPE
25 08915-13510 WASHER-SPRING LOCK (4) COUPE
26 08915-43510 WASHER-PLAIN M5 (4) COUPE
27 08911-10510 NUT-HEX M5 (4) COUPE
28 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR (2) COUPE
29 80675-H1000 WASHER-HANDLE (2) COUPE
30 08330-51220 SCREW-MACHINE (2) COUPE
31 80700-H1800 ASSY-REGULATOR DOOR WINDOW RH COUPE
32 08310-61012 SCREW-MACHINE 1 (12) COUPE
33 08915-13610 WASHER-SPRING LOCK M6 1 (12) COUPE
34 80701-H1800 ASSY-REGULATOR DOOR WINDOW LH COUPE
35 08915-43610 WASHER-PLAIN M6 (4) COUPE
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Front_Door_Fitting_Part_Numbers"
This page has been accessed 8,386 times. This page was last modified 14:53, 14 September 2021. Content is available under Datsun 1200 Club.
