Sedan Fuel Tank Part Numbers
From Datsun 1200 Club
Categories: Fuel System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Sedan Fuel Tank
Fuel Sender
Fuel Cap
Standard
 1 17201-H1001 ASSY-TANK FUEL 40L 0570- 2 17201-H1000
   17201-H1902 ASSY-TANK FUEL 40L 1070- 4 17201-H1001
   17201-H2800 ASSY-TANK FUEL 40L 0 17201-H1902
   17201-H1000 ASSY-TANK FUEL 40L
 2 17342-18000 RING-O
 3 17343-14801 PLATE-LOCK 2 17343-H1001
   17343-H1001 PLATE-LOCK
 4 25060-H1000 GAUGE-FUEL TANK
   25060-H1900 GAUGE-FUEL TANK 1070- 0 25060-H1000
 5 17312-14800 PACKING-DRAIN
   17312-H1000 PACKING-DRAIN 2 17312-14800
   17312-P0101 PACKING-DRAIN -0370 2 17312-H1000
   17312-P0102 PACKING-DRAIN 2 17312-P0101
 6 17310-H1000 PLUG-DRAIN 2 08931-44210
   17310-P0100 PLUG-DRAIN -0370 2 17310-H1000
   08931-44210  PLUG M12
 7 17251-H1000 CAP-FILLER
 8 17264-18000 PACKING
 9 17220-H1000 ASSY-TUBE FILLER UPPER
10 17222-H1000 NECK-FILLER
11 17221-H1000 PACKING FILLER NECK
12 08310-40812 SCREW M4x8 pan head (3)
   17229-H1900 HOSE-FILLER 17229-H1000
13 17229-H1000 HOSE-FILLER
14 08723-15800 CLAMP-HOSE (2)
15 A7325-H1000 TUBE(10X14DX5M)
16 08723-11400 CLAMP-HOSE (2)
   16439-22100 CLAMP-HOSE (2) 2 08723-11400
17 17335-H1000 TUBE-VINYL
18 08360-82014 BOLT WITH LOCK WASHER (4) Machine screw M8x20, Hex head
19 08915-53810 WASHER-PLAIN M8 (4)
20 17314-H1000 GROMMET
1973 LB110 USA Parts Catalog
Evapo
1 17201-H1902 ASSY-TANK FUEL 40L SEDAN EVAPO 0570- 2 17201-H1901
1 17201-H2800 ASSY-TANK FUEL 40L SEDAN EVAPO 1070- 2 17201-H1902
1 17201-H1901 ASSY-TANK FUEL 40L SEDAN EVAPO
2 17342-18000 RING-O SEDAN
3 17343-H1001 PLATE-LOCK SEDAN
3 17343-14801 PLATE-LOCK SEDAN 2 17343-H1001
4 25060-H1900 GAUGE-FUEL TANK SEDAN EVAPO
5 17312-14800 PACKING-DRAIN SEDAN
5 17312-H1000 PACKING-DRAIN SEDAN 2 17312-14800
5 17312-P0101 PACKING-DRAIN SEDAN 1070- 2 17312-H1000
5 17312-P0102 PACKING-DRAIN SEDAN 1070- 2 17312-P0101
6 08931-44210 PLUG SEDAN
6 17310-H1000 PLUG-DRAIN SEDAN 2 08931-44210
6 17310-P0100 PLUG-DRAIN SEDAN 1070- 2 17310-H1000
7 17251-H1900 CAP-FILLER SEDAN
7 17251-H1000 CAP-FILLER SEDAN EVAPO 0570- 2 17251-H1900
7 17251-H1900 CAP-FILLER SEDAN EVAPO 0672- 2 17251-H1000
7 17251-H1901 CAP-FILLER SEDAN EVAPO 0672- 2 17251-H1900
7 17251-H1902 CAP-FILLER SEDAN EVAPO 0173- 2 17251-H1901
8 17264-18000 PACKING SEDAN
9 17220-H1901 TUBE-FILLER UPPER SEDAN EVAPO
10 17222-H1000 NECK-FILLER SEDAN
11 17221-H1000 PACKING FILLER NECK SEDAN
12 08310-40812 SCREW (3) SEDAN EVAPO
13 17229-H1900 HOSE-FILLER SEDAN EVAPO
14 08723-15800 CLAMP-HOSE (2) SEDAN EVAPO
15 08360-82014 BOLT WITH LOCK WASHER (4) SEDAN
16 08915-53810 WASHER-PLAIN (4) SEDAN
17 17314-H1000 GROMMET SEDAN
18 17350-H1900 ASSY-TANK RESERVOIR SEDAN EVAPO
19 17351-H1900 CONNECTOR-3 WAY SEDAN EVAPO
19 17351-H1901 CONNECTOR-3 WAY SEDAN EVAPO 2 17351-H1900
20 17352-H1901 SEPARATOR SEDAN EVAPO
20 17352-H1902 SEPARATOR SEDAN EVAPO 0570- 2 17352-H1901
21 A8742-20040 HOSE-FUEL RUBBER (10X17X2.2M) SEDAN EVAPO 2 08742-20040
21 08742-20040 HOSE-FUEL RUBBER (10X17X2.2M) SEDAN EVAPO 2 A7515-H1900
21 A7515-H1900 HOSE-FUEL RUBBER(10X16DX5M) SEDAN EVAPO
22 A7515-H1800 HOSE-FUEL RUBBER(6X13.5X5M) SEDAN EVAPO
22 08742-20020 HOSE-FUEL RUBBER (6X13.5X2.2M SEDAN EVAPO 2 A7515-H1800
23 08723-11400 CLAMP-HOSE 1 (14) SEDAN EVAPO
23 16439-22100 CLAMP-HOSE 1 (14) SEDAN EVAPO 2 08723-11400
24 17230-H1900 HOSE-FILLER 2ND SEDAN EVAPO
24 17230-H1901 HOSE-FILLER INNER SEDAN EVAPO 2 17230-H1900
25 08723-13600 CLAMP-HOSE SEDAN EVAPO
26 08723-11400 CLAMP-HOSE (2) SEDAN EVAPO
26 16439-22100 CLAMP-HOSE (2) SEDAN EVAPO 2 08723-11400
27 17361-H1922 TUBE-EVAPO SEDAN EVAPO AUTOMATIC
27 17361-H1902 TUBE-EVAPO SEDAN EVAPO MANUAL
27 17361-H1903 TUBE-EVAPO SEDAN EVAPO MANUAL 0 17361-H1902
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Sedan_Fuel_Tank_Part_Numbers"
This page has been accessed 6,663 times. This page was last modified 07:28, 10 May 2023. Content is available under Datsun 1200 Club.
