THE DATSUN RANGE
From Datsun 1200 Club
Category: Documentation
<-- back to Brochures
Title: THE DATSUN RANGE [1200 Deluxe Saloon]
1971 all Datsun cars B110
Format:1 page tri-fold (6 panels) Size:212x140mm Publication Number:unspecified
27554.jpgoutside 27553.jpginside
Outside
1200 cover
1600 panel 2
2000 panel 3
27554.jpgAlbum 27554
1200 DE LUXE SALOON
B110 1200 DE LUXE SALOON
THE DATSUN RANGE
27552.jpgAlbum 27552
1200 DE LUXE SALOON
Four door, all steel body with separate reclining front seats.
Standard equipment includes: front disc brakes, padded instrument panel, whitewall tyres, overriders, twin wind-tone horns, windscreen washers, two speed wipers, carpeting throughout, heater and demister, reversing lights, and headlight flasher.
A sturdy, comfortable and high performance " big " car.
SPECIFICATION
Engine 4 cylinder 1,171 c.c. OHV engine with 5 bearing camshaft. with Hitachi twin choke downdraught carburettor. 68 B H-P at 6,000 rpm, compression ratio 9:1. Max: torque 70 ft. lbs. at 3,600 rpm.
Transmission Floor mounted central gear lever. Syncromesh on all four gears. Ratios: 1st: 3.757 2nd: 2.169 3rd: 1.104 4th: 1.000 Rev. 3.610
Overall length 12' 6-1/2"
Front Suspension Independent strut type with coil springs, tension rods, telescopic shock absorbers and stabilizer.
Rear Suspension Semi elliptic leaf springs with shock absorbers.
Performance 93 mph.
Electrical System 12 volts. 40 A H Accumulator and 25 amp. alternator.
THE INTERNATIONAL CAR
DATSUN
1800 DE LUXE SALOON
 C30 1800 DE LUXE SALOON
2000 DE LUXE ESTATE CAR
130 2000 DE LUXE ESTATE CAR
Nissan-Datsun (U.K. Concessionares) Ltd.
Harbour Way - Shoreham-by-Sea - Sussex - BN4 5HX
Telephone Shoreham-by-Sea 4410-4418-4674 Telex 87445
Inside
27553.jpgAlbum 27553
1300 DE LUXE SALOON
510 1300 DE LUXE SALOON
1600 DE LUXE SALOON
510 1600 DE LUXE SALOON
1600 DE LUXE ESTATE CAR
510 1600 DE LUXE ESTATE CAR
Revision
REVISION
* 1200 Coupe added
* 1300 changed to 1400
* no auto for the 1400
27560.jpgAlbum 27560
Front
Revisions:
  • adds a blue line at the bottom about coupe
  • deleted " overriders, twin wind-tone horns,"
  • added "Wheel trims as illustrated available at extra cost."
THE DATSUN RANGE
5265.jpgAlbum 5265
1200 DE LUXE SALOON
Standard equipment includes: front disc brakes, padded instrument panel, whitewall tyres, windscreen washers, two speed wipers, carpeting throughout, heater and demister, reversing lights, and headlight flasher. Wheel trims as illustrated available at extra cost.
SPECIFICATION
Performance 93 mph.
DATSUN
ALSO AVAILABLE IN DELUX COUPE VERSION
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=THE_DATSUN_RANGE"
This page has been accessed 2,626 times. This page was last modified 06:17, 1 April 2025. Content is available under Datsun 1200 Club.
