Transmission Seals
From Datsun 1200 Club
Categories: Transmission | Engine Mechanical
<-- back to 56-Series Transmission Parts
Rubber seals for gearbox.
#Front Cover O-ring
#Front Oil Seal
#Transmission Rear Seal
Front Cover O-ring
32112-18000 RING-O, front cover ($7 Nissan USA 2025)
Front Oil Seal
8 32113-13200 SEAL-OIL FRONT COVER
8 32113-H3100 SEAL-OIL FRONT COVER 0971- 2 32113-13200
C2113-H3100 SEAL-OIL FRONT COVER 0971-
 * Replaces: 32113-H3100 and 32113-13200
31104.jpgAlbum 31104
Rockauto
* SCHAEFFLER SS2200
Bore Diameter (IN)                 1.575
Bore Diameter (MM)                 40.01
Maximum Seal Inside Diameter (IN)  0.984
Maximum Seal Inside Diameter (MM)  24.99
Seal Outside Diameter (IN)	    1.583
Seal Outside Diameter (MM)	    40.21
Seal Type	Metal; Spring; Auxiliary lip
Seal Width (IN)	            0.276
Seal Width (MM)	            7.01
Sealing Material	         Nitrile
Fits:
* Datsun B110/B210/B310
* GM/Isuzu truck steering Gear Worm Shaft seal
* Honda Accord/Prelude 1979-1983
Rockauto
* Timken 222540 F4W56L, F4W56A $2.84
* National 710316 F4W56L
  * Oil Seal: Nitrile
  * Shaft Size=0.984"
  * Housing Bore=1.575"
  * Outer Diameter=1.583"
  * Width=0.315"
* Timken 710417 F4W63, F4W63A, F4W63L
* Timken 1981 R4W71A
REPAIR SLEEVES
31103.jpgAlbum 31103
* SKF 99098 Speed-Sleeve
* Timken KWK99098 Kwik Sleeve repair F4W56L, F4W56A
* National/BCA 99098 Redi-Sleeve $27.79
  * .982" x .986" x .313"
TRANSMISSION EXTENSION REAR OIL SEAL (tailshaft seal/yoke seal/gearbox output seal)
Which seal you need depends on which type of Driveshaft yoke is being used.
Shrouded OR unshrouded OR lipped
17849.jpgAlbum 17849 26284.jpgAlbum 26284
If you buy the wrong seal, you may be able to use it by cutting it down
885.jpgAlbum 885
56-series Transmission
3-speed, 4-speed, 5-speed 56-Series Transmission
16 #32136-18001 SEAL-OIL REAR EXTENSION
16 #32136-H3100 SEAL-OIL REAR EXTENSION 1071-0972 22 32136-18001
16 #32136-G1001 SEAL-OIL REAR EXTENSION 1072- 0 32136-H3100
32136-H3100
B110 from October 1971
* replaced the earlier #32136-18001
* not compatible with the newer #32136-G1001
32136-H3100 SEAL-OIL REAR EXTENSION [45mm bore] RockAuto.com
* SKF 11618
31100.jpgAlbum 31100 31101.jpgAlbum 31101 31102.jpgAlbum 31102
32136-18000
Simple type 45mm
Replaced by #32136-H3100
* B10 Datsun 1000
* Early B110 Datsun 1200
32136-18000 45mm diameter
32136-G1001
New style with shield enclosing the end of the transmission. Will not work with drivelines that have a shield.
56-series from October 1971
* B110 from 1971.10
* B120 from 7110
* B210
TIMKEN 2016 F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L $11.04
NATIONAL 2016 Aichi F4W56L $15.87
* Material        Nitrile
* Shaft Size      1.181" 30mm
* Housing Bore    1.772" 45mm
* Outer Diameter  1.78"  45.2mm
* Flange Diameter 2.441" 62mm
* Width           0.591" 15mm
32136-G1001 60mm flange, 45 mm bore
25685.jpgAlbum 25685 maido_113-img600x450-13530452029nee0t27970.jpg maido_113-img600x450-1353045201jpi1ni27970.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Transmission_Seals"
This page has been accessed 106 times. This page was last modified 00:34, 31 October 2025. Content is available under Datsun 1200 Club.
