Cylinder Head Part Numbers 2
From Datsun 1200 Club
Category: Engine Mechanical
A-series Cylinder Heads were used in many models, and there are many variations. For more details, see A-series Cylinder Heads. Following are part numbers for head assemblies. Also see A12GX Part Numbers.
Also see Cylinder Head Part Numbers 1
Head Gasket
GASKET-CYLINDER HEAD (11044)
A10 Bore ??
11044-18000,18001,18002 B10
11044-18004 B10 replaces early part
A12 Bore 73 mm
11044-H1000 B110, B210 to '75-4
11044-H1025 B210 from '75-5
11044-H3901 B210 -7612, B310 Van
11044-H7403 B210 7701-
11044-M3000 B210 Van -7612
11044-M3001 B210 Van 7701-
11044-H8501 B310 Sedan, Coupe
11044-H2300, H2301 [thinner?] A12GX, A12T
11044-H2325 A12GX from '72-6
A13 (1974) Bore ?
A12A Bore 75mm
A14 Bore 76mm
11044-H7500,H7860 B210 11044-H7201 B310
11044-M2460 A14T
A13S,A15 (76mm bore)
11044-H8660
Valve Guides
  • 13212-H0112 GUIDE-VALVE INTAKE $8.08
  • 13213-H0113 GUIDE-VALVE EXHAUST $8.25
B10
From the B10 JDM parts catalog June, 1970
  • Intake valves: 35mm 13201-H1000 (formerly 13201-18000)
  • Exhaust valves: 29mm 13202-18000
  • Rally Springs (dual valve springs) were an option.
  • Round Ports
  • Dry manifold
A10
Sedan,Van
11041-18001, 11041-18002 ASS'Y-HEAD cylinder
11041-H0100 ASS'Y-HEAD cylinder 11041-18002
11041-H1001 ASS'Y-HEAD cylinder from '70-april
So you can see the last B10 head is the same as the B110 head. The fittings are probably different from the early head.
A10 Coupe
Coupe - used with flat-top pistons for higher compression
11041-25700,11041-25701 ASS'Y-HEAD cylinder
11041-H0300 ASS'Y-HEAD cylinder 11041-25701
Most likely the Coupe head has a different size chamber (larger?), so that the flat-tops don't push it to 10.5:1.
B110
The following part numbers are from the B110 Japanese Domestic Model parts catalog (Nov. 1971), unless otherwise noted.
A12
  • Intake valves: 29mm 13201-H1000
  • Exhaust valves: 35mm 13202-18000
11041-H1001 HEAD ASSY-CYLINDER A12 except GX 11041-H1003
11041-H1003 HEAD ASSY-CYLINDER A12 except GX 11041-H1005
11041-H1005 HEAD ASSY-CYLINDER A12 except GX
All of these are replacement-equivalents
A12GX (dual valve springs)
  • Intake valves: 13201-H2300 35mm
  • Exhaust valves: 13202-H2300 29 mm
Combustion Chamber: 29cc (compression ratio 10:1 with flat-top pistons)
11041-H2300 HEAD ASSY-CYLINDER A12 GX 11041-H2301
11041-H2301 HEAD ASSY-CYLINDER A12 GX
B110 USA
USA model B110s heads were the same as JDM heads, except that most had "Open" combustion chambers to reduce NOx emissions.
* Closed Chamber (same as JDM heads)
11041-H1001 to 5/71 obs
* Open Chamber (unique to USA?)
* Model of Origin code H39 is for LB110TRU
11041-H3900 6/71-12/72 obs
11041-H3901 1/73-2/73 obs
11041-H3902 3/73 & up
11041-H3903 3/73 & up (supercedes H3902)
Source: Hollander Catalog, Nissan Parts Catalog
B120
From the B120 Japanese Domestic Model parts catalog (Oct 1997, covers 7510-end of JDM product in 1994/1995)
Early
    • 13201-H1000 to 8503
    • 13201-H2300 from 8504
    • 13202-18000 to 8503
    • 13202-H7400 from 8504
Head Gasket
11044-H3901 7510-9107
11044-H3902 9107-
Dry Intake - Gasket 14035-18000
* original manifold bolt-pattern
11041-M3000 HEAD ASSY-CYLINDER 7510-7803
* new manifold bolt-pattern
11041-M3001 HEAD ASSY-CYLINDER 7804-7907
Wet Intake, New Bolt Pattern
* Intake Gasket 14035-H7400
11041-G2560 HEAD ASSY-CYLINDER 7908-8109
* Intake Gasket 14035-H7410
11041-G2561 HEAD ASSY-CYLINDER 8110-8910
* uses bridged intake manifold
 (front and rear runners are tied together)
* Intake Gasket 14035-H8501 -9111
* Intake Gasket 14035-H8511 9111-
11041-G6100 HEAD ASSY-CYLINDER 8910-
B210 Early
From the Nov 1976 JDM catalog
A12T
  • Exhaust valves: 13202-H2300 29mm
  • Extra Large Oval Port
  • Wet intake
  • Dual valve springs
11041-H5702 HEAD ASSY-cylinder A12T
A12
From the Nov 1976 JDM catalog (including van)
  • Original Intake Bolt Pattern (Gasket 14035-18000)
  • Dry Intake
11041-H5002 HEAD ASSY-cylinder A12S
11041-H3000 HEAD ASSY-cylinder A12S (from '75-10) ^11041-H5002
B210 Late
From the B210 Japanese Domestic Model parts catalog (Jul 1978) unless otherwise stated.
Head Gasket
  • A12: 11044-H3901
  • A14: 11044-H7200 A14, A14T
Intake Gasket
  • A12: 14035-18000 Van [dry intake, original bolt pattern]
  • A12S: 14035-H3901 S,K [dry intake, new bolt pattern]
  • A14: 14035-H7200 [Round Port, dry intake]
  • A14T: 14035-M2401 [Oval Port]
A12 (Van)
  • Round Port
  • Dry intake
  • Original intake bolt pattern
11041-M3000 HEAD ASSY-CYLINDER A12S V -7612
11041-M3001 HEAD ASSY-CYLINDER A12S V 7701-
A12S
  • Intake valves: 35mm 13201-H2300
  • Exhaust valves: 29mm 13202-H7400
  • Round Port
  • Dry Intake
  • New intake bolt pattern
11041-H7401 HEAD ASSY-CYLINDER A12S S,K -7612
11041-H7403 HEAD ASSY-CYLINDER A12S S,K 7701-
A14 (Van)
  • Intake valves: 37mm 13201-H6200
  • Exhaust valves: 30mm 13202-H6200
  • Round Ports
    • Intake-to-Head gasket 11044-H7200
  • Dry Intake
11041-H7500 HEAD ASSY-CYLINDER A14S V
11041-H7860 HEAD ASSY-CYLINDER A14S V
A14T (twin carb)
  • Oval Ports (smaller than GX, same size as standard A14)
11041-M2460 HEAD ASSY-CYLINDER A14T
B210 USA
Source: Hollander
A13 (1974)
  • Medium Oval Port
  • Large Valves (A14 size)
11041-H6200 B-210 1974 A13
A14
* Round Port
11041-H78261 B-210 1977 A14 5-speed
* Oval Port
11041-M4900 B-210 1975-1976 A14, F10 1976
11041-H7760 B-210 1977 A14 exc. 5-speed
B310 JDM
From the B310 Japanese Domestic Model parts catalog (Nov. 1983)
Van: Round Port A12S, Round Port A14S
EFI: Medium Oval A14E (to 8010), A15E (from 8011)
A12: Round Port A12S, A13S, water port intake
A14: Oval Port A14S, A15S, water port intake
Head Gasket
A10 : 11044-18000,18001,18002
A10: 11044-18004
A12 (73mm bore): 11044-H1000
A12S (73mm bore): 11044-H8501 Sedan, Coupe
A12S (73mm bore): 11044-H3901 Van
A12 GX: 11044-H2300 [thinner?]
A13 (1974): ?
A12A (75mm bore): ?
A14 (76mm bore): 11044-H7201
A13S,A15 (76mm bore): 11044-H8660
Intake Gasket
GASKET-MANIFOLD TO CYLINDER HEAD
Round Port, No water ports, Original bolt pattern
  • 14035-18000 B310 A12S V -7909 (Select Use)
  • 14035-18010 B310 A12S V -7909 (Select Use)
Round Port, No water ports, New bolt pattern (both patterns?)
  • 14035-H7200 B310 A14S Van -7909 (Select Use)
  • 14035-H7210 B310 A14S Van -7909 (Select Use)
  • 14035-H7400 B310 Van 7910- (Select Use), supercedes H7200
  • 14035-H7410 B310 Van 7910- (Select Use), supercedes H7210
Round Port, Water Ports, New bolt pattern
  • 14035-H8501 B310 A12S S,K -8010, A13 8011-
Oval Port, Water Ports, New bolt pattern
  • 14035-H8901 B310 A14S S,K + AT -8010, A15S 8011-
Medium Oval Port, EFI Head
  • 14035-H9201 B310 A14E -8010, A15E
A12S Van
  • Intake valves: 35mm 13201-H1000 (1971 B110)
  • Exhaust valves: 29mm 13202-18000 (1971 B110)
  • Round Port
  • No intake water ports
* old intake bolt pattern
11041-M3001 HEAD ASSY-CYLINDER A12S.V N-7907 11041-G2560
* both intake bolt patterns?
11041-G2560 HEAD ASSY-CYLINDER V.A12S 7910-8010 11041-G2561
11041-G2561 HEAD ASSY-CYLINDER V.A12S 8011-
A12S Van head is same as B120 Truck head.
A12S, A13S
  • Intake valves: 35mm 13201-H2300 (1971 B110 GX engine)
  • Exhaust valves: 13202-H7400
  • Round Port
  • Intake Water Ports
11041-H8500 HEAD ASSY-CYLINDER A12S.S,K  N-7909 11041-H8501
11041-H8501 HEAD ASSY-CYLINDER S,K.A12S 7910-8010
Both of these are replacement-equivalents
11041-H8503 HEAD ASSY-CYLINDER A13S 8011-
A14 Van
  • Exhaust valves: 30mm 13202-H6200 replaced by 13202-H8900
  • Round Port
  • No Intake Water Ports
11041-H7861 HEAD ASSY-CYLINDER A14S.V N-7806 11041-H7863
11041-H7863 HEAD ASSY-CYLINDER A14S.V 7807-7909 11041-G3202
11041-G3202 HEAD ASSY-CYLINDER V.A14S 7910-8010
11041-G3203 HEAD ASSY-CYLINDER V.A14S 8011-
A14, A15
  • Oval Port
11041-H8900 HEAD ASSY-CYLINDER S,K.A14S 7811-7903 11041-H8901
11041-H8901 HEAD ASSY-CYLINDER S,K.A14S 7811-7903 11041-H8904
11041-H8904 HEAD ASSY-CYLINDER S,K.A14S 7904-8010, A15S 8011-
A14E & A15E
  • Medium Oval Ports
11041-H9200 HEAD ASSY-CYLINDER A14E N-7810 11041-H9201
11041-H9201 HEAD ASSY-CYLINDER A14E 7811-7903 11041-H9202
11041-H9202 HEAD ASSY-CYLINDER A14E 7904-7907 11041-H9204
11041-H9204 HEAD ASSY-CYLINDER A14E 7908-8010 A15E 8011-
B310 USA
Source: Nissan Parts Catalog Jan 2006
North American Market was divided starting in mid-1970s:
  • FED (U): Federal (49 states, not including California)
  • CAL (K): California (which has stricter emission regulations)
  • CAN (N): Canada
Heads and Head Gaskets were updated 0880, not interchangeable with previous gasket and head. The blocks are the same, so presumably the head was physically changed or ... perhaps the specification was simply upgraded.
VALVE -0780
  • INTAKE 37mm: 13201-H6200 A12A USA
  • EXHAUST 30mm: 13202-H6200 A12A USA
VALVE 0880-
  • INTAKE: 13201-H9500 A12A USA 0880-
A14/A15
11044-H7201 A14,A15 -0780
11044-H9820 A14,A15 0880-
A12A
VALVE -0780
VALVE 0880-
  • EXHAUST: 13202-H9500
11044-H8501 A12 CAN 1278-0780
11044-H8501 A12 USA 0879-0780
11044-H9520 A12 0880-
11044-H9521 A12
CYLINDER HEAD ASSY
11041-H7283 A12 -1078
11041-H7284 A12 CAN 1278-0780 ^11041-H7283
11041-H7285 A12 CAN 0880-
Cherry USA
Source: Hollander
11041-H7762 A14 310 (N10) 1979
11041-H7660 A14 F10 1977-78
11041-M4900 A14 F10 1976, B-210 1975-1976
Datsun Cherry Heads
The Datsun Cherry model family was Datsun's first front-wheel-drive line and includes the E10, F10 and N10 models, a.k.a. Pulsar and includes Datsun 310.
A10 from E10
11041-M0102 HEAD ASSY-CYLINDER A10
A12S from E10
11041-H1503 HEAD ASSY-CYLINDER A12S
A12T from E10 (dual valve springs)
  • Exhaust valves: 29mm 13202-H2300
11041-M0801 HEAD ASSY-CYLINDER A12T
A12 from F10 Sedan & Coupe
A12 from F10 Van
A14S from F10
11041-7502 HEAD ASSY-CYLINDER A14S
A14T from F10
A12S from N10 Van
11041-M3001 HEAD ASSY-CYLINDER 11041-G2560
A12AS from N10
11041-H8500 HEAD ASSY-CYLINDER A12AS 11041-H8501
11041-H8501 HEAD ASSY-CYLINDER A12AS 11041-H8503
11041-H8503 HEAD ASSY-CYLINDER A12AS
A14S from N10 Van
11041-G3202 HEAD ASSY-CYLINDER 11041-G3203
A14S from N10 P
11041-H8900 HEAD ASSY-CYLINDER 11041-H8902
11041-H8902 HEAD ASSY-CYLINDER 11041-H8904
A14E from N10 (dual valve springs)
11041-H9200 HEAD ASSY-CYLINDER 11041-H9202
11041-H9202 HEAD ASSY-CYLINDER 11041-H9204
Hollander Interchange
North American-Market Cylinder Heads (reference Hollander interchange 1980)
No. 183 Datsun 1200 (B110) 71-73 A12
No. 1367 Datsun B-210 (B210) 1974 A13
11041-H6200
No. 1370 Datsun B-210 (B210) 1977 A14
11041-H78261 or 11041-H7760
No. 1375 Datsun B-210 (B210) 75-76 A14 & Datsun F10 1976
11041-M4900
No. 1376 Datsun F10 1977-78
11041-H7660
No. 2641 Datsun 210 (B310) 1979 Ex. California A14 & A15
11041-H7702
No. 2642 Datsun 210 (B310) 1979 California A14 & A15
11041-H9162
No. 2742 Datsun 310 (N10) 1979
11041-H7762
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Cylinder_Head_Part_Numbers_2"
This page has been accessed 10,243 times. This page was last modified 02:16, 12 April 2013. Content is available under Datsun 1200 Club.
