Lucas alternator
From Datsun 1200 Club
Categories: Charging System | Engine Electrical System
Locally assembled Datsun 1200 have used various alternators. Lucas is popular in Commonwealth countries.
27151.jpgAlbum 27151
Lucas 15AC
Late 120Y Australian assembled have a Lucas single wire internally regulated alternator. Earlier 120Y have had an externally regulated alternator.
Lucas 15-A.C. have one IND terminal and two + terminals.
NOTE: Externally regulated A15AC also has IND + F terminal
It will plug into an externally-regulated harness BUT IT IS WIRED DIFFERENTLY.
+    goes to battery via Fusible Link
AUX+ leave disconnected
IND  indicator lamp (charge)
F    missing*
NOTE: If it has an 'F' terminal the 15AC needs external regulator
Lucas 15AC missing F terminal (indicating internally regulated)
Lucas AS123
Big-flange Lucas internally-regulated alternator is used in South Africa on the B140 Nissan LDV 1400.
Lucas AS123 55A
65A available $86 USD new aftermarket
Internal Regulator
3 hole adjusting tension ear.
Bracket angle: -30° / 0° / 30°
Threaded B+ terminal post and optional B+ spade connection
Threaded D+ terminal post
Single wire or three terminal plugs
26024.jpgAlbum 26024 31323.jpgbrochure
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Lucas_alternator"
This page has been accessed 8,657 times. This page was last modified 01:17, 24 November 2025. Content is available under Datsun 1200 Club.
