Piston, Crank & Rod Part Numbers
From Datsun 1200 Club
Categories: Engine Mechanical | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
Piston
Crankshaft
Connecting Rods
Flywheel
Camshaft bearings
 1 12010-H1011 SET-PISTON WITH PIN STD (4) A12 0672- 2 12010-H1001
 1 12010-H1003 SET-PISTON WITH PIN 0.25 OVER SIZE (4) A12
 1 12010-H1004 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12
   12010-H1065 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12 0672- 2 12010-H1014
 1 12010-H1014 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12 0672- 2 12010-H1004
 1 12010-H1005 SET-PISTON WITH PIN 0.75 OVER SIZE (4) A12
 1 12010-H1006 SET-PISTON WITH PIN 1.00 OVER SIZE (4) A12
   12010-H1066 SET-PISTON WITH PIN 1.00 OVER SIZE [-0.40] (4) A12 0672- 2 12010-H1016
 1 12010-H1016 SET-PISTON WITH PIN 1.00 OVER SIZE (4) A12 0672- 2 12010-H1006
 1 12010-H1007 SET-PISTON WITH PIN 1.25 OVER SIZE (4) A12
 1 12010-H1008 SET-PISTON WITH PIN 1.50 OVER SIZE (4) A12
   12010-H1061 SET-PISTON WITH PIN STD (4) A12 12010-H1001
 1 12010-H1001 SET-PISTON WITH PIN STD (4) A12
   12035-H6201 SET-RING PISTON 0.50 OVER SIZE (4) A12 2 12035-B3040
 2 12035-B3040 SET-RING PISTON 0.50 OVER SIZE (4) A12 2 12035-H1002
   12039-H6200 SET-RING PISTON 1.50 OVER SIZE (4) A12 2 12039-B3040
 2 12039-B3040 SET-RING PISTON 1.50 OVER SIZE (4) A12 2 12039-H1002
 2 12039-H1002 SET-RING PISTON 1.50 OVER SIZE (4) A12
 2 12038-H1002 SET-RING PISTON 1.25 OVER SIZE (4) A12
 2 12037-B3040 SET-RING PISTON 1.00 OVER SIZE (4) A12 2 12037-H1002
 2 12033-H1002 SET-RING PISTON STD (4) A12
 2 12037-H1002 SET-RING PISTON 1.00 OVER SIZE (4) A12
 2 12035-H1002 SET-RING PISTON 0.50 OVER SIZE (4) A12
 2 12034-H1002 SET-RING PISTON 0.25 OVER SIZE (4) A12
 2 12033-H6201 SET-RING PISTON STD (4) A12 2 12033-B3040
 2 12033-B3040 SET-RING PISTON STD (4) A12 2 12033-H1002
 2 12036-H1002 SET-RING PISTON 0.75 OVER SIZE (4) A12
 3 12100-H1000 ASSY-CONNECTING ROD (4) A12
 4 12109-H1001 BOLT-CONNECTING ROD (TOKYO RASI) (8) A12
 4 12109-H1011 BOLT-CONNECTING ROD (TOKAI SEIAT (8) A12
 5 12112-18000 NUT-HEX CONNECTING ROD (8) A12
 6 12111-20906 BUSHING-CONNECTING ROD UNDERSIZE 100 (8) A12
 6 12111-20910 BEARING-CONNECTING ROD STD (8) A12 12111-20900
 6 12111-20900 BEARING-CONNECTING ROD STD (8) A12
 6 12111-20901 BUSHING-CONNECTING ROD UNDERSIZE 8 (8) A12
 6 12111-20902 BUSHING-CONNECTING ROD UNDERSIZE 12 (8) A12
 6 12111-20903 BUSHING-CONNECTING ROD UNDERSIZE 25 (8) A12
 6 12111-20905 BUSHING-CONNECTING ROD UNDERSIZE 75 (8) A12
 6 12111-20904 BUSHING-CONNECTING ROD UNDERSIZE 50 (8) A12
 7 12200-H1000 ASSY-CRANKSHAFT A12 MANUAL
 7 12200-H1001 CRANKSHAFT A12 -671 12 12200-H1000
 7 12200-H1000 CRANKSHAFT A12 0671- 2 12200-H1001
 7 12200-H5000 CRANKSHAFT A12 0572- 2 12200-H1000
 8 00933-20650 PLUG-TAPER (4) A12
 8 01647-00011 PLUG-TAPER (4) A12 2 00933-20650
 9 32202-18000 BUSHING-PILOT A12 MANUAL
10 12316-30000 KEY-WOODLUF 5X16 (2) A12
11 13021-H1000 SPROCKET-CRANK A12
12 12301-30000 WASHER-PACKING CRANKSHAFT (0) A12
13 12299-18000 SHIM-CRANK SPROCKET (0) A12
14 12302-18000 THROWER-OIL CRANKSHAFT A12
15 12303-H1001 PULLEY-CRANKSHAFT A12 0272- 0 12303-18002
15 12303-18002 PULLEY-CRANKSHAFT A12
16 12308-H1000 WASHER-PULLEY BOLT A12
17 12309-78200 BOLT-CRANK PULLEY A12
18 12310-H1000 ASSY-FLY WHEEL A12 MANUAL
19 12312-18000 GEAR-RING FLY WHEEL A12 MANUAL
20 12313-10600 DOWL (3) A12 MANUAL
21 12315-H1001 BOLT-FLY WHEEL (6) A12 MANUAL
22 12331-20300 ASSY-DRIVE PLATE & GEAR A12 AUTOMATIC
23 12330-20300 PILOT-CONVERTER A12 AUTOMATIC
24 12333-20300 PLATE-CRANK CONVERTER A12 AUTOMATIC
25 12315-H1000 BOLT-FLY WHEEL (6) A12 AUTOMATIC
26 12212-H1000 SET-BEARING US 1.00MM A12
26 12207-M7201 SET-BEARING STD A12 12207-H1000
26 12207-H1000 SET-BEARING STD A12
26 12208-H1000 SET-BEARING US 0.20MM A12
26 12209-H1000 SET-BEARING US 0.25MM A12
26 12210-H1000 SET-BEARING US 0.50MM A12
26 12211-H1000 SET-BEARING US 0.75MM A12
1973 LB110 USA Parts Catalog
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Piston%2C_Crank_%26_Rod_Part_Numbers"
This page has been accessed 7,130 times. This page was last modified 05:41, 4 September 2017. Content is available under Datsun 1200 Club.
