Bumper Parts
From Datsun 1200 Club
Category: Body
Bumpers are the same for USA and Japan markets, except for 1973 USA model bumper.
B110 バンパー
* 1970 front bumpers use small 8mm bolts to fasten to car
* 1970 North America intro with #Overriders
* 1973 North America change to safety bumpers
* 1975 change of stays to use large 12mm bolts
The regular rear bumper is in three pieces (and sold as three pieces)
  • Long center section that varies between Sedan, Coupe and Wagon
  • Two end caps, left and right, that wrap around the side a little bit
End caps
21430.jpgAlbum 21430
NOTE: 1973 parts fit older brackets (stays), but older bumper doesn't fit newer brackets.
Front Bumper (Coupe & Sedan)
* 62651-H1900 ASSY-BUMPER,FRONT Sedan, Coupe w/#Overrider holes
* 62651-H1000/H1001 ASSY-BUMPER,FRONT early Coupe
* 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
POST coupe bumper
28258.jpgAlbum 28258
Rear Bumper, sedan
* 85012-H1000 BUMPER END-REAR RH Coupe, Sedan
* 85013-H1000 BUMPER END-REAR LH Coupe, Sedan
* 85011-H1900 BUMPER-REAR CENTER Sedan
* 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
Rear Bumper, Coupe
* 85011-H1905 BUMPER-REAR CENTER Coupe
* 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
Overriders
Overriders (bumper guards) are the same sedan/coupe. Front and rear differ. For 1971-1972 the rubber is in the form of inserts that snap into the brackets. For 1973 with the 5-mph bumpers, the rubber is bonded to the brackets.
Overrider rubber inserts 1970-1972 (two front, two rear)
85024-H1900 RUBBER-OVERRIDER (4) -0672
Rear Overrider
85020-H1900 OVERRIDER-REAR BUMPER RH
85021-H1900 OVERRIDER-REAR BUMPER LH
85020-H7000 OVERRIDER-REAR BUMPER RH 1973
85021-H7000 OVERRIDER-REAR BUMPER LH 1973
Front Overrider
62674-H1900 OVERRIDER-FRONT BUMPER RH
62675-H1900 OVERRIDER-FRONT BUMPER LH
62674-H7000 OVERRIDER-FRONT BUMPER RH 1973
62675-H7000 OVERRIDER-FRONT BUMPER LH 1973
1971-1972 overriders with rubber inserts 21179.jpgAlbum 21179
1973 2.5-mph bumpers
15928.jpgAlbum 15928
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Front Bumper
62651-H1000 ASSY-BUMPER,FRONT [sedan/coupe/van]
62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
* Two-piece welded vs Three-piece welded
8580.jpgAlbum 8580 8581.jpgAlbum 8581 8582.jpgAlbum 8582 8583.jpgAlbum 8583
Stays
Stays mount the bumper to the body. Early vs late stays have a different bolt angle and spacing (not interchangeable).
Early 1200s use 8mm bolts (fastening Stay to Hood Ledge)
08110-81662 BOLT (up to '72-6)
Later 1200s use 12mm bolts
08114-22510 BOLT (from '72-7)
Changed to a longer 30mm long bolt for 1976 JPN (1973 in USA)
Early Front Bumper Stays: 62671-H1001 to June 1972 (8 mm chassis bolts)
21433.jpgAlbum 21433
Early vs Late stays (notice notch in late version): 62671-H1002 from July 1972 (12 mm chassis bolts)
24909.jpgAlbum 24909
Late stays are identified by the notches
27136.jpgAlbum 27136
Stay Measurements
early chassis rail bolt holes: ?
late chassis rail bolt holes: ?
Rear Bumper
NOTE: Japan models had no #Overriders
85011-H1800 BUMPER-REAR CENTER Coupe [with plate cutout]
85011-H1400 BUMPER-REAR CENTER Van [plain bar]
85011-H1000 BUMPER-REAR CENTER Sedan [with lamp hole]
21435.jpgAlbum 21435
15 85012-H1000 BUMPER-REAR [end cap] RH
16 85013-H1000 BUMPER-REAR [end cap] LH
Rear Stays
#H10 coupe,sedan
#H14 Van
fixing body to stay (2 of each) ALL
  62678-21000 SHIM-rubber, stay, bumper side
  08110-82062 BOLT-with lock washer M8x20
  08915-53810 WASHER-plain large M8
H10
85204-H1000 STAY-bumper, rear coupe,sedan 2
Rear Bumper Stay bolts straight to the Body#Rear Panel... so a little bump may dent the body.
21434.jpgAlbum 21434
20121.jpgAlbum 20121
H14
B110 Sunny Van (VB110) aka wagon
85204-H1400 STAY-bumper, rear Van RH
85205-H1400 STAY-bumper, rear Van LH
Right and Left side stays
28615.jpgAlbum 28615 28616.jpgAlbum 28616 28617.jpgAlbum 28617 28618.jpgAlbum 28618
28619.jpgAlbum 28619 28620.jpgAlbum 28620 28621.jpgAlbum 28621 28622.jpgAlbum 28622
Japan Sunny Truck
Front
Assembly Early (1971-1978)
21426.jpgAlbum 21426
62651-G1001 BUMPER ASS'Y-front STD -7509 [painted]
62651-H1025 BUMPER ASS'Y-front DX -7509 [chromed]
62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 [car-type]
Assembly Late - rubber ends
21428.jpgAlbum 21428
62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 [CHROME + rubber]
62650-95W00 ASSY-BUMPER,FRONT Truck from 8910 [BLACK + rubber]
21432.jpgAlbum 21432
62024-G1060 BUMPER-FRONT [rubber end cap] RH from 7804
62025-G1060 BUMPER-FRONT [rubber end cap] LH from 7804
* 08360-61026 SCREW 7804-8910
* 08911-10637 NUT 7804-8910
Side Brackets
24529.jpgAlbum 24529
62672-H1001 BRACKET-FRONT BUMPER SIDE, RH
62673-H1001 BRACKET-FRONT BUMPER SIDE, LH
62663-G1050 BOLT-bumper "B" STD -7509 [side, exterior]
* superceded 62663-15401 STD
62663-27700 BOLT-CARRIAGE [side, exterior] -8503 CHROME METAL (CR-10S) (2)
62663-G1900 BOLT [side, exterior] 8504-8910 CHROME METAL (CR-12S) (2)
62663-G1205 BOLT [side, exterior] 8910- BLACK ハンツトヤノソウ (2)
* 08915-43610 WASHER (2)
* 08915-13610 WASHER-LOCK (2)
* 08911-10610 NUT (2)
Carriage Bolts
bumper-bolts.jpg 21429.jpgAlbum 21429
62678-21000 SHIM-BRACKET BUMPER (2)
08360-61626 BOLT (fixing bumper side to fender)
  replaced 08360-62014 -7509
08915-43610 WASHER-plain -7509
Stays
21433.jpgAlbum 21433 24530.jpgAlbum 24530
62670-H1002 STAY-FRONT BUMPER, RH
* replaced 62670-H1001 STAY-front bumper (R.H.) (up to '72-6)
62671-H1002 STAY-FRONT BUMPER, LH
* replaced 62671-H1001 STAY-front bumper (L.H.) (up to '72-6)
62663-G1050 BOLT-bumper "B" STD (4)
62663-27700 BOLT-CARRIAGE (4) [external, to bumper] EXC STD
* 08915-43610 WASHER-PLAIN (4)
* 08915-13610 WASHER-LOCK (4)
* 08911-10610 NUT (4)
08124-23010 BOLT (4) [to body panel]
* superceded 08114-25510 (from '72-7)
* replaced 08110-81662 (up to '72-6)
08915-14210 WASHER-LOCK (4)
08915-44210 WASHER-PLAIN(4)
* replaced 08915-53810 (up to '72-6)
Hook (-7509) Bolted to the front Bumper Stays
62682-H7000 HOOK-tie down (R.H.)
62683-H7000 HOOK-tie down (L.H.)
21436.jpgAlbum 21436
Rear
85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7611
85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7611
85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
08310-64512 SCREW [external] 7510-
08915-43610 WASHER-lock
08310-64510 SCREW [external] -7509
* 08915-43610 WASHER-LOCK
08110-61810 SCREW [internal]
* 08915-13610 WASHER-LOCK 7510-
21431.jpgAlbum 21431
90802-G1000 BUMPER RUBBER-TAIL GATE -7603
90802-G1001 BUMPER RUBBER-TAIL GATE 7604-
08310-62012 SCREW (2)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Bumper_Parts"
This page has been accessed 17,483 times. This page was last modified 10:37, 24 August 2022. Content is available under Datsun 1200 Club.
