Three Speed Transmission
(Redirected from 3-speed)
Category: Transmission
<-- back to 56-Series Transmission
Most Datsun 1200s were fitted with a 4-speed floor shift manual transmission (FS4W56). However, the Standard trim models came with a 3-speed column shift (R3W56). This transmission had a higher 1st gear than the 4-speed (3.380:1 vs 3.757:1), meaning takeoff was a bit slower than the 4-speed, and starting on steep hils a bit more difficult. The 4-speed is a direct bolt-in replacement for the 3-speed.
Standard trim (STD) Datsun 1200 models came standard with an R3W56 transmission. This was a remote-shift box with a Steering Column-mounted shifter.
R = Remote shift
W = Warner type synchros
56 = spacing between shafts (56-Series Transmission)
column shift
2760.jpgAlbum 2760
side-shift linkage
14710.jpgAlbum 14710
steering column shift linkage
19054.jpgAlbum 19054
The remote-shift gearbox is easily recognizable by its lack of an upright gear shift apparatus on the extension housing.
Ratios:
Rev: 3.640
1st: 3.380
2nd: 1.734
3rd: 1.000
Note that the North American market got 4-speeds transmissions, never any 3-speeds.
See Transmission Overview for:
* Maintenance specifications (oil type, capacity, etc)
* Comparison of other B110 avaialble transmissions
* Gear ratios
* Link to the transmission swap article
B210 3-speed with Steering Column shift
25413.jpgAlbum 25413
B10
Older Datsun 1000 transmission, note the bell crank clutch mechanism instead of cable clutch:
16614.jpgAlbum 16614 19053.jpgAlbum 19053
C20
R3W56 from 1970 Cherry Cab with bell-crank clutch
174_6786df0bae8d8.jpgPost 498712 174_6786df12932af.jpgPost 498712
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Three_Speed_Transmission"
This page has been accessed 9,830 times. This page was last modified 22:14, 14 January 2025. Content is available under Datsun 1200 Club.
