Hot-Spark Ignition
(Redirected from Hotspark)
Categories: Engine Electrical System | Ignition Modifications
The Hot-Spark is an Electronic Ignition ignitor unit for Datsun 1200-style Hitachi distributors. It is only $50 USD, and fits easily like a Pertronix Electronic Ignition unit, but is less expensive.
POST levey said: The hot spark kit works well for me :)
It should work on your 1200, assuming you have an early Hitachi distributor (D4n type) and not a Mitsubishi unit. It will say on the distributor housing. Look for D410, D411, or D4A markings.
As with any points-replacement system, you can use the stock points coil with the stock ballast resistor. Hot-Spark sells a HS34HEC "high energy" coil, but it is a low-current 3.4 ohm unit. Electronic Ignition Coils are usually 0.7 ohms for a more powerful spark, but that is not compatible with the Hot-Spark.
Coil must have 3 Ohms or more primary resistance.
Hot-Spark also sell a new distributor (HS-HIT4) for L13/L14/L16/L18/L20B engines.
Discussion
Discussion: Electronic Ignition for points Hitachi Dizzies
7952_51d3d01f1fb06.jpgPost 440384 7952_51db23bb1af8b.jpgUpload click to view 7952_51ef4861845c6.jpgUpload click to view 7952_51ef489313c99.jpgUpload click to view 7952_51ef4955a319f.jpgUpload click to view 7952_51ef49a35b09e.jpgUpload click to view 7952_51ef49d372eef.jpgUpload click to view
  • Red wire: low side of ballast resistor
  • Black wire: Coil - terminal
  • Keep the stock ballast resistor, coil & factory wiring
Hot-Spark requires 3.0 ohm coil. Datsun 1200 points coil is 1.3 ohms, stock ballast resistor is 1.5 ohms, so keep the ballast resistor.
Why connect the Red wire to the low side of the Resistor? Because voltage regulators can exceed 14.0 volts and the Hot-Spark can be damaged by anything over 14.0 volts.
Hot-Spark: If the charging system voltage, measured at the coil's + terminal, is more than 14.0 volts at any RPM level ... [a] ballast resistor should be wired between the coil's + terminal and the red HotSpark ignition wire. Too much voltage can damage the ignition module
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Hot-Spark_Ignition"
This page has been accessed 14,606 times. This page was last modified 03:44, 24 September 2017. Content is available under Datsun 1200 Club.
