TOUGH AS IT IS THRIFTY
From Datsun 1200 Club
Categories: Documentation | Datsun B210
<-- back to B210 Advertisements
Title: TOUGH AS IT IS THRIFTY [mileage and features]
coupe 1976 B210
Format:full page Size:magazine Publication Number:unspecified
29213.jpgAlbum 29213
DATSUN B-210. TOUGH AS IT IS THRIFTY.
FIRST OFF...SUPER GAS MILEAGE!
Gas Mileage Information—Datsun B-210*
Model   Manual Transmission Automatic Transmission
Hatchback    City  Hwy.       City     Hwy.
and          MPG   MPG        MPG      MPG
Sedans       29    41         26       34
  • The figures quoted give an estimated fuel consumption and are the result of E.P.A. mileage tests. Depending on driving habits and the condition of your vehicle, your mileage may be more or less.
NOW CONSIDER THE PERFORMANCE. DURABILITY.
Engine: 4-cylinder, in-line OHV water-cooled.
Bore and Stroke 2.99 in. x 3.03 in.
Displacement (1397cc) 85.2 cu. in.
  • 70 HP SAE Net (68-Calif.). More than Chevette, and some other cars that get less gas mileage.
  • In race tune, power for the two- time SCCA C-Sedan Champion B-210. (Other race-modified Datsun engines power the Datsun B-Sedan champion 710 and 6-time C-Production titlist Datsun Z-Car.)
Transmission: Manual: 4-speed with floor gearshift. Automatic: Fully automatic 3-speed transmission with torque converter. 6-position floor selector.
Gear     Manual   Automatic
Ratio:  4-speed    3-speed
1st      3.51        2.46
2nd      2.17        1.46
3rd      1.38        1.00
4th      1.00        --
Rev      3.76        2.18
Final gear: Hypoid type. Ratio 3.89 to 1.
  • 4-speed stick standard. Optional on Vega, not available on Gremlin.
Suspension and Axle: Front: Independent strut type with coil springs and stabilizer bar. Rear: Semi-floating rear axle. Semi-elliptic leaf springs with shock absorbers.
  • Front suspension suspends car's center of gravity between two tall spring towers for good handling.
  • Front stabilizer bar helps keep the wheels on the ground in cornering.
Brakes: Power assisted front disc brakes, 9.7 in. Rear drum brakes (leading and trailing shoes), 8.0 in.
  • Tandem master cylinder system supplies braking on two wheels in case of brake failure.
  • Power assisted for easy pedal pressure; short, straight stops. (Some small cars like Chevette, Pinto and Gremlin have power assist optional at extra cost.)
Wheels and Tires: 4-1/2J-13 steel disc wheels. 6.15-13 tubeless white sidewall tires. 155-SR13 radial tires optional.
Body: All-steel unibody construction with crush zones, front and rear. Lift-up rear gate (Hatchback only).
  • Body panels crafted to fit. Dipped and painted before assembly.
  • Spare tire mounted out of the way below cargo area floor. An extra buffer in the crush zone.
Instruments: Speedometer with odometer and resettable trip odometer. Temperature gauge. Fuel gauge. Generator, oil pressure warning light.
  • Quick reading. Adjustable nighttime illumination.
  • Resettable trip odometer (an extra in many cars).
Other Standard Equipment: All-vinyl upholstery. Fully reclining front bucket seats. Electric rear window defogger. Tinted glass. Flow-through ventilation system. Full carpeting. Console box. Package tray. Glove box. Fold-down rear seat (Hatchback only). Inside hood release.
  • Standard items like temperature gauges and trip odometer that are optional on Vega, Chevette Coupe and Gremlin, not available on Pinto, Chevette Scooter.
Optional Equipment: Three-speed automatic transmission. Dealer installed, factory approved air conditioning. Rear window shade. Locking gas cap. Luggage rack. Roof rack. Radio (AM, AM/FM, stereo). Floor mats. Clock. Tachometer.
  • Relatively few options because of many no-cost extras.
  • Ask your dealer for full list of all the options engineered and approved for your B-210.
  • Performance options for Race & Rally available. Contact: Datsun Competition Department, Box 191, Gardena, CA 90247.
Dimensions & Weights
Width              60.8 in.
Min. road clearance 6.7 in.
                4-Door
Curb Weight*   Hatchback    2-Door
4-speed         2,095 lb.   2,050 lb.
Automatic       2,135 lb.   2,090 lb.
Seating            4
  • Note: California weights are slightly higher due to different exhaust emission equipment.
Datsun Saves
America's #1 Selling Import
[image: red B210 coupe, silver 280Z]
FROM THE SAME ENGINEERS WHO BROUGHT YOU THE Z-CAR.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=TOUGH_AS_IT_IS_THRIFTY"
This page has been accessed 1,002 times. This page was last modified 08:19, 20 December 2023. Content is available under Datsun 1200 Club.
