How to fit L16, L18 and L20b engines - tbc
From Datsun 1200 Club
Category: Tech Section
This is the old Tech Section article
See the updated article: L-series Engine Swap
Published by: Davo1200 , On: Sep-30-2002
NOTE: Irregularities in this article appear. This is a guide from members posts and contributions. Please help with these irregularities, so that we all know the exact process of the conversion.
Datsun L16, L18 and L20b Engine
The L16 to L18 is an uncommon swap for the Datsun1200. All though it has been done with excellent results.
The L series engines are a little heavier than an A series so handling is affected to a degree.
Aquire 1980 Stanza crossmember, lower control arms, brakes , L16, 4/5 speed box and stuts as an option.
Move x member 3/4" rearwards to allow the engine to sit as low and as rearward as possible.
Leave the sump stock.
Also brace the x-member underneath for some extra strength so it can be jacked there.
Have also redrilled x-member for the control arm mounts and plated over the area for strength. This is not needed but can be a useful time to gain some camber
Engine mounting brakets on the engine were also modified to be narrower and to allow it to sit lower than it normally would in the Stanza.
Care has to be taken with clearance to the drag link which raises as the wheels are turned. Also had to space the sway bar down about 1/2" to clear the oil pump.
The x-member to chassis mounts will have to be cut off and new ones fabricated.
(cut from user L18.b110)
Datsun L16 Engine
Bore - 83mm
Stroke - 73.7mm
Conrod - 133mm
Block Hieght - 207.85mm
Displacment -
Power - 96 - 105hp
Datsun L18 Engine
Bore - 85mm
Stroke - 78mm
Conrod - 130.5mm
Displacment -
Power -
Datsun L20b Engine
Bore - 85mm
Stroke - 86mm
Conrod - 146mm
Block Hieght - 227.45mm
Displacment -
Power -
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=How_to_fit_L16%2C_L18_and_L20b_engines_-_tbc"
This page has been accessed 7,055 times. This page was last modified 03:13, 28 July 2015. Content is available under Datsun 1200 Club.
