There is no page titled ":Detonation". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 12 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Quench (5273 bytes)
6: ...igh compression can make your engine prone to pre-detonation (pinging) which can destroy the engine. A high-qu...
52: ...tantly, the CR increase did not result in earlier detonation when the quench increased. - Nuclear Fun Run (3417 bytes)
3: ...rd the bottom of the tower you can see the yellow detonation cords going left to right. The thing was drilled ... - Crankshaft (8631 bytes)
240: * [[Pinging]] (detonation) can put massive stresses on the engine - AY12 engine (5638 bytes)
33: ... can take more compression without unintended pre-detonation (knocking or pinking/pinging) - Piston (17660 bytes)
488: Detonation (too much spark advance) causes broken ring lands...
494: Evidence of detonation can be seen in the combustion chamber: - Compression Ratio (7266 bytes)
92: * Fuel. The tendency to avoid Pre-detonation varies with the Octane rating. So while "regular"...
96: ...bore (all else being equal) is more likely to see detonation. Smaller bore means the flame quickly and complet...
108: ...exhaust runs cooler, less chance of pre-ignition (detonation). - Spark Curve (26150 bytes)
68: ...it *may* (or may not) cause overheating and/or predetonation which can break the pistons.
73: ...st muffler is loud, use {{search|Detonation+Cans|Detonation Cans}}, search google for this). - Vacuum advance (5285 bytes)
1: ...k to normal under heavy loads, thereby preventing detonation (pinking/pinging). - CCing (4389 bytes)
43: ...which causes excellent quench, thus less prone to detonation and more power. Adding bigger valves is good for ... - Turbo systems (20288 bytes)
88: ...d richer jets to keep air charge cool and prevent detonation
137: * To avoid engine-damaging detonation, keep the intake air cool via an intercooler
138: * To avoid engine-damaging detonation, keep the combustion cool via water injection
163: To make the engine survive, you gotta eliminate detonation (pinging). Then your turbo engine will last many ...
167: <blockquote class="fancy">Regardless of detonation problems water injection should be used on all bo... - Pinging (2290 bytes)
15: Engine spark knocking is is also known as '''detonation''', in British English as 'pink' or 'pinking', an...
17: ...mbustion is initiated too soon, it will result in detonation.
21: ... hear detonation (or use {{search|detonation_cans|detonation cans}}).
27: ...ustion pressure (ignition advance + compression). Detonation is usually the one that puts holes in your piston... - Speeduino (4486 bytes)
56: ...fler is loud — use {{search|Detonation+Cans|Detonation Cans}}.
