Main : Mechanical : Suspension stanza struts into B110 coupe done! w/ adjustable tops
[<   Previous  393  394  395  396  397  398  399  Next   >]
stanza struts into B110 coupe done! w/ adjustable topsPopular
SubmitterevilsimMore Photos from evilsim   Last Update2006/9/3 14:27    Tell a friendTell a friend
Hits4008  Comments2    0.00 (0 votes)0.00 (0 votes)
i had the nuts i bought from a member machined and an extra bit made (see TOP and BOTTOM in pic.. these went into the top and bottom of the adjustable strut top. very snug fit.), so the struts went in at long last. yes i can actually break properly now. all stanza bits incl control arms, struts, strut inserts, discs, calipers and 120Y control arms. had discs machined and used lowered stanza springs, which has left my front end one or two inches too high. They are king springs so now I will need to get them lowered. Toe was way way out and too much pos camber was easily adjusted out with an alan key. Strut work done by www.tweakit.com.au. Thanks greg doug and angus for yer help. took me years to get off my duff and do this. woohoo.
evilsim
Posted: 2006/9/3 14:33  Updated: 2006/9/3 14:33
 Re: stanza struts into B110 coupe done! w/ adjustable tops
when i edit a post with a picture in it, it loses the picture! thus what happened here.
go here
http://datsun1200.com/modules/myalbum/photo.php?lid=10007
boofhead
Posted: 2006/9/4 12:06  Updated: 2006/9/4 12:06
lookin the goods now
Posted: 2006/9/4 21:59  Updated: 2006/9/4 21:59
There is a bug in the Photo Album.
If you use the edit feature ()... don't be tempted to try to change the photo. If you specify the same or new photo, it will delete the existing one. So be sure to leave the "Select photo" text box empty when editing an existing photo.
evilsim
Posted: 2006/9/5 10:09  Updated: 2006/9/5 10:09
k thanx DD ill do that nxt time
