Main : Mechanical : Suspension S130 strut photo
[<   Previous  390  391  392  393  394  395  396  Next   >]
S130 strut photo
S130 strut photoPopular
Submitterdream74More Photos from dream74   Last Update2006/9/10 17:01    Tell a friendTell a friend
Hits5898  Comments4    0.00 (0 votes)0.00 (0 votes)
280zx strut with tokico illumina shock, ground control coil over, and cusco b110 adjustable camber plate.
tappet
Posted: 2006/9/13 3:30  Updated: 2006/9/13 3:30
 Re: S130 strut photo
very nice..
what rate are the springs..
is there anything apart from the "bolt on sleeve" holding the spring platform in place???
dream74
Posted: 2006/9/13 6:06  Updated: 2006/9/13 6:06
I started with 150lb rate. I have no idea what the stock 1200 spring rate is....I think bolt on sleeve should holding in place if not I just weld on it.....I still don't know the ride height until install it
tappet
Posted: 2006/9/14 10:32  Updated: 2006/9/14 10:32
i was using 250p springs in my setup..
it was very good for the track but a bit too firm for the street.. u could go a little firmer but with an a series motor it should be ok..
most likely u will find the spring platform at the bottom of the strut on the first big pothole u hit...
i had this happen when i was advised that 4 grubscrews and a bit of locktite will be sufficient.. This was from a engineer too.
i ended up welding a collar on the strut..
have a look at the first pic in the suspension section of the photo gallery.. i made this backyard strut years ago when i was still 19..
WhiteSedan
Posted: 2006/9/14 10:38  Updated: 2006/9/14 10:38
I used steel threaded sleeves so i could weld mine to teh strut. how can you weld alloy to steel?
Ive gone for 275lb springs but ive got the L-series so should be ok. I like the 280zx strut, ive been amazed how much more room you get in the wheel well compared to the stanza gear.
Moisabamf
Posted: 2007/10/12 2:43  Updated: 2007/10/12 2:43
hi im really interested in doing that same conversion to my sedan. could you give me some pointers, problems you encountered and prices? i would really appreciate it
thanks
