Main : Misc r31 coilovers
[<   Previous  4056  4057  4058  4059  4060  4061  4062  Next   >]
r31 coilovers
r31 coiloversPopular
Submitter12undiesMore Photos from 12undies   Last Update2006/9/15 7:08    Tell a friendTell a friend
Hits4249  Comments9    0.00 (0 votes)0.00 (0 votes)
pic of the struts i built they consist of short stroke adjustable koni inserts with cusco strut tops they worked out to be perfect hight
12undies
Posted: 2006/9/17 11:58  Updated: 2006/9/17 11:58
Quite a regular
 Re: r31 coilovers
yeah they r stanza control arms so i guess there stanza steering arms sorry its been a while since i did this so yu kinda forget wat r your thoughts on strut bending for more neg
PIGDOG
Posted: 2006/9/17 12:12  Updated: 2006/9/17 12:12
 Re: r31 coilovers
which part of the strut? not familiar with strut bending
isnt the good thing about the r31 struts that the stub angle is greater than other datsun struts, making you able to run bigger wheels, also giving unwanted positive camber when put in 1200s
so by bending the strut to get more camber you will be losing the advantage of lots of room
this is where you just start with struts that are the right angle
DatA15
Posted: 2006/9/17 15:57  Updated: 2006/9/17 15:57
 Re: r31 coilovers
the good think about r31 struts is you can run larger wheels but then the smallest you would want to run is 14" and then you still have to grind away at the brakes.
(you can notice if you look closely at the brakes up the top)
L18_B110
Posted: 2006/9/18 0:44  Updated: 2006/9/18 0:44
 Re: r31 coilovers
standard wheel on both R30 and R31 is 14". Shouldn't be any problem running 14" wheels over those brakes, and some 13" wheels will fit too.
12undies
Posted: 2006/9/17 11:36  Updated: 2006/9/17 11:36
Quite a regular
 Re: r31 coilovers
i had to cut about 2 inches out of the strut to fit the inserts right there just standed steering arms also were the strut bolts to the steering arm you need to put a spacer in there to locate the strut nice it can be danderous without one.wat do yu mean about lca's also? wat r your thoughts on a strut bend to give more neg camber thanks
PIGDOG
Posted: 2006/9/17 11:51  Updated: 2006/9/17 11:51
 Re: r31 coilovers
so your using standard 1200 steering arms or r31?
usually people use stanza lower control arms as this allows you to use the stanza ball joint and in turn the stanza steering arm, which r31 struts bolt to aswell
tappet
Posted: 2006/9/16 1:39  Updated: 2006/9/16 1:39
 Re: r31 coilovers
Very nice work, it should pull up pretty good with those huge discs..
show us a pic of the ride height...
also can u share a little info for the datsun crew..
is the strut shortened???
what brakes are u running??
what steering arm / lca's did u use???
PIGDOG
Posted: 2006/9/16 2:36  Updated: 2006/9/16 2:36
 Re: r31 coilovers
there are a few pics of his car that were posted not that long ago
brakes look to be standard slotted r31 discs and standard calipers
i wouldnt mind knowing which LCAs and steering arms you use
rock1200
Posted: 2006/9/16 10:11  Updated: 2006/9/16 10:11
 Re: r31 coilovers
More INFO please... LCA's, Steering arms and anything else used to fit them? please.
