Main : Mechanical : Engine A15 head exhaust port
[<   Previous  2796  2797  2798  2799  2800  2801  2802  Next   >]
A15 head exhaust portPopular
SubmitterDatsun100ATurboMore Photos from Datsun100ATurbo   Last Update2003/2/25 14:20    Tell a friendTell a friend
Hits7460  Comments3    0.00 (0 votes)0.00 (0 votes)
Here you can see a little how far you can go when you are porting your head. Don
D
Posted: 2003/2/28 2:30  Updated: 2003/2/28 2:30
From: under the Firmament LOL no twiglight effect BS
 Re: A15 head exhaust port
If I remove the valve guide peak section to help the flow do I need to use triple valve springs for valve stability??
datto_dave
Posted: 2003/2/27 9:03  Updated: 2003/2/27 9:03
i might copy this and show u what u can actually do to the port in order to get max. flow
DAVE
rally-a-coupe
Posted: 2003/7/1 10:09  Updated: 2003/7/1 10:09
100ATURBO have you cut an round port in half if you have a F**ked ond could you please cut is as i have been told by a lot of people that the round port is better that the oval this is to do with angles and flow direction
