[< Previous 2906 2907 2908 2909 2910 2911 2912 [< Previous 2906 2907 2908 2909 2910 2911 2912
| Poster |
Thread |
| Datlover |
Posted: 2003/1/25 15:37 Updated: 2003/1/25 15:37 |
Not too shy to talk   Joined: 2002/12/29 From: South Africa Posts: 23 |
 Re: V6 engine I want to ask if you could use the same downdraught webers on this engine than the ones used on the ford V6 engines?
| Poster |
Thread |
| ddgonzal |
Posted: 2003/5/12 5:04 Updated: 2003/5/12 5:04 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: V6 engine Yes, you can use the the Weber 32/36 (Holley 5200/G180) carb on this engine. This carb is sometimes used on 4.2 liter jeep engines, so the size is appropriate. Btw, this is the same picture as # 382
| Poster |
Thread |
| ca18det_man |
Posted: 2002/7/7 8:32 Updated: 2002/7/7 8:32 |
No life (a.k.a. DattoMaster)   Joined: 1999/11/25 From: Mudgee NSW Australia Posts: 1187 |
 Re: V6 engine looks like a VG20 or VG30 i have been helping a local bloke with a VG20 into a 1200 ute its fits really neat just needs the electrics (computer) and fuel system and she will be finished. cheers andrew
| Poster |
Thread |
| jaimecidpedro |
Posted: 2002/7/13 17:37 Updated: 2002/7/13 17:37 |
No life (a.k.a. DattoMaster)   Joined: 2001/8/2 From: Posts: 1354 |
 Re: V6 engine NIce job. I suppose this is what the chickenhawk will receive too,as a transplant. One question. Can this engines work with carburators,ignition system ,with no computer? Why is a computer so mandatory? I have no experience with computerized cars. Jaime
| Poster |
Thread |
| dimlight65 |
Posted: 2002/7/23 14:46 Updated: 2002/7/23 14:46 |
No life (a.k.a. DattoMaster)   Joined: 2001/2/7 From: Fort Worth, Texas, USA Posts: 1003 |
 Re: V6 engine Yes, the VG engines can be run with carburetion. However, you will need the carburetor version distributor. In the newest Nissan competition catalog they say that the Saudi Arabian Nissan Cedric came with a carbureted VG. They, Nissan Comp, sell it as well as the manifold to run a carb. Another option would be to use the Throttle body injection manifold from a V6 pickup but you will still need the distributor. Sorry, but the easiest way is to just go with the injection.
| Poster |
Thread |
| tens_and_twenties |
Posted: 2002/7/23 15:01 Updated: 2002/7/23 15:01 |
No life (a.k.a. DattoMaster)   Joined: 2001/10/15 From: Arlington, TX, USA Posts: 1305 |
 Re: V6 engine FWIW, the Chickenhawk is getting a VG33E from a 2001 Pathfinder. Same as above, only with more CC's (3.3L). And yes, EFI is probably the simplesy way. If you can find a V6 200SX in the JY, it'll have the best intake manifold, and the harness/ECU from an '84-87 300ZX (ECCS system) will be the easiest to hook up. It's not the greatest from a performance standpoint(the 88-90 are a shade better), but you are only talking about the difference between 180hp and 190hp..... in a 2000lb car.....
| Poster |
Thread |
| dattoman_1000 |
Posted: 2002/10/19 15:59 Updated: 2002/10/19 15:59 |
No life (a.k.a. DattoMaster)   Joined: 2002/8/11 From: Perth Posts: 2692 |
 Re: V6 engine I don't know 100% which this engine is but I do know the car. It was orig fitted with a VG20 to get rego and then that was removed and fitted with a VG30. Its a beaut ute and goes great. Used to owned by one of my customers......we helped with the brakes on it. He recently sold it and went overseas.......damn shame...wish I knew it was for sale. I would have bought it myself.
| Poster |
Thread |
| da-feral |
Posted: 2003/1/5 21:43 Updated: 2003/1/5 21:43 |
Just popping in   Joined: 2002/12/12 From: Millgrove Victoria Oztralia Posts: 17 |
 Re: V6 engine With an easy 250 hp and 240 ft/b torque available from the VG30 that would make a very interesting weapon. Pity about the weight of the engine box combination though. I imagine it would have horrible understeer? Cheers Feral Errol
| Poster |
Thread |
| dimlight65 |
Posted: 2003/1/6 16:20 Updated: 2003/1/6 16:20 |
 Re: V6 engine Erroll, I'll let you know after I get the VG-33 powered Chickenhawk II back on the road. Of course, it is at least third in line after a few other projects.
| Poster |
Thread |
| ddgonzal |
Posted: 2003/1/7 7:22 Updated: 2003/1/7 7:22 |
 Re: V6 engine dimlight, you realize you are approaching the boundary of "why did he put such a big heavy engine in such a balanced, well handling car?" ... oops, you've crossed it. Seriously though it sounds like a grand project. isn't the VQ35 an all-aluminum 3.5 Nissan V6 ... hmmm ...
| Poster |
Thread |
| dimlight65 |
Posted: 2003/1/7 15:58 Updated: 2003/1/7 15:58 |
 Re: V6 engine Yeah, yeah, I know, big heavy blah blah in a well balanced blah blah... Thing is, when you find a crash test car's engine, with SEVEN miles on the clock, for $100, you jump on the Mo-Fo! Hell, I'll put ballast in the car to get the front to rear weight balance back if I have to. Besides, I still have George (the turbo A-13 car) if I want to turn!
| Poster |
Thread |
| dimlight65 |
Posted: 2002/7/5 15:19 Updated: 2002/7/5 15:19 |
 Re: V6 engine Sweet! Now bolt on a pair of three barrel down draft Weber IDA like the Porsches used on the flat sixes!
| Poster |
Thread |
| rally-a-coupe |
Posted: 2002/7/6 5:13 Updated: 2002/7/6 5:13 |
Home away from home   Joined: 2002/4/1 From: Christchurch New Zealand Posts: 417 |
 Re: V6 engine what is the motor out of
