Main : Mechanical : Body and Interiors 120Y van Stage II SIDE VIEW
[<   Previous  3979  3980  3981  3982  3983  3984  3985  Next   >]
120Y van Stage II SIDE VIEWPopular
SubmitterFAZPIOESMore Photos from FAZPIOES   Last Update2006/11/1 13:49    Tell a friendTell a friend
Hits4771  Comments12    0.00 (0 votes)0.00 (0 votes)
jaimecidpedro
Posted: 2006/12/30 1:05  Updated: 2006/12/30 1:05
 Re: 120Y van Stage II SIDE VIEW
I like this estate....it is cool.
beattie
Posted: 2006/12/30 5:03  Updated: 2006/12/30 5:03
What did you use to make the side indicators clear? I know the Z boys will be interested because they share the same lens setup.
A 2 door wagon? never seen one of them before... well i dont think so!
jaimecidpedro
Posted: 2006/12/30 6:56  Updated: 2006/12/30 6:56
The 2 door wagon is called a Van. The four door wagon is the Estate/ Station wagon
Correct me if wrong...I guess that is it. The vans were common in UK
Mawler1
Posted: 2006/12/30 13:16  Updated: 2006/12/30 13:16
120Y station Wagons (4 door vans) were quite common: but the sedans were/are preffered as the Vans (both styles have 4 wheel drums and Lung punchers (non collapsable steering columns as they had 3 on the tree (column Shift 3 speed manual)
the 2 door vans are VERY rare.... and The 2 door wagons are even rarer still!!
if I could find a nice 2 door van I'd go through the "pus and pain" of setting one up with stanza struts and a L18! (pref. SSS spec!)
FAZPIOES
Posted: 2006/12/30 15:38  Updated: 2006/12/30 15:38
SITE INDICATORS CLEAR - I didn
Posted: 2006/12/31 1:13  Updated: 2006/12/31 1:13
This is a picture of a VB210 -- V for Van. In Japan are wagons are called "van". You might be thinking about "panel van" which has no windows on the rear sides.
There were 2-dr and 4-dr vans for Datsun 1200, I dunno about B210s though.
See our Club wiki [url=http://wiki.datsun1200.com/index.php/Wagon[/url]. "Estate Wagon" I think is a British English term. In America we rarely say that, more often "Station Wagon" or just wagon.
Tyrie
Posted: 2006/12/31 2:25  Updated: 2006/12/31 2:25
Poster: Mawler1 Date: 2006/12/30 23:16:57
so whats the difference between a 2door wagon and a 2door van??? If a 4door wagon is a 4door van???
my one (same as pictured, but more rust ) was stock standard and had disk brake front and 4speed floor shift.
Mawler1
Posted: 2006/12/31 3:26  Updated: 2006/12/31 3:26
4 door van - oops they don't exist..
the 2door van/stationwagon is the same bodystyle... just the wagon has factory fitted side windows (slightly larger than the aftermarket ones...)
I thought the vans/stationwagons were base models... Ie. no stainless trim, no carpet, no radio, no ciggy lighter, and had the mechanical differences I mentioned before...
Posted: 2006/12/31 4:10  Updated: 2006/12/31 4:10
There is *no* difference between a 2-dr van and 4-dr van except ... two doors. The B110 (Datsun 1200) came in both versions. Take a look at the pictures.
4-dr van.
2-dr van.
jaimecidpedro
Posted: 2006/12/31 6:45  Updated: 2006/12/31 6:45
I did not know how numerous the 2 door "vans" were. It is kind of strange, a 2 door wagon/van/estate/station wagon....that limits access to the rear area....but perhaps I see it that way because it is really unusual to me.
Posted: 2006/12/31 7:16  Updated: 2006/12/31 7:16
I guess you are too young to remember Chevrolet Nomad wagon, Ford Pinto wagon, and Chevy Vega wagons. All were 2-dr wagons and extremely popular. The little ones sold millions, while the Nomad is now a very desired collector item.
Mawler1
Posted: 2006/12/31 7:41  Updated: 2006/12/31 7:41
never seen a pinto or a vega... but the 1955-1957 nomads are cool!...
the nomad specific parts are worth a fortune... so if an incomplete one shows up at the nearest swapmeet.... RUN!
FAZPIOES
Posted: 2006/12/31 16:00  Updated: 2006/12/31 16:00
DATSUN 120Y VAN 2DR - serial references :
- ENGINE : A12 (with a bigger Carb than 1200 )
- BRAKES : Rear- DRUMS - Front - DISKS
- FRONT SITS : reclinable and run to the front so rear passangers have a better access
- REAR SITS : both parts reclinable - changing Car into a Van
- MIDDLE WINDOWS - open to the sides
