Main : Members : PIGDOG r31 discs on h165
[<   Previous  110  111  112  113  114  115  116  Next   >]
r31 discs on h165
r31 discs on h165Popular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2006/11/29 1:44    Tell a friendTell a friend
Hits3238  Comments8    0.00 (0 votes)0.00 (0 votes)
showing the little clearance under 14s, dont know how close the handbrake doover actually is
WhiteSedan
Posted: 2006/11/29 7:52  Updated: 2006/11/29 7:52
 Re: r31 discs on h165
PIGDOG, does all that handbrake gear come off with just that 12-14mm bolt? I like this setup much more than the bluey with those heavy disc over drum things.
PIGDOG
Posted: 2006/11/29 8:01  Updated: 2006/11/29 8:01
if you arent planning on running a handbrake, just get some commodore rear calipers as they are the same just without the built in handbrake and they arent finned
EDIT: you can also see the two bolt holes that dont match up
WhiteSedan
Posted: 2006/11/29 8:20  Updated: 2006/11/29 8:20
Yeah gonna run a hydraulic handbrake. What model commo calipers fit up? Wonder if any vented disc and caliper combo will bolt up?
PIGDOG
Posted: 2006/11/29 8:29  Updated: 2006/11/29 8:29
r32 discs are vented, dont know if the 4 stud non turbo ones are
maybe s13 rears, could be vented
then go for r32 twin piston rear calipers
oh yeah vn calipers will replace the skyline ones if a handbrake isnt wanted
WhiteSedan
Posted: 2006/11/29 8:32  Updated: 2006/11/29 8:32
Im sensing another spending spree this weekend,
Edit: This is the datsport R32 setup for 1600's, they have redrilled the discs.
PIGDOG
Posted: 2006/11/29 8:39  Updated: 2006/11/29 8:39
well if you get some r32 calipers, feel free to send them over to me and ill see if i can get them to fit
WhiteSedan
Posted: 2006/11/29 8:45  Updated: 2006/11/29 8:45
This is brakets that datsport does for R31 calipers on a 1600, they have to be bolted and then welded.
PIGDOG
Posted: 2006/11/29 8:49  Updated: 2006/11/29 8:49
all i need to know is the bolt spacing of r32 calipers and then i should be able to figure out the rest
not that new rear caliper brackets are at all hard to make
i think ill have another look at datsports setup and get an idea of the disc offset and caliper offset
