Main : Mechanical : Engine AFR display
[<   Previous  2187  2188  2189  2190  2191  2192  2193  Next   >]
AFR display
AFR displayPopular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2006/12/6 9:33    Tell a friendTell a friend
Hits2403  Comments5    0.00 (0 votes)0.00 (0 votes)
perfect idle tune!!
Posted: 2006/12/7 13:49  Updated: 2006/12/7 13:49
 Re: AFR display
It seems to be off by 0.1
Mildman
Posted: 2006/12/7 14:28  Updated: 2006/12/7 14:28
 Re: AFR display
Although as it seems to idle at 6000rpm.....
BAD310
Posted: 2006/12/7 16:51  Updated: 2006/12/7 16:51
 Re: AFR display
I was thinking that to Mildman, but that might be his shift point, maybe.
pager
Posted: 2006/12/7 17:40  Updated: 2006/12/7 17:40
 Re: AFR display
good stuff!! considering its a carby engine
datsik
Posted: 2006/12/7 19:22  Updated: 2006/12/7 19:22
 Re: AFR display
its an early type of "recall" dial...it shows the max RPM reached.
Grunterhunter
Posted: 2006/12/19 0:06  Updated: 2006/12/19 0:06
 Re: AFR display
Nothing that fancy, just a Speco tacho with a adjustable second needle for your redline.... also as an adjustable light that you can set to come on.
I stand corrected- almost perfect idle tune. At idle it tends to fluctuate from 14.5 to 15 with an occcasional spilke to 12 or so when there is a misfire. the other interesting thing is watching your mixtures change (idle and under power) at night when it cools down, or when the engine bay is hot on a hot day, etc. It teaches you a lot about how carbies work- finding the point when different circuits start to work, the effects of changing your air correctors. I still dont know how accurate it is but to understand relative changes its a really useful bit of gear.
