Main : Misc a14 powered plymouth cricket
[<   Previous  3625  3626  3627  3628  3629  3630  3631  Next   >]
a14 powered plymouth cricketPopular
Submittermikeys_toyMore Photos from mikeys_toy   Last Update2006/12/20 3:52    Tell a friendTell a friend
Hits3010  Comments5    0.00 (0 votes)0.00 (0 votes)
modded A14, 60 series trans
muppet
Posted: 2006/12/20 8:56  Updated: 2006/12/20 8:56
Quite a regular
 Re: a14 powered plymouth cricket
Got any engine bay shots, how easy was the conversion, as I might be able to convince a mate to do the same conversion with his Avenger.
mikeys_toy
Posted: 2006/12/21 6:17  Updated: 2006/12/21 6:17
motor mounts were almost a bolt in, I used the datsun throttle linkage, the datsun trans mount had to be widened and bolted to the floor; the original bolt holes couldn't handle any offset without tearing.
the hardest thing was the clutch linkage; the Hillman used a cable, datsun has a hydraulic linkage, i used a '80 honda prelude master cylinder bolted to a bracket welded to the pedal box with a remote reservior. I also had to have a custom driveshaft made and move the shifter hole back slightly
LittleFireyOne
Posted: 2009/4/21 2:06  Updated: 2009/4/21 2:06
That would be easier for us then cos our 60 series use cable clutch
Tyrie
Posted: 2006/12/20 3:55  Updated: 2006/12/20 3:55
I like I like
hate to have to drive it around that low, but it sure looks cool.
What did they have in them originally?
A14force
Posted: 2006/12/20 8:45  Updated: 2006/12/20 8:45
These were known as an avenger in NZ/Aust/UK.
The original running gear was sh1t. A nissan transplantn would make it into a good car.
