Main : Misc : Tech Section ported gx
[<   Previous  319  320  321  322  323  324  325  Next   >]
ported  gx
ported gxPopular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2006/12/20 12:41    Tell a friendTell a friend
Hits3091  Comments6    0.00 (0 votes)0.00 (0 votes)
this work was not done buy me, the previous owner ported the head. a little too mutch , i think.
killer1200
Posted: 2006/12/20 15:43  Updated: 2006/12/20 15:43
 Re: ported gx
here it is,
i dont know what im gonna do to the head, im not in that stage for now.
what do you think of the ports?
They look fairly good, but dont look totally matched.
There are a couple of very cheap and easy things to do to find out if the person knew what he was doing.
1. Go down to your local chemist and get a couple of syringes one thats about 20mls and one that has .1 increments which is normally about 3mls.That will cost all of $1.Then put some grease on your valves to make a water tight seal. Then it's just a matter of filling them up.They should all be the same.
2.Simple get out a rule and measure the ports.
3. Not as cheap as the first 2, but get your head flowed this will also give you a inlet to exhaust port raito. Different people have different ideas on what it should be, but you want your exhaust port to flow about 80% of your inlet. This will also help with picking a cam.
It
DatsunSSS
Posted: 2006/12/20 21:46  Updated: 2006/12/20 21:46
 Re: ported gx
here it is.
Thanks man, im gonna follow your advice.
What you think about the combustion chamber?
killer1200
Posted: 2006/12/21 6:45  Updated: 2006/12/21 6:45
 Re: ported gx
Again they dont look to bad but measure them again with the syringes.
That centre combustion chamber looks like it's been welding a little bit and the inlet seat doesnt look 100% right.(Note the little gap on the spark plug side where the inlet and exhaust seats meet)
I dont know how much work you want to put in, but you can finish the inlet with 80 grit sand paper.That will give about the perfect finish for power.However the Hp gain from a mirror finish and the perfect finish for power(A little bit rough)is only about 1% so it's not really this big myth that everyone talks about.
Where you want the mirror finish is your exhaust port if your a perfectionist the last grade of sand paper you'll use is 1200 grit.
This helps keep heat off the exhaust port and stops carbon sticking to the port.
You also want to do the same mirror finish in the combustion chamber it's self.
You'd really only do this stuff for a race car, but it still works the same on a road car.
Posted: 2006/12/21 6:58  Updated: 2006/12/21 6:58
 Re: ported gx
killer1200
Posted: 2006/12/21 7:23  Updated: 2006/12/21 7:23
 Re: ported gx
Thanks DD if i'd have known that was there It would have saved me sometime.
DatsunSSS
Posted: 2006/12/21 20:32  Updated: 2006/12/21 20:32
 Re: ported gx
thanks killer , you were very helpfull to me.
My mechanic is helping me and teaching me at the same time, he is a very good mecanic. He have one competition shop, but i dont know how we gonna do to make the head better.
can you explain how or were i can do a "head flow" ?
Can you say what you have done to your engines-? and what hp you get.?
thanks
americo
