Main : Misc : Forum silvia brake conversion
[<   Previous  298  299  300  301  302  303  304  Next   >]
silvia brake conversionPopular
SubmitterChassis_slappin_1200More Photos from Chassis_slappin_1200   Last Update2006/12/21 4:18    Tell a friendTell a friend
Hits2453  Comments7    0.00 (0 votes)0.00 (0 votes)
I think i have it this time
Posted: 2006/12/25 21:35  Updated: 2006/12/25 21:35
From: whakatane, but most of the time canterbury NZ
 Re: silvia brake conversion
The sr20det calipers are four pots and have nissan cast into the front as well. these may be the same caliper as the turbo r32 skylines? mine are just na sr rotors off a s14 silvia.
Mildman
Posted: 2006/12/25 23:43  Updated: 2006/12/25 23:43
This caliper was available on R32 Skylines (mostly on non-turbo models) they seem very familiar as my R32 GTSt had these brakes on it too.
Daveman
Posted: 2006/12/26 3:09  Updated: 2006/12/26 3:09
Not too sure what the rest of you mean, but the SR20 silvia's did NOT have the 4 spot calipers with NISSAN cast into the front of them. You may have, however, seen several silvia's getting round with them on because it's a fairly simple bolt on upgrade on an S13.
All it takes is the R32 gtst 4 piston caliper and the R33 non turbo 4 stud disc and this all bolts straight onto an S13 hub assembly.
mad120y
Posted: 2006/12/21 8:29  Updated: 2006/12/21 8:29
Now all you have to do is work out how to mount that that big vice to the car :P
john_13961
Posted: 2006/12/21 9:29  Updated: 2006/12/21 9:29
not to mention the counter weight u will have to run on your wheel lol
BAD310
Posted: 2006/12/23 14:32  Updated: 2006/12/23 14:32
They are the CA calipers aren't they? I think the SR calipers have NISSAN set into the front face of them, same as the R32, Z32 and 300ZX ones i think.
2QK4U
Posted: 2006/12/23 14:55  Updated: 2006/12/23 14:55
CA and SR calipers looks the same but different size and different disc diameter. skyline Z32 etc are the sumitomo 4 piston ones you see with the nissan stamped on them, they also vary on the thickness of disc they cant take, Z32 brakes take a thicker disc.
