Main : Misc need a little help water pump
[<   Previous  3346  3347  3348  3349  3350  3351  3352  Next   >]
need a little help water pumpPopular
SubmitterStumpedMore Photos from Stumped   Last Update2007/2/15 23:51    Tell a friendTell a friend
Hits1412  Comments3    0.00 (0 votes)0.00 (0 votes)
this would be the pump I am trying to get
Stumped
Posted: 2007/2/18 11:00  Updated: 2007/2/18 11:00
 Re: need a little help water pump
it's an aluminum casting, and the reason it leaks is because the Bering's let go, she had a wobble in it.
I found the part. We ordered for a L1600 1971 510 water pump.
Thank you for the help
Greg
Tyrie
Posted: 2007/2/16 3:39  Updated: 2007/2/16 3:39
Dont the paddles/blades/whatever they're called wear out? those look like new?
Posted: 2007/2/16 3:54  Updated: 2007/2/16 3:54
They are usually cast iron. Sometimes they get corroded, but they don't technically wear out.
Usually the shaft bearing wears out, and other get loose, makes noise or leaks coolant.
