Main : Mechanical : Body and Interiors LHD indicator stalk and hazard switch
[<   Previous  4248  4249  4250  4251  4252  4253  4254  Next   >]
LHD indicator stalk and hazard switchPopular
SubmitterdattodudeMore Photos from dattodude   Last Update2003/4/9 9:59    Tell a friendTell a friend
Hits8625  Comments8    0.00 (0 votes)0.00 (0 votes)
LHD indicator stalk and hazard switch.
Not sure what I'll do with them..
1200rallycar
Posted: 2003/4/9 11:24  Updated: 2003/4/9 11:24
 Re: LHD indicator stalk and hazard switch
does anyone (aussie) have a hazard swith on there 1200 from factory, just wondering cause my 3 dont have em and ive never seen one?
B120dat
Posted: 2003/4/9 14:28  Updated: 2003/4/9 14:28
i have a hazard light switch on my 1200 (1980, ute )
Posted: 2003/4/9 21:52  Updated: 2003/4/9 21:52
The US 1200s (71-73) have the hazard light switch as in this photo. It's placed on top of the steering column, behind the wheel.
dattodude
Posted: 2003/4/10 8:33  Updated: 2003/4/10 8:33
I will have one..That's why I bought it...
Is there a dress bezel that fits over the top?
I'll have to talk to Nissan about that. I'd also like to get a LHD column cover. I might want to put the blinker stalk on the other side, just to be different.
Chris.
Posted: 2003/8/24 0:38  Updated: 2003/8/24 0:38
Here's the cover:
2136
2142____
dattodude
Posted: 2003/8/26 7:30  Updated: 2003/8/26 7:30
David,
That's the way..now it makes more sense. The LHD ones don't have 2 holes. ie. one for the hazard switch to poke through, and the other for "who knows what".
If you see the picture of the hazard switch unit, you'll see that the metal bracket has 2 holes in the other other end, this is to hold more switches for a purpose unknown to me.
In the RHD models the plastic casing that goes around the steering column has 2 holes in it, and for models without a hazard switch, it has a plastic plug/bezel piece that clicks into the 2 holes on the top of the casing. So the LHD models don't need something to fill the second hole, because the LHD model only has one hole for the hazard switch to come through.
I hope this explains what I was going on about.
So, after I've fitted the hazard switch, I need to cleanly cut out a rectangular piece of thin black plastic sheeting and glue it over the "extra hole" and have it present the hazard switch in a factory like way.
Cheers,
Chris
Posted: 2003/8/26 8:33  Updated: 2003/8/26 8:33
I wonder what those extra holes are for. This JDM picture shows the "something" is there -- but it's not clear enough to make out what it is:
JDM B110 GX Coupe
I notice it this GX also has plastic around the the ignition key cylinder ... a rear defrost knob ... and what appears to a separate radio console to the left of the main console.
2129 GX trim
Here are some regular RHD models, I see the plastic column cover is shaped more bulkily than the LDH cover.
765
978
Posted: 2009/5/25 8:57  Updated: 2009/5/25 8:57
OK, the extra two holes in the Hazard switch metal bracket are for "Parking" switches, all the JDM models had this. Not sure how it was use in operation.
As noted, the USA upper cover only had a hole to let the one Hazard button show, while JDM upper cover was cut for all three buttons.
The T/S switch is same RHD and LHD. It clamps to the column, so can be rotated 180 degrees.
