Main : Members : LAGWAGON ecu and bits mounted under the glovebox
[<   Previous  26  27  28  29  30  31  32  Next   >]
ecu and bits mounted under the gloveboxPopular
SubmitterLAGWAGONMore Photos from LAGWAGON   Last Update2007/3/18 7:11    Tell a friendTell a friend
Hits2592  Comments6    0.00 (0 votes)0.00 (0 votes)
gotta tidy up a little but it works now :)
Curtis
Posted: 2007/5/4 13:58  Updated: 2007/5/4 13:58
 Re: ecu and bits mounted under the glovebox
Lagwagon. why is the igntion module not hooked up?? is that one hanging in the air?? was one blown?? Dont happen to know how much they are new do you?? im im just reseraching atm but i gess they just boost the ecu signal. any info will be of much help cheers.
Posted: 2015/5/2 1:31  Updated: 2015/5/2 6:25
The ignitor is just a transistor ignition unit. It takes four low-current inputs and outputs high current for the coils.
22020-85M10 TRANSISTOR IGNITION UNIT Mitsubishi
* 1987-1988 KN13 USA "Sentra XE" CA16DE/CA18DE
* 1987-1988 N13 Pulsar NX CA16DE/CA18DE
* 1990-1994 Q45 V8
22020-60U00 TRANSISTOR IGNITION UNIT Hitachi
One input plug has 5-wires -- 4 inputs low current triggers. The odd pin is for ground/earth.
The other plug has 4 high current outputs to the four coils.
The SR unit is smaller, newer but works the same way.
* Nissan 22020-50F00 'DIS4 04'
A common, cheaper replacement is the Bosch 211 Ignitor, used by many cars for example VW/Audi.
See Coil On Plug
gx1200
Posted: 2007/3/18 19:03  Updated: 2007/3/18 19:03
Is that an aftermarket fuse block or was it "borrowed" from something else???
Cheers. Adam.
blofly
Posted: 2007/3/19 1:37  Updated: 2007/3/19 1:37
cool.... it is already neat and tidy! as long as the wires don't get around my feet I am happy
Are you happy with the engine conversion?
LAGWAGON
Posted: 2007/3/19 5:24  Updated: 2007/3/19 5:24
the fuse block is a newy from good ol supercrap auto, and yes i'm happy with the conversion so far. i tried to take a bit more time than i usually do and make things nice
dattodude
Posted: 2007/3/19 5:59  Updated: 2007/3/19 5:59
Don't get the wires hooked up in the windscreen wiper mechanism either. I thought I'd blown a fuse when I'd turned on the wipers...turns out they wiper arm ripped the wires out of the relay box.
