Main : Members : B120dat Decomp Plate
[<   Previous  22  23  24  25  26  27  28  Next   >]
Decomp Plate
Decomp PlatePopular
SubmitterB120datMore Photos from B120dat   Last Update2007/5/15 19:23    Tell a friendTell a friend
Hits2284  Comments6    0.00 (0 votes)0.00 (0 votes)
Pic of it.
muppet
Posted: 2007/5/16 16:47  Updated: 2007/5/16 16:47
Quite a regular
 Re: Decomp Plate
How thick is the plate and where did you get it from, also what is it made from?
B120dat
Posted: 2007/5/22 11:33  Updated: 2007/5/22 11:33
 Re: Decomp Plate
Just seems to be made of steel mate. I didnt measure it, the guy who built the motor i used it from said it was desgined to drop the compression one point. Its about 1mm thick i think.
1200GXman
Posted: 2007/5/22 14:00  Updated: 2007/5/22 14:00
 Re: Decomp Plate
Why a decompression plate?
Here in South Africa we have a quality gasket manufacturer called Payon. I can get a custom made head gasket of max thickness of 3mm. With a decomp plate I would feel there is a extra place where it can blow through(between block and decomp plate,between decomp plate and gasket or between gasket and head).
With only head gasket it will be between block and head gasket or head gasket and head.
Just a thought. Curious what you guys think about a extra thicker head gasket.
sidedraught
Posted: 2007/5/15 20:13  Updated: 2007/5/15 20:13
 Re: Decomp Plate
I have heard of carbon buildup causing hotspots and detonation with a plate, any truth to that?
converted
Posted: 2007/5/16 5:22  Updated: 2007/5/16 5:22
 Re: Decomp Plate
Jeff thought a decomp plate was the way to go. Carbon buildup due to inefficient fuel burning is the reason to detonation.
B120dat
Posted: 2007/5/16 6:47  Updated: 2007/5/16 6:47
 Re: Decomp Plate
This Plate was designed to drop compression one point for stock Aseries.
