Main : Mechanical : Engine Fiesta parts.....loool
[<   Previous  2184  2185  2186  2187  2188  2189  2190  Next   >]
Fiesta parts.....looolPopular
SubmitterLottoMore Photos from Lotto   Last Update2007/5/16 6:50    Tell a friendTell a friend
Hits6725  Comments28    0.00 (0 votes)0.00 (0 votes)
this is from a Ford Fiesta 1.1(electronic),  NGK BPR9EG and also Lucas sport iignition coil 40Kv.
It
Lotto
Posted: 2008/1/29 21:30  Updated: 2008/1/29 21:30
 Re: Fiesta parts.....loool
check the electronic module
Posted: 2008/4/14 6:02  Updated: 2008/4/14 6:02
UK Fiestas got electronic ignition starting in 1986 (Fiesta Mk II). This engine is the famous Kent design, which was even sold in USA. The Fiesta uses the Valencia fwd variation of Kent engine.
Only $210 pounds at Burton.
I wonder why the distributor fits the Datsun engine... must be some historical reason dating back to Austin?
Lotto
Posted: 2007/5/16 18:20  Updated: 2007/5/16 18:20
any one can do this........looool only 3 wires
rventura
Posted: 2007/5/16 18:43  Updated: 2007/5/16 18:43
Ok, muito obrigado!
Eu julgava que era necessario um sistema "transistorizado" para "controlar" este sistema.
Vou tentar implementar isto.
Bandit_blues
Posted: 2009/4/6 10:34  Updated: 2009/4/6 10:34
Can someone tell me if we can use the datsun coil? I didn`t understand the wiring yet.
Posted: 2009/4/6 19:56  Updated: 2009/4/6 19:56
Yes, you can use the Datsun coil. With the Datsun 1200 coil, be sure to use the ballast resistor too.
Posted: 2011/6/16 1:08  Updated: 2011/6/16 1:08
this is a Diesel version
A diesel with a distributor? Sorry, I don't understand.
Which Fiesta series (approximate years) is this from?
Ford Festiva is a Korean car
Ford Fiesta is Ford Europe car
wolki101
Posted: 2011/6/16 2:01  Updated: 2011/6/16 2:01
last post was in 2008, good luck getting a reply now haha
WhiteSedan
Posted: 2007/5/16 14:05  Updated: 2007/5/16 14:05
Cool mod, Is this a ford laser here? Got a engine model no.?
rventura
Posted: 2007/5/16 14:28  Updated: 2007/5/16 14:28
Boas, j
Whorida
Posted: 2007/5/16 14:51  Updated: 2007/5/16 14:51
Looks more like a Ford Festiva.
LittleFireyOne
Posted: 2007/5/16 16:25  Updated: 2007/5/16 16:25
Well Bam my Lamb, I work at Ford!! I'm going to have to keep a lookout for these parts now.
I'll go get the price for that peice tomorro and post it up later
TnPshow
Posted: 2007/5/16 17:48  Updated: 2007/5/16 17:48
Could this be similar to a Mazda 121 shades me wonders?
Whorida
Posted: 2007/5/16 17:50  Updated: 2007/5/16 17:50
Every chance, similar year, same company (almost), would have used same parts.
Curtis
Posted: 2007/5/16 13:43  Updated: 2007/5/16 13:43
great mod... can u tell me if its a hall effect setup??? cheers
Lotto
Posted: 2007/5/16 7:51  Updated: 2007/5/16 7:51
Loooool this is a Diesel version...looool but it looks the same
Lotto
Posted: 2007/5/16 7:50  Updated: 2007/5/16 7:50
Fiesta1.1 from Portugal
TnPshow
Posted: 2007/5/16 7:02  Updated: 2007/5/16 7:02
Do you have a picture of the Fiesta?
This sounds like a good conversion Lotto!
Lotto
Posted: 2007/5/16 7:39  Updated: 2007/5/16 7:39
It
Lotto
Posted: 2007/5/16 7:44  Updated: 2007/5/16 7:44
see the next photo it
pitanando
Posted: 2007/5/17 3:18  Updated: 2007/5/17 3:18
Boas!!! tudo bien!?
what is the difrence in this setup to the sst one?
Lotto
Posted: 2007/5/17 17:34  Updated: 2007/5/17 17:34
Imagina uma recta em que a 4
LittleFireyOne
Posted: 2007/5/17 17:49  Updated: 2007/5/17 17:49
I asked about how much these distributors are and typical Ford doesn't even sell them here anymore. PFFFT
Lotto
Posted: 2007/5/18 21:39  Updated: 2007/5/18 21:39
It cost me 20 euros in the scrap yard, it
pitanando
Posted: 2008/1/26 23:18  Updated: 2008/1/26 23:18
Hi lotto! i have maneged to get one like yours, but it dosen
beattie
Posted: 2008/1/27 0:10  Updated: 2008/1/27 0:10
We never got a 1.1 Ford/Mazda engine over here in aust. i think they started with 1.3 here. Could be the same.
I know all the insides of my dizzy was out of a early 323 or 626 so maybe thats the same dizzy? We have a couple of old SOHC Mazda/Ford engines out the back of work. Ill nick a dizzy and see hoe compatable they are. Could be an alternitive to the E series dizzy
Lotto
Posted: 2018/9/13 23:21  Updated: 2018/9/13 23:21
Well, first the car is still running, after all these years, but it was in vegetative state for at least 6 years, I've broken the engine because lean mixture......but it was an excuse for a major rebuilt. Now it's an 1300cm3 full balanced engine, but that's for a other topic.
Regarding de distribution it still running with the ford part, the transformation it's easy, you have to cut the main shaft because the Ford engine uses a longer one, then you make another hole for the pin of the Datsun sprocket.....and don't need balastre, connected direct to the H voltage coil.
See my videos on YouTube, search for HLotto
Posted: 2018/9/15 23:46  Updated: 2018/9/15 23:46
É bom ouvir uma atualização sobre o carro
VIDEO: Datsun 1200 with bike carbs stage 2
