Main : Misc Dyno monitor
[<   Previous  2837  2838  2839  2840  2841  2842  2843  Next   >]
Dyno monitor
Dyno monitorPopular
SubmitterkululadotgroenMore Photos from kululadotgroen   Last Update2007/6/7 12:49    Tell a friendTell a friend
Hits2409  Comments8    0.00 (0 votes)0.00 (0 votes)
Picture I took of the dyno's monitor. Was noisy and windy and dark so the pic didn't really come out nice
greendog
Posted: 2007/6/9 12:24  Updated: 2007/6/9 12:24
 Re: Dyno monitor
196hp this is from the 4agze i guess?
kululadotgroen
Posted: 2007/6/12 7:37  Updated: 2007/6/12 7:37
 Re: Dyno monitor
Yes it's the 4agze, but I removed the SC and replaced it with a turbo. O, and that's at the wheels...
EDIT: Thread of car if you wanted to see some vids of the dyno run, my 1200 thread.
bennykb10
Posted: 2007/6/12 7:39  Updated: 2007/6/12 7:39
 Re: Dyno monitor
time to turn up the boost to get it to 200 hp
kululadotgroen
Posted: 2007/6/12 7:44  Updated: 2007/6/12 7:44
 Re: Dyno monitor
Mmmm, I'm running 0.8 bar atm. We got 184hp, and the guy said that my exhaust is very restrictive(it's 2.5"), he removed the lambda and CO things from the tailpipe, did another run and got 196hp. He says that I would probably get 20-30hp more by just changing to a 3" pipe. Should'a listened to all the advice... Will wait(read save) a bit, and get a 3" mandrel bent pipe fitted. For now it's ok, and I have the prospect of relatively cheap power upgrades to look forward to...
bennykb10
Posted: 2007/6/12 7:48  Updated: 2007/6/12 7:48
 Re: Dyno monitor
does it have stock internals? thats it go the 3 inch straight threw
kululadotgroen
Posted: 2007/6/12 8:02  Updated: 2007/6/12 8:02
 Re: Dyno monitor
Yes stock internals, I can go some way still before reaching the end of their tethers. There are people driving around with 370kw on stock. Ok some wires and ARP studs are employed to keep the head and block from parting, but other than that stock.
Tyrie
Posted: 2007/6/12 8:46  Updated: 2007/6/12 8:46
 Re: Dyno monitor
have a look for wogboy's setup on here, he was planning to run 25-30psi every day in his, cant remember if it was standard or not, but even a standard one should handle over 20psi no worries
Burke_a_lot
Posted: 2007/6/12 10:02  Updated: 2007/6/12 10:02
 Re: Dyno monitor
196HP! not bad at all, better than my 76HP@6200rpm (get my dyno runs 4 free)
