Main : Misc My new thermo fan switch housing
[<   Previous  2836  2837  2838  2839  2840  2841  2842  Next   >]
My new thermo fan switch housingPopular
Submitter1200GXmanMore Photos from 1200GXman   Last Update2007/6/8 12:13    Tell a friendTell a friend
Hits5141  Comments13    0.00 (0 votes)0.00 (0 votes)
Just got this from the local engineer.Custom made for the thermo switch.
Supremo
Posted: 2010/9/3 11:29  Updated: 2010/9/3 11:34
Quite a regular
 Re: My new thermo fan switch housing
Thank you, and it makes perfect sense.
Posted: 2010/9/4 2:52  Updated: 2010/9/4 2:52
Nissan put them in the bottom hose.
There were two different temperature switches for the bottom hose location:
* 21595-M0206 SWITCH-THERMOMETER ON 85-90C
* 21595-M4961 SWITCH-THERMOMETER ON 72-75C
Supremo
Posted: 2010/8/31 14:38  Updated: 2010/8/31 14:38
Quite a regular
Like the idea, i just want to know will it matter where you put a housing like that, or should it go on to the bottom pipe from the stock radiator?.
1200GXman
Posted: 2010/9/1 8:05  Updated: 2010/9/1 8:05
Top pipe is better.
It will then pick up that the water coming from the head is too hot and switch on the fan. The bottom hose is water coming from the radiator that has already been cooled. If this is still hot enough to switch on the fan if the switch is in the bottom hose, it might be already too hot for the engine.
Cable_Tie
Posted: 2007/6/9 20:53  Updated: 2007/6/9 20:53
A bit of thread tape will stop it leaking. From any plumbing/hardware store.
1200GXman
Posted: 2007/6/11 10:45  Updated: 2007/6/11 10:45
@1200rallycar
Sorry, I just bought it at our local parts store. Don't think the partnumbers will be the same as on your side. Just ask for a Nissan 1400 Pulsar thermo fan switch.
Ok, I ran into a bit of bad luck this weekend. I installed everything. I used some loctite on the thread of the switch and tightened it up so that the O-ring seals nice and relatively tight.Left it like that overnight and sunday afternoon I filled up the radiator.Started the engine and let it idle. At about precisely halfway I started to worry because the fan did not kick in yet. Spoke too soon. Exactly on the halfway mark on a stock datsun temp gauge and stock datsun temp sender unit fitted, the fan kicked on. So, to inform everyone, 85 C is at about precisely middle on the temp gauge. It ran for about 2 minutes and the needle dropped about 1 to 2mm and the fan switched off. Very happy about it. This was done without the radiator cap fitted so that the air bubbles could escape that could have gotten trapped in the system. Ok, now the presure test. I fitted the cap and would you believe me that there is a pin hole smaller than a hair's thickness that the missed in welding the T piece.
If I wipe away the radiator fluid from this hole with a tisue it take about 1 minute for a new one to develop.
A question. I want to take it to a exhaust shop and ask them to just spot weld the hole with a CO2 welder. Will it not damage the sensor due to electricity going to flow through it when welding?
Heat I am not so much worried about as it will be just a quick spot weld job on the hole.
Curtis
Posted: 2007/6/11 11:49  Updated: 2007/6/11 11:49
take it back to the engineer and tell him to get off his ass and learn to weld...
Wombat_racing
Posted: 2009/3/22 1:43  Updated: 2009/3/22 1:43
TheA14 powered N10 Pulsar has the same sort of set up standard Its mounted in the side of the engine bay and is fitted into the bottom hose. could work out cheaper than getting one made.
1200GXman
Posted: 2007/6/8 12:19  Updated: 2007/6/8 12:19
Just picked this up for the thermo switch to be installed in the top hose.
1400 Nissan Pulsar thermo fan switch.
Kicks on at 85 C and off again at 80 C.What can I use to put on the thread to prevent leaking? There is a O-ring at the top. Must I just tighten it up without anything on the thread?
beattie
Posted: 2007/6/8 12:14  Updated: 2007/6/8 12:14
cool, what did that set you back? kinda looks like the davies craig unit i mentioned in your thread
1200GXman
Posted: 2007/6/8 12:25  Updated: 2007/6/8 12:25
Well, the switch was R77 South African rand and the engineering of the T piece was R280 South African rand. Damn expensive and not even stainless steels. Not worrying much because the one T piece I removed from the bottom pipe only had surface rust on the outside and none on the inside. Is in the car for 2 to 3 years now.Will clean them up and spray them with some spraypaint on the outside or paint them with some heat resistant paint I have at home.Apparently the heat resistant paint sort of penetrates the metal.
1200rallycar
Posted: 2007/6/9 0:22  Updated: 2007/6/9 0:22
looks great!
im getting one of these instead of an adjustable probe one now, will be uch neater and reliable i think
i would say you need to tighten it down to the o-ring
do you have a part number for that switch?
1200rallycar
Posted: 2007/6/9 0:27  Updated: 2007/6/9 0:27
wait what am i talking about..
megasquirt is going to control my thermo now... hehehe
i already have a temp sensor tapped into the head for that
