[< Previous 2218 2219 2220 2221 2222 2223 2224 Next >]
| Poster |
Thread |
| stirlingmac |
Posted: 2007/7/5 8:42 Updated: 2007/7/5 8:42 |
Home away from home   Joined: 2000/5/6 From: Wellington New Zealand Posts: 962 |
 Re: Twin-SU manifold for A14 It looks like a factory 1400 GX set up to me.
| Poster |
Thread |
| Dodgeman |
Posted: 2007/7/5 9:05 Updated: 2007/7/5 9:05 |
No life (a.k.a. DattoMaster)   Joined: 2003/6/27 From: Southern Tablelands N.S.W. Australia Posts: 8287 |
 Re: Twin-SU manifold for A14 I don't believe that it is a factory manifold. I am very familiar with the 1200 & the later A12 GX induction systems & the only other GX was the A14. There is a factory GX manifold just up the road that is not a 1200 or A12 one so I presumed that it was an A14 item & yes, from memory it had 4 bolt carbs. I will try to get a picture of it & post it here for comparison.
| Poster |
Thread |
| ddgonzal |
Posted: 2007/7/6 2:09 Updated: 2007/7/6 2:09 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31865 |
 Re: Twin-SU manifold for A14 Thanks guys. Based on the A14 data, I was able to find all three in the parts catalog and make a comparison picture: manifold comparo
| Poster |
Thread |
| Dodgeman |
Posted: 2007/7/6 5:14 Updated: 2007/7/6 5:14 |
 Re: Twin-SU manifold for A14 Well strip my gears, I learn something new on this site every dang day. No wonder it's so well designed, it's a factory item after all. I'll just go over in this corner & have some more humble pie.
| Poster |
Thread |
| ddgonzal |
Posted: 2007/7/6 5:23 Updated: 2007/7/6 5:23 |
 Re: Twin-SU manifold for A14 me too, I was trying to sell it, and realized it was not an A12GX manifold, then worried it was "just" an SU manifold. I'm glad to find out it is an actual factory Nissan manifold.
Better yet, it is for the A14 oval port -- not the monster A12GX port.
| Poster |
Thread |
| Dodgeman |
Posted: 2007/7/6 5:49 Updated: 2007/7/6 5:49 |
 Re: Twin-SU manifold for A14 If you turn it around in another picture & provide the port dimention I believe that you will find out right quick.
Personally, I suspect that it is for the A14 Oval port head, but we shall see.
Do you have the carbs for it?
| Poster |
Thread |
| ddgonzal |
Posted: 2007/7/6 5:58 Updated: 2007/7/6 5:58 |
 Re: Twin-SU manifold for A14 Already measured it -- this manifold is for A14 Oval Port head (mid-size oval). Unfortunately I don't have carbs, which is why am agreeable to selling it. I started a wiki for it, with more details: wiki - Hitachi Twin Carb
| Poster |
Thread |
| Dodgeman |
Posted: 2007/7/6 6:03 Updated: 2007/7/6 6:03 |
 Re: Twin-SU manifold for A14 David, watch for incoming PM.
| Poster |
Thread |
| Dundee1000 |
Posted: 2007/7/6 6:23 Updated: 2007/7/6 6:23 |
No life (a.k.a. DattoMaster)   Joined: 2003/2/10 From: Freo Posts: 3318 |
 Re: Twin-SU manifold for A14 I best check the twins that came off my A15 and see if they are simular..
| Poster |
Thread |
| ddgonzal |
Posted: 2007/7/4 23:51 Updated: 2007/7/4 23:51 |
 Re: Twin-SU manifold for A14 Any ideas which company made this?
Looks like you could bolt either british SU HS4s on it (4-bolt) or Nissan Hitachi sidedrafts using 2 diagonal bolts.
| Poster |
Thread |
| Dodgeman |
Posted: 2007/7/5 2:39 Updated: 2007/7/5 2:39 |
 Re: Twin-SU manifold for A14 Those coolant galleries, for manifold heat, come right out to the carbs. Are there any British SU carbs that use the coolant to heat the carbs themselves. This would be particularly usefull in really cold areas. This looks to be a fairly well thought out design.
| Poster |
Thread |
| benny |
Posted: 2007/7/5 3:16 Updated: 2007/7/5 3:16 |
No life (a.k.a. DattoMaster)   Joined: 2002/6/14 From: Sydney Posts: 2598 |
 Re: Twin-SU manifold for A14 My original A14 import motor had this setup... The hitachis had the 4 bolt flange...
