Main : Members : PIGDOG skyline brakes on 200b struts
[<   Previous  64  65  66  67  68  69  70  Next   >]
skyline brakes on 200b strutsPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/7/13 12:05    Tell a friendTell a friend
Hits4373  Comments12    0.00 (0 votes)0.00 (0 votes)
fitted them up today to see what they would be like in the car
kululadotgroen
Posted: 2007/11/20 19:04  Updated: 2007/11/20 19:04
 Re: skyline brakes on 200b struts
Methinks when I take the engine out to fix it up, I'll have to upgrade the brakes as well. Luckily now I'll be close to my dad, having free machining to my hearts content, of the highest quality.
From which Skyline did they come?
Thanks your work has inspired me...
1200rallycar
Posted: 2007/11/21 1:33  Updated: 2007/11/21 1:33
cool, good inspiration shots
i just won a set of four coil over sleeve kits on ebay.... hope they arn't too shiet
was hoping to get those calipers on also, did you have a template for the caliper mount?
not sure if i should get 180b or 200b struts yet??
good to see you got the discs to work, might have to order a set of blanks, so theres no extra holes after drilling them to suit
oh yeah.. where did you get your adjustable tops? i'm looking around for a cheap set
PIGDOG
Posted: 2007/11/21 5:36  Updated: 2007/11/21 5:36
discs from an r33, machined down to 292m to fit in trx rims, calipers from an r32
no template really, but its not that hard to work out
get the disc modded to suit the hub then as long as you have newish pads and discs you can just slide the caliper onto the disc in the spot you want and start bracket making
for these brakes 200b struts are the way to go as the caliper mounting tags are a better offset, need a 10mm spacer i think between the strut and the caliper bracket to line the caliper up perfect with the disc, go to the next pic back in my album to see the bracket
the adjustable tops are JIC ones from an s13, they used to live in unfams sedan
1200rallycar
Posted: 2007/11/21 6:14  Updated: 2007/11/21 6:14
so the calipers are the GTR R32 or GTST etc?
PIGDOG
Posted: 2007/11/21 6:28  Updated: 2007/11/21 6:28
gtst, same as 300zx calipers
they originally suit a 280mm disc but they are just right for the 296mm discs when used on 200b struts
any smaller than around 290mm disc and the caliper mounting tags on the strut and caliper start to run into each other
PIGDOG
Posted: 2007/7/13 12:13  Updated: 2007/7/13 12:13
had to grind 2mm off the end of the steering arms so that the caliper and bracket would fit
also had to grind the fins off one of the calipers to get even 1mm of clearance at all piont around the rim
so its damn close
CA120Y
Posted: 2007/7/13 13:37  Updated: 2007/7/13 13:37
Quite a regular
what rotors have you used? did they bolt up to the hub? did you have to machine them at all?
ps love your work
PIGDOG
Posted: 2007/7/13 13:41  Updated: 2007/7/13 13:41
used 296x30 r33 gtst rotors
no they dont bolt up the the hub, nothing a lathe and drill press dont fix
have to machine the centre hole of the disc out, from 68mm to 73mm, then drill 4 new holes to mount to the hub
also will most likely machine the disc down 4 mm in diameter so that it has more clearance to the caliper, got about 1mm if that atm
CA120Y
Posted: 2007/7/14 5:47  Updated: 2007/7/14 5:47
Quite a regular
and you swaped the struts so you could mount the rotors on the front? is that nescessary?
last question i promise
dat141
Posted: 2007/7/14 6:18  Updated: 2007/7/14 6:18
Fingers crossed nothing gets caught between the caliper and the wheel then !
LittleFireyOne
Posted: 2007/7/15 2:53  Updated: 2007/7/15 2:53
Swapping the brakes to the front has a couple of advantages and sometimes nesesaties. The callipers will be getting more direct air for cooling since it's not blocked by the control arm.
The nesessty thing thiing is that some of these larger brake setups foul on the steering arm\linkages so to fit them properly would require to pretty nifty bending of those items which isn't easy to get right.
Ian's brakes are front mounted and the steering linkages still had to be slighty cold bent to give the right angles and stuff.
PIGDOG
Posted: 2007/7/18 12:13  Updated: 2007/7/18 12:13
yeah hopefully nothing getting in there between the caliper and the wheel.....dont want to scratch the nicely painted calipers
had to mount the caliper at the front as it would have the steering arm go straight through it other wise
