Main : Members : PIGDOG what is this?
[<   Previous  61  62  63  64  65  66  67  Next   >]
what is this?
what is this?Popular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/7/25 23:16    Tell a friendTell a friend
Hits4494  Comments14    0.00 (0 votes)0.00 (0 votes)
on the back of an 80s model ute speedo
kelmo
Posted: 2007/7/27 15:11  Updated: 2007/7/27 15:11
 Re: what is this?
On the 80's models it was a voltage regulator. When the part failed, the temp and fuel guage would fail. This looks very much like those but the regulator would not affect the speedo. Group "68" for nissan is generally dash trim and brackets. Are there any #'s that start with a "248XX" or a "B48XX"? What year is this veh?(I can't remember if that was stated earlier) Also, don't remember any US models having a regulator for speedo & tach.
dattodude
Posted: 2007/7/27 17:23  Updated: 2007/7/27 17:23
 Re: what is this?
Ok Ok..let me exercise my ebay purchases
I bought the Nissan Emission Control Workshop Manual some time ago, and it's in there.
It's referred to as an 'Amplifier'. It is part of the 'Throttle Opener Assembly'
It's only fitted to the Manual Transmission models.
Pub No. SM6E-EMC0A0, Page EC-11:
"The speed detecting switch is part of the speedometer assembly and is installed in the speedometer. The amplifier prevents damage to the speed detecting switch which actuate the throttle opener only when the car speed is above 10km/h."
Both the B210 and B120 have this device (although they have a different connector and mounting bracket).
sycodat
Posted: 2007/7/26 7:34  Updated: 2007/7/26 7:34
 Re: what is this?
how ever said it's a nissan part give him a jelly bean I have one in my 720 4wd it's to do with the odmator on your cluster
A14force
Posted: 2007/7/27 4:15  Updated: 2007/7/27 4:15
 Re: what is this?
it's probably a voltage stabiliser.
PIGDOG
Posted: 2007/7/27 6:19  Updated: 2007/7/27 6:19
 Re: what is this?
so why does it go into the speedo and earth when the speedo is at 0 kph?
id think its more of a switch for something that doesnt need to be working when stationary
dattodude
Posted: 2007/7/27 6:32  Updated: 2007/7/27 6:32
 Re: what is this?
Didn't we figure it was for pollution control...
Or is it a antique form of speed limiter .. Although, I thought it was generally accepted that the 'valve bounce in 4th' method kept speed under control.
Actually, after a long overdue bite of dinner... it's part of the dash light dimmer circuit.
edit2: after actually reading the thread..I return to being completely befuddled as to it's true purpose.
Dodgeman
Posted: 2007/7/27 6:41  Updated: 2007/7/27 6:41
 Re: what is this?
I believe that it is a speed detecting switch amplifier & is part of the polution control system.
Without actually checking, I suspect that it is somehow linked in with the BCDD system [Boost Controled Deceleration Device where the 'boost' is actually vacuum]
Many Datsun models in the late 70's & early 80's had these & the speedo has a switch that returns the system to full idle setting at speeds below a preset value of somewhere between about 6 to 8 mph. [or is it kph?]
Aussie series one 910 Bluebirds with manual trans had something like this.
ang94541
Posted: 2007/7/26 1:30  Updated: 2007/7/26 1:30
 Re: what is this?
An 80's era tap.
Someone's been listening to your conversations in the car bro.
PIGDOG
Posted: 2007/7/25 23:24  Updated: 2007/7/25 23:24
 Re: what is this?
my coupe speedos didnt have this, so i thought it was safe to take it off......i thought wrong
speedo goes up very slowly, got to about 40 in 50 mins of driving and hasnt seemed to come back down at all
problem is that one of the wires goes through the ute firewall in a plug that the sedan doesnt have, so i cant connect it
so does any one know what it is, and what it does(apart from make the speedo work)
frankthedolphintrainer
Posted: 2007/7/25 23:48  Updated: 2007/7/25 23:48
 Re: what is this?
there was a thread on this about 3 weeks ago i think everyone had a stab at what it was
PIGDOG
Posted: 2007/7/25 23:55  Updated: 2007/7/25 23:55
 Re: what is this?
any idea on what the name of the thread was....or if there were any decent answers?
Posted: 2007/7/26 0:20  Updated: 2007/7/26 0:20
 Re: what is this?
this is it i think in a rush clicky
Posted: 2007/7/26 0:34  Updated: 2007/7/26 0:34
 Re: what is this?
We never figured out what it was:
Anyone know? It is a Matsushita 68600-AN8500. Seems like a Nissan number:
68 Instrument section
PIGDOG
Posted: 2007/7/26 0:48  Updated: 2007/7/26 0:48
 Re: what is this?
ok i no longer care what it is as its not the reason why my speedo wasnt working, turns out that the late utes use a slightly different speedo cable to other datsuns
long story short, speedo cable was pressing against the speedo to hard and not letting it move freely
so ill just put the kph face on one of my coupe mph speedos
but just for the sake of finding out what this little doover does
one wire gets power from next to the tacho, another wire goes into the speedo and seems to ground when the needle is at 0 and the other heads off into the engine bay somewhere
