Main : Misc new bosch fuel pump where to fit
[<   Previous  2629  2630  2631  2632  2633  2634  2635  Next   >]
new bosch fuel pump where to fitPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/7/16 9:06    Tell a friendTell a friend
Hits2061  Comments4    0.00 (0 votes)0.00 (0 votes)
got my new fuel pump today and have no idea where to put it ,should i hide it near the tank at the back or have it up front in the bay?
1200rallycar
Posted: 2007/7/16 10:10  Updated: 2007/7/16 10:10
 Re: new bosch fuel pump where to fit
same as a vl pump
not designed to suck fuel up to it
better to keep it near the tank and lower than it where possible
mad120y
Posted: 2007/7/16 10:19  Updated: 2007/7/16 10:19
I've got mine basically under the passengers seat (driver side). there is a slight recess perfect to protect it from flying rocks
prospec
Posted: 2007/7/16 11:35  Updated: 2007/7/16 11:35
hey i have one of these pumps and looking with the rubber boot of the outlet is there suposed to be a banjo fitting coming out of it or what sort of fitting? Thanks
Whorida
Posted: 2007/7/16 11:38  Updated: 2007/7/16 11:38
Make a mount for inside the rear quarter. Fix it up behind one of the removable panels in the tray, perfectly hidden.
sssute
Posted: 2007/7/16 13:05  Updated: 2007/7/16 13:05
This is a mounting plate that is bolted with rubber mounts hunging from under the tray. I had the swell pot made in reverse so it can be hung. I ended up changing the lift pump, as the thing is way to loud. Main pump is a Bosch motorsport 44 pump.
