Main : Misc dog180s turbo manifold
[<   Previous  2618  2619  2620  2621  2622  2623  2624  Next   >]
dog180s turbo manifoldPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/7/19 9:19    Tell a friendTell a friend
Hits2417  Comments4    0.00 (0 votes)0.00 (0 votes)
a series
b310gx
Posted: 2007/7/23 9:46  Updated: 2007/7/23 9:46
 Re: dog180s turbo manifold
Dwayne, get rid of the little vaccum outlet on the brake booster fitting, cause on comes the boost, off goes the fitting. I'd just cut it flush with the outside of the fitting then braze, solder, etc the hole closed. Unless that's where
you're going to take off a boost guage,or run an auto. I'd also see if somebody could put some alloy welding into the holes the allen keys
go through, as i've had studs break this area out, then you get a massive leak.Maybe you could get the adaptor welded to the manifold so you can completely fill this area.
cheater_5
Posted: 2007/7/22 19:40  Updated: 2007/7/22 19:40
wouldnt it be wise to remove the line going from crankbreather or block breather on the right there and put it to a catch can instead of to the inlet.
Doesnt oil reduce the octane level of the petrol. in a turbo setup lower octane fuel is the last thing you want.
just plug up the inlet and add a catch can.
just a thought
possum1200
Posted: 2007/7/22 20:08  Updated: 2007/7/22 20:08
what size hose is the crank breather??
benny
Posted: 2007/7/19 10:02  Updated: 2007/7/19 10:02
Should be the goods Dwayne. Im thinking it should make more power than the setup that was in the Sunny...
1200GXman
Posted: 2007/7/19 11:08  Updated: 2007/7/19 11:08
How did you drop compression?
dog160
Posted: 2007/7/19 11:43  Updated: 2007/7/19 11:43
From: In front, and pulling away.Sometimes around Sydney....ish!
Thanks Benny. As you know, the brother has some fabrication to do! Cheaper to get one made than ask the bro
1200GX- It has a 3mm decompression plate, but I will pull that out shortly to increase driveability off boost.
